Old 06-07-2006, 11:15 PM   #1
XEESP_351
Default au independant rear axle tramp
has any1 here that owns a xr series au (specificly xr8 III) with independant rear end suffered from axle tramp or bounce when accelerating hard from a standing still or when wheelspining (BURNOUT). it still has standed shocks and springs
XEESP_351 is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2006, 06:45 AM   #2
sickxr
Ford POWER!
sickxr's Avatar
Yeah my xr6 does it really bad.. i had posted the same question about a month ago. Mine isnt IRS tho.
Liquid Silver Ford Falcon AUII XR6 HP Manual
sickxr is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2006, 07:19 AM   #3
fordAU
No problems at all with a Manual S3 XR8, the vehicle has done 55 thou so the shocks are still ok.
One thing I did at the last service was to have the diff refilled with the heaviest oil the Mechanic could find.
Whilst I never have experienced axle tramp the heavier oil has made the diff less clunky, the manuals have bad manners at low speed and this has improved driveability.
If you vehicle is a manual could be worth a try, if an auto not sure if this would make any difference.
Cheers.
fordAU is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2006, 09:06 AM   #4
FTE217
T3/Sprint8
FTE217's Avatar
No not at all.
Tickfords T3/TS50 '02
Sprint8 manual Sept 24 '16
Daily Macan GTS
"Don't believe everything you read on the internet. Abraham Lincoln"
FTE217 is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2006, 09:08 AM   #5
AUIII XR8 MAN
DJR TM#54
AUIII XR8 MAN's Avatar
No problem with that here either.
When traveling to V8 Supercar rounds, i book through KYLEE MOLE Travel agents, She Goes, She Goes, She Goes & I just went.
Now Zetec Powered. 1.6lt of madness. But the XR8 still remains
AUIII XR8 MAN is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2006, 09:39 AM   #6
MRJUCY
Fordless
MRJUCY's Avatar
Mine's a TE50 but yes they can be made to tramp a touch I find if you give it too much off the mark to get away cleanly but not enough to really get the wheels spinning it will do a little dance before taking off. I think it's more to do with learning to drive the car properly then trying to change the car.
MRJUCY is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2006, 11:56 AM   #7
loxxr6
XB in parts...
loxxr6's Avatar
I can get it pretty bad but I have lowered springs and standard shocks.... (non irs tho). I had the same prob prior to lowering the car.
However if I'm pretty sensible with the revs it's not that bad.
Old 07-07-2006, 12:28 PM   #8
FTE217
T3/Sprint8
FTE217's Avatar
That's live axle loxx,one of it's traits.....where as irs doesn't really have this issue but I suppose it's how hard you push it !
Daily Macan GTS
Old 07-07-2006, 09:06 PM   #9
XEESP_351
fordau yes mine is manual aswell but i done 120k thinking might be shocks although seems ok on bounce test and no signs of oil leakage from shocks..although they could be gas dunno...even if i dont dump clutch still does it.. no bounce when sideways..would a progresive shock fix problem or should fit lower springs?
Old 07-07-2006, 09:16 PM   #10
XEESP_351
mr jucy even when soft of line with a bit of clutch still does it anytime wheel spin is incountered it does it
Old 07-07-2006, 10:24 PM   #11
jimt3te50
My kids think I'm cool
jimt3te50's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Jim has consistently for some time now shared his life, and his passions in his XY GT and more so his FG GT in a way so everyone here feels part of the journey, which helps make AFF such a worthwhile place to be.  An outstanding contributor in my book.
Mine tramps pretty bad but I've changed so much I wouldn't know where to start looking! lol
As bluedriver said, probably more a matter of learning how to drive the car accordingly then looking for things to change........
2011 FPV GT 335 >My Build Thread<
(Posts 3511-3515 has a compilation of most of the pics, page 118 @ 30 posts per page)
BLUESTREAK built 5.2L flat-plane-crank VOODOO with 3.2L Intercooled Kenne Bell blower, 1000rwhp/746rwkw @ 8000rpm @ 20psi on E85. Built ZF with BLUESTREAK 2C Circle D converter. Unbloodybelievable...
2018 Ford Ranger RAPTOR
2013 Audi SQ5
jimt3te50 is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2006, 10:34 PM   #12
XEESP_351
yeh prolly way i drive but still IRS shouldnt be as serious i would have thought..thats the whole point? it doesnt seem to squat much under load...
Old 08-07-2006, 07:58 AM   #13
Tickford Kid
Formerly known as TS 50
Tickford Kid's Avatar
Check your top shock mounts. Could be stuffed and that could make your shocks null and void.
BLUEPRINT T3 TS50 #109, MANUAL WITH BREMBOS
Tickford Kid is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2006, 08:23 AM   #14
sbutler
335 kw of goodness
sbutler's Avatar
Axel tramp is a problem with AU IRS as TS 50 said rear shock mounts will make it worse, so will broken left engine mount bolts.
I have had my T3 since new & its always done it. Sometimes it can be very bad, other times dosen't do it at all.
It seems to be effected by the way you drive, the road, the weather, but I wouldn't say the shocks are the cause.
CAUTION!
STILL Contain's opinion's & fact's that may offend !!!
2012 GTP 213 black what was I thinking? NOW FOR SALE>>
http://www.fordforums.com.au/showthread.php?t=11439680
sbutler is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2006, 12:55 PM   #15
RspecAU
BA GT-P Owner
RspecAU's Avatar
My XR8 IRS is bad for it to check the top shock mount or ur shocks themselves. You should also check ur wheel bearing as well. I have replaced the shock monts but havn't had a chance to test it out properly yet but i'm sure thst i have fixed this problem
DAILY DRIVER/TRACK CAR
BUILD NUMBER 006
Old 08-07-2006, 06:53 PM   #16
Andy XR8
AU3 Winged Windsor
Andy XR8's Avatar
i also suffer from a bit of axle tramp mostly when its wet and spinning in a straight line not when sideways i think its to do with the tyres trying to get traction but dont quote me on that
Andy XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 10-07-2006, 12:48 AM   #17
HP Dude
Tickford Rules!
HP Dude's Avatar
I get axle tramp when I accelerate (pretty) hard out of corners.
Tickford Rules! :eclipsee_
1969 Ford Fairmont XW
1999 AU I Falcon XR6HP
1999 AU I Falcon XR8 (sold)
2007 Mitsubishi Evolution IX
2009 Lotus Elise S
HP Dude is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2006, 10:03 PM   #18
XEESP_351
FIXED!!!
i replaced rear springs and shocks with stage 2 pedders sports ryders alot firmer shock than standard tickford..It squats alot more too...and guard height real good too not too low and lower than standard tickford...happy
Old 24-07-2006, 10:08 PM   #19
loxxr6
XB in parts...
loxxr6's Avatar
So is the ride rougher ?
Old 25-07-2006, 07:47 PM   #20
XEESP_351
no feels bout the same doesnt have that dreadful ute feel when real hard springs fitted im very happy with result...like a imentioned before it squats better i think very good combination...Some king springs feel very hard when ive driven other cars ..and no worry of tyre rubbing either on guards..
