14-06-2006, 08:05 PM | #1 | ||
Now drifting a falcon
does the au 220kw throttlebody fit on a ed v8? if not what does, for an upgrade and what sort of price would i be looking at????
14-06-2006, 09:38 PM | #2 | ||
Yep it'll fit up fine. Don't expect any power gains with the standard HO manifold still in place though. (Says he with an AU t/b lol)
Oh, and have fun putting your TPS back on ;) Mine's held in with one screw, full backyard stylez |
15-06-2006, 07:59 PM | #3 | ||
if you dont mind me askin whats the tps
15-06-2006, 08:01 PM | #4 | ||
throttle position sensor (the black sensor on top)
15-06-2006, 08:03 PM | #5 | |||
15-06-2006, 08:14 PM | #6 | ||
meow
Will 'fit' straight on except for the TPS as Dave pointed out, I think you can either 'force it' to fit, or rewire it to fit.
Price? Anywhere from $50-$250, I wouldn't pay much over $150 for one tho. Gains? Minimal at best if everything else is stock. |
15-06-2006, 08:33 PM | #7 | ||
ive got k&n extractors and stuff like that? still any power difference? where would i be able to get it?
15-06-2006, 08:38 PM | #8 | |||
meow
Look through eBay and on the forums. With exhaust and intake done you might notice a small difference... the MAF will now be a restriction, better to have a bigger maf and smaller t/b (I think rule of thumb is 5-7mm difference?) |
15-06-2006, 09:00 PM | #9 | ||
whats that the grey metal thing near the air box, its really restrictive, wats that and where can i get em and how much
15-06-2006, 09:14 PM | #10 | ||
That's the MAF. You'll have to find these things second hand as Ford pricing is beyond sanity.
15-06-2006, 10:53 PM | #11 | ||
As I said, your HO manifold will still pose as a restriction which will mean your upsized throttle body won't be giving you much - if any - more power.
But by all means, get the throttle body now whilst on the hunt for a manifold! And I believe Free347 is hinting that he has a throttle body for sale. |
15-06-2006, 11:55 PM | #12 | ||
what am i looking for when im in for maf
16-06-2006, 11:44 AM | #13 | ||
meow
Probably one off an AU or an aftermarket one. C&L or Mass Air spring to mind.
Up to $400. |
18-06-2006, 06:30 PM | #14 | ||
Here's an AU MAF body vs an EB MAF body
18-06-2006, 06:41 PM | #15 | ||
Looking at the pics, could you get creative with the die grinder and open it up a bit?
18-06-2006, 06:47 PM | #16 | |||
AFF's 1st DM.......
Nope and they are matched to injectors.
ie eb has 19lb injectors you cant just slap an AU maf as they are set for 24's.
FORD GIVING POWER TO THE PEOPLE Alloy headed 347ci EDXR8 13.21 @107.7mph Quote:
18-06-2006, 06:50 PM | #17 | |||
18-06-2006, 06:54 PM | #18 | |||
18-06-2006, 07:42 PM | #19 | ||||
Back on the road
There is a "MAF Voltage vs Air Mass", aka MAF Transfer, function in the EEC that is calibrated to the combination of MAF electronics and MAF body. Quote:
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
18-06-2006, 10:04 PM | #20 | ||
so how do you recalibrate the au maf to match 19lb injectors?
or are bigger injectors needed with a bigger maf |
18-06-2006, 10:19 PM | #21 | ||||
AFF's 1st DM.......
So your saying i can fit an ebgt maf to a std eb 5.0l engine and itll work fine.... Hmmmm i thinks not
18-06-2006, 10:32 PM | #22 | |||
Back on the road
You make sure the EEC has the correct MAF Trasnfer function for the MAF it is using, and that the injector slopes are set correctly for the injector size being used.
18-06-2006, 10:38 PM | #23 | |||
Back on the road
The answer is no, because they are a different MAF.
19-06-2006, 04:37 PM | #24 | ||
ok? with those pics back up there with the maf's was that a au 6? can they fir on the ed v8?
19-06-2006, 04:49 PM | #25 | ||
Back on the road
Nah, they are 70mm AU V8 (left) and 55mm E-Series V8 (right).
The i6 doesn't have a MAF, it has a MAP. You can fit the AU V8 MAF and a Chiptorque chip, or even better twEECer if supported, to recalibrate the EEC for the bigger AU MAF.
19-06-2006, 04:51 PM | #26 | ||
i cant just bolt it on?, wat if i did
19-06-2006, 04:55 PM | #27 | ||
Back on the road
The AU MAF has a different plug than the E-Series, so you can't just plug it in without modifying the loom.
Even if you could, the MAF Transfer function in the EEC would be all wrong for the signal sent from the new MAF. It would run, but most likely start getting real lean at high load values.
19-06-2006, 04:57 PM | #28 | ||
go any harder?
19-06-2006, 05:00 PM | #29 | ||||
meow
19-06-2006, 08:20 PM | #30 | |||
LOL xr8ute, I love your term! I suppose it's correct, being a Frankenstein MAF :P I don't really have an optimum tune, and she does ping a little under throttle at higher speeds. (I use unleaded). If you think my MAF is dodgy, you should see how I've shoehorned the EB TPS onto my AU throttle body! :hihi: |
