Old 23-06-2006, 04:33 PM   #1
syktlr
stktlr
syktlr's Avatar
Default Irs
how do i know if my 99au fairy is irs or not tried looking underneath to see but not sure wat im looking for
syktlr is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2006, 04:57 PM   #2
Mark351
Built Ford Tough
Mark351's Avatar
Try looking for Watts Linkage, if you've got that, no IRS.
Black on white '83 SWB F100 C6 auto 351C on gas and on the ground --> Project Thread
'55 F100, just a roller at the moment, new project
Silver MY12 Volkswagen Amarok
Mark351 is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2006, 04:59 PM   #3
syktlr
stktlr
syktlr's Avatar
is that the bars running from under the springs to the front of the car
Old 23-06-2006, 05:08 PM   #4
FTE217
T3/Sprint8
FTE217's Avatar
Sounds like the upper and lower control arms, if you have this no IRS I'm afraid.
Tickfords T3/TS50 '02
Sprint8 manual Sept 24 '16
Daily Macan GTS
"Don't believe everything you read on the internet. Abraham Lincoln"
FTE217 is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2006, 05:14 PM   #5
syktlr
stktlr
syktlr's Avatar
oh bugger life goes on though thanks
Old 23-06-2006, 05:21 PM   #6
T3man
T3man's Avatar
And it sounds like you're confused - upper and lower control arms (another name for wishbones) is EXACTLY what IRS is about. Maybe you meant upper and lower trailing links - this is what the Watts rear end uses.
syktlr> Look under the back of your car - if you see a solid beam going from one side to the other, and carrying the diff in the centre, and with a Pivot mount on the diff carrying two locating rods then you are looking at a Watts link rear end.
