22-06-2006, 05:14 PM | #1 | ||
evening all
Picked up a set of BA 17s to put on my EF. I have hub adaptors from my 18 inch Zenettis. heres the dilema- the lip on the adaptor wont fit into the 17s because the rims have a small ridge on them. The easiest way around it is to grind the lip off the adaptor but i dont really want to tamper with them. Should i take to the rims with a dremel or is it something best left to the pros? Cheers Tim for those thinking about the unsafe and illegal adaptor lecture, dont bother |
22-06-2006, 05:31 PM | #2 | ||
will also add that the adaptors are 37mm thick. is this the size commonly used with these wheels?
22-06-2006, 05:57 PM | #3 | ||
can't u just the the ba rims with the ef offset??
oh yeah, sorry, i have no idea about adaptors/spacers... I didn't insurance places liked em.. |
22-06-2006, 05:58 PM | #4 | ||
White Lightning
yeh mate i took the dremel to my rims actually. ground the lip a bit all the way round on the inside of the rim. then they went on perfectly.
22-06-2006, 06:56 PM | #5 | ||
if its good enough for you simmo its good enough for me.
cheers mate |
22-06-2006, 07:41 PM | #6 | ||
OzEcruisers PRESIDENT
Hmmmmm dremel, what not just take a hack saw to them, lol.
Guess if you have re-treads on them then go for it as they are already stuffed. Arent wheels the feet of your car, just as important as brakes, love to see how many weights are going to be stuck on them after you "dremel" them - so they are balanced. :1syellow1
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan PROEF 13.46 @ 105.78mph Tuned by DYNOMOTIVE 200BUX - AFF Drag Nats 2019 EF Wagon
22-06-2006, 08:09 PM | #7 | ||
everyones a comedian. _ point taken though.
I could see it being a problem if i was playing with the outer edge of the wheel but i doubt there would be a real balance problem with taking a little from the centre of the wheel. |
22-06-2006, 08:11 PM | #8 | ||
You could have bought Ba copies in 17" and 18" made to e-series off set which saves alot of muching around and keeps the insurance companies happy too
22-06-2006, 09:06 PM | #9 | ||
they were a good price so i jumped on them. Thought it would be straight forward. adaptors dont bother me, never had any hastles before. might still sell them and get my zenetti repaired
22-06-2006, 11:13 PM | #10 | |||
I thought Adapters are legal is some states anyway(not vic I know that much) so thats not really the issue If it works and they sit flat and are balanced then there shouldnt be an issue except for the obvious (Insurance/Roadworthy) PS they are very nice looking rims
23-06-2006, 12:11 AM | #11 | ||
thanks for your reply hemi. I will probably run them until i can afford a better arrangement, without adaptors.
I dont know you bud, how was i to know you were joking? sounded smart to me. I suppose you get that with the internet |
23-06-2006, 12:29 PM | #12 | |||
I was saying its good to see some one can take a joke (it wasn't sarcism) meaning you can take a joke..........
23-06-2006, 02:24 PM | #13 | ||
Oops, I slipped....
If you're going to grind the rim, make sure you do it very slowly, bit by bit. If you take too much off, the rims won't sit on the spigot (the round thing in the middle of the hub) and then weight will be taken by the wheel studs, which IS dangerous.
You also might want to consider re-sale, if you grind them, they won't be safe on an AU-BF....
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
23-06-2006, 03:41 PM | #14 | ||
White Lightning
the amount i took off was pitiful. seriously no more than a minute with the standard brown dremel grinding wheel.
