hey guys
I have a dodgie ariel fitted, and want to fit an electric ariel im looking at buying off eBay. http://cgi.ebay.com.au/ws/eBayISAPI....MEBI%3AIT&rd=1 Has anyone done this ? How easy is it and can i do it myself ? (im not that good with cars but wanting to learn) is it like plug and play ? lol Jeff
:eclipsee_ MY CAR :eclipsee_
you could also try your local auto parts store, ie repco, supercheap, etc. they sell them to. do you have an aftermarket head unit or the factory one?
#3 | |||
well providing it has a power output for an electric aerial then it should work, basically it has a power, ground and signal wire, so as long as the head unit can output signal then it should be ok. the best thing to do would be to pull off the trim inside the passenger side wheel well where the normal aerial is and see if there is a plug or anything in there to plug into
Smile
I have bought a few au dedicated aerials and they do not fit in without modification..I hopoe yours does as this can be a pain.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
Your reception will suffer with electric so its not really worth it
Isn't the electric aerials on futuras standard?
My 99 futura has one, so I don't think it would be too hard to get it to work. Reception is fantastic! |
If you can send me your fax number via PM, I call fax the two pages out of the workshop manual to you on Monday.
It will give you an idea as to what is involved. Alternatively, you could pick up a manual from an auto parts shop. |
#10 | |||
as the parts that slide in each other generate static as it shakes in the wind |
#11 | |||
#12 | ||
CRE.87V
shouldnt there be a 2 pin harness behind the pas kick panel to plug this into??? as well as the aerial extension???....i fitted one to my bro au falcon....just held in by a 10 or 12 mm bolt...easy
i have an auto aerial for sale out of my s1 xr6 if u want to buy it for about 60 bucks....im in newcastle....and im always in the marys to go to tafe burley |
#13 | |||
![]() Join Date: Dec 2004
#14 | ||||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
#15 | ||
Can't pull them up & down at all
Its a fixed mast with no sliding parts |
#16 | ||
well being that you're in america i'd say theres a chance that the actual aerial design would be different here, ive never heard of any reception problems with premo sound from aerials causing static
#18 | ||
afaik just a philips head screwdriver, also it may be easier if you take the passenger side wheel off, to remove the guard cover from inside
#19 | ||
CRE.87V
undo the tree plug in the inner guard...and ull need to bend a tab to get it out...u will see the aerial in there...its held in by one 10 or 12 mm nut..undo this slide it down out from the top of guard....this plastic plug on gaurd may or may not need to be removed for the auto aerial
hope it helps |
#20 | |||
i'll give it ago - assuming i win this item from ebay ![]()
#21 | |||
My Cars: 2002 Ford Falcon AU S3 SR 2006 BF MKI Falcon XR6 2008 Mazda BT50 SDX 2004 BA XR8 ute 2006 AUDI A4 B7 2013 FG II XR6 Ute 2006 Ford Territory TX 2003 Ford Falcon XR8 2009 Territory Turbo Ghia Current: 2012 Audi A4 B8 2.0T Quattro |
#22 | ||
CRE.87V
i said in this post.....ive got one id sell ya....make me an offer...im from newcastle
#23 | ||
Ford Owner
The mast in mine has broke yesterday, it's a factory fitted electric aerial, will have to pull it out and replace the mast, put back together on the week end,
After calling ford they sell the mast for $50 and a genuine complete electric aerial for $300, after calling auto barn, they sell a complete aerial to fit au for $119, or a mast for $29. Will post an update after the jobs done. |
