Old 17-08-2006, 08:47 PM   #1
dveus 1
93' 5 Litre LTD
dveus 1's Avatar
Default About Cams for 5lt V8
In the not too distant future I will be shopping around for a cam for my 5Lt LTD.I have no idea about what type,how much pricewise and what the benefits apart from the obvious and also what else I will need.Being a new E-series member with 1 cruise under my belt I am hoping you guys can shed some light on this subject and share your knowledge.Thanks in advance,,,Andy
Andy :sm_headba
1993 5 Litre LTD.Stock motor.tinted windows,sunroof,pioneer P7550 7" DVD head deck + 2x7" headrest monitors,pioneer 260w rear,110w front,Kicker ES 1000w subby run by audioline 4channel 800w boot.Duel Fuel. Catback 2.5" exhaust.Hornet Alarm,Pimped Out LED's,Sits on King Lows & 17" ROH RT's.
A WORK IN PROGRESS HEHE :eclipsee_
Daily Ride: 1989 Telstar TX5 TURBO
dveus 1 is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2006, 11:19 PM   #2
anakha
What mods have you already done to the car and what are your goals with it?
If its a stocker or close to it I would uncorking the intake and exhaust first. Depending on budget go for headers and cat back. Also look for either an AU/Explorer manifold and if you can stretch for it some new heads. Some shorter rear gears and a higher stall converter would help. All of those things, as well as a larger MAF and throttle body I would consider before a cam change.
anakha is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2006, 11:23 PM   #3
dveus 1
93' 5 Litre LTD
dveus 1's Avatar
Yes..its stock at the moment.First mod next week is catback 2.5" exhaust..I planned to get the headers and hi flo cat converter a little later....then a few weeks after that..wheels and tyres.Then I planned to start on the motor.Thanks very much for your feedback.I will be taking it all in.regards,,,Andy
Andy :sm_headba
Old 17-08-2006, 11:25 PM   #4
John_LS1
I agree with anakha.
cam means basicly dissasembling half the motor and is not a quick/easy job. do the bolt ons first then do heads and cam at the same time. depending on what cam you choose you could get the heads/springs/rockers done to suit.
Old 17-08-2006, 11:29 PM   #5
svo347
AFF's 1st DM.......
svo347's Avatar
Unless you change the heads now, i wouldnt recommend changing the cat, it'll outflow the E7's easily
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 17-08-2006, 11:31 PM   #6
dveus 1
93' 5 Litre LTD
dveus 1's Avatar
Goals are mainly street use and club cruising but would like the motor to be moderately(Medium) beefed up for my own personal enjoyment..cheers,,Andy
Andy :sm_headba
Old 17-08-2006, 11:34 PM   #7
dveus 1
93' 5 Litre LTD
dveus 1's Avatar
cool..so im doing things in the right order then...bolt ons(exhaust) first then do the heads and cam and cat after that.
Andy :sm_headba
Old 17-08-2006, 11:37 PM   #8
svo347
AFF's 1st DM.......
svo347's Avatar
Head port etc but if your serious you would be better off with better heads. Either GT40'Ps (Ford) or aftermarket(Edelbrock,AFR,Trickflow etc)..
Good deals going around with the ford heads and explorer manifolds which would be your best bet if wanting "Factory Ford"....
13.21 @107.7mph
Old 17-08-2006, 11:43 PM   #9
jimt3te50
My kids think I'm cool
jimt3te50's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Jim has consistently for some time now shared his life, and his passions in his XY GT and more so his FG GT in a way so everyone here feels part of the journey, which helps make AFF such a worthwhile place to be.  An outstanding contributor in my book.
I sold the worked T3 GT40P heads off my car to offyaguts and he ran that in an auto EF/L(?) Fairmont with the trickflow TFS1 cam and it ran about 98mph over the 1/4 with no stally or good tyres........
The GT40P's (best of the iron heads anyway) run around $800-$1300 depending on valve gear etc and will be the single greatest gain I would say- the explorer manifold should be done same time to maximise the gain from the heads and you might as well do the cam same time........ As others have said it will end up being a big job.
Hell, modding a V8 in ANY way, turns out to be a big job..... can we get a show of hands from those who spent three times what they thought they were going to? :
2011 FPV GT 335 >My Build Thread<
(Posts 3511-3515 has a compilation of most of the pics, page 118 @ 30 posts per page)
BLUESTREAK built 5.2L flat-plane-crank VOODOO with 3.2L Intercooled Kenne Bell blower, 1000rwhp/746rwkw @ 8000rpm @ 20psi on E85. Built ZF with BLUESTREAK 2C Circle D converter. Unbloodybelievable...
2018 Ford Ranger RAPTOR
2013 Audi SQ5
jimt3te50 is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2006, 11:46 PM   #10
svo347
AFF's 1st DM.......
svo347's Avatar
Yer ........
:gren:
13.21 @107.7mph
Old 18-08-2006, 01:43 AM   #11
FPVWEPN
Team Urinal Cake Racing
FPVWEPN's Avatar
jim ur torque rating is at the wheels yhe???? Because if it isn't thats a bit confusing as dont stock te50's have 500nm?
FPVWEPN is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2006, 01:47 AM   #12
svo347
AFF's 1st DM.......
svo347's Avatar
No mate not stock. do a search on jims posts, at 400 rw/hp no way.
http://fordforums.com.au/showthread.php?t=32600
13.21 @107.7mph
Old 18-08-2006, 06:35 AM   #13
Devious Jet
Devious Motorsports
Devious Jet's Avatar
With the exhaust.......I found a twin 2 1/4 inch into a 3 inch system works awesome....
Has a nice note and is not really too loud, and has given me better fuel economy! true!
I had a 2.5 inch exhaust on my stock 5.0 and it sounded terrible.....no...make that worse then terible!
1992 EB 'S' wagon....5.0 V8....WOO HOO 3" exhaust now!
Devious Jet is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2006, 09:17 AM   #14
Walkinshaw
Two > One
Walkinshaw's Avatar
Good street cams would be
Crane powermax 2030 (or 2031 with 1.7:1 rollers)
TFS 1
BarryV put a 2030 into his DC LTD with Edelbrock manafold, 65mm TB, ProM MAF and home ported E7TE's. The cam made the biggest diffrence our of all the mods by far. Very torquie.
Old 19-08-2006, 11:25 AM   #15
dveus 1
93' 5 Litre LTD
dveus 1's Avatar
Great Guys...thanks for the feedback.im keeping this thread for future reference.Looks like Ive got a bit of overtime to do LMAO in the not too distant future.
Andy :sm_headba
Old 19-08-2006, 11:33 AM   #16
LUXO_8
windsor user
also have a read through the windsor section of the site......
link
http://www.fordforums.com.au/forumdisplay.php?f=11
hell yes...... :
Old 19-08-2006, 01:38 PM   #17
Sylox
Uterus M.I.A.
Sylox's Avatar
Have a look though my project thread as well. I not to long back did a TFS1 cam install etc etc
Sylox is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2006, 12:17 AM   #18
dveus 1
93' 5 Litre LTD
dveus 1's Avatar
cool...will do ,,thanks
Andy :sm_headba
