Old 23-06-2006, 02:14 AM   #1
XITED_6
Was It Something I Said!
Default Gear knob
Hey guys.
Just curious if any1 has fitted a BA momo manual gear knob onto a AU stick???
Looking at doing this just wondering if they fit staright on...
Anyway...
If any1 has done this or know if it can fit straight on with some pics possible it be great.
Thanks
we live in a age where pizza gets to your door before the police
XITED_6 is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2006, 02:19 AM   #2
JC
JC's Avatar
Falkeen had done this to his XR8 ute. It should be a straight screw off/screw on job.
Ford Performance Club ACT
Old 23-06-2006, 02:20 AM   #3
ziggee
yeah they fit... 10mm thread..
but you might need to grind down the stick, as the BA knob is quite long... so have angle grinder ready, or better yet a metal lathe... ;)
Old 23-06-2006, 08:34 AM   #4
AU:PROJECT:UTE
Drought Breaker
AU:PROJECT:UTE's Avatar
Or you cant unclip the boot, take off the shift lever, cut 4" out of the fat section of the shaft and then weld it back together. Grind it off smooth and then refit, works well and cuts the height down heaps.
Whereas rethreading the shaft can only shorten the shifter approx 1".
2002 AUIII XL W/- Custom Tray
ALL COUNTRY: SW Platt Mccann 5 Poster, GME 4706 7' Whippys, Uniden UH015SX UHF AND Scanner combo, Narva Taurus Bull lights, Hawk Grille, Series II Pursuit Side Skirts, Stickers on the back window and more eartags than a mob of cranky angus
ALL GO: XR6 VCT donk and ECU NO MORE!!
Now even MORE fun with 200kw XR8 and 5 speed, Tickford Cluster, 3.45 LSD, full custom twin system w/- 3" chrome angle cut tips :
AU:PROJECT:UTE is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2006, 04:43 PM   #5
XITED_6
I already have a shorter "BPT" stick/leaver which sits at a nice height.
So the manual BA momo gear knob should fit easy as screwing it on with no dramas.
Thanks guys.
Old 23-06-2006, 05:20 PM   #6
ziggee
heheh i did mine with a grinder..... thank god its covered up by the boot! its aint pretty, but works... try grinding 10cm?? off a 20mm bar into 10mm and see how round you end up with!... actually its not that bad, although I will not be able to re-thread it again... doh!
