Old 17-08-2006, 09:57 PM   #1
kennys
Question BA TR3650 5speed
Will a BA TR3650 5speed manual fit into my AU2 XR8?
Are these the same 5 speeds used in the 5.6 litre strokers?
Im guessing i'l have to change the bellhousing? Is this the only modification il have to do?
kennys is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2006, 10:43 PM   #2
56L
a.k.a PAULY
56L's Avatar
there is a fair few differences in the box as i am sure the input shaft is totally different in size and lenght, the 5.6 has a custom bellhousing specially made for tickford,you can get BA 3650 boxes for around $800 and the AU 3650 tend to fetch around the $2000 plus mark, to buy parts to replicate a AU box would be expensive and thats if you could get the parts as i am sure some are unavailable
there are alot of people on here that know alot more detail so sit tight and i am sure they will give more accurate details
you would also need a 26 spline clutch plate
and i would say another driveshaft as the 3650 is longer than the t5 and may be different gearbox cross member, speek to mal wood automotive as he is the tremec importer for australia and he would probably have a kit to suit,but it all adds up and could turn out to be quite expensive
the amount of money that it could cost you may be the difference between your au2 and a cheap te50 fitted with a tremec
jimt3te50 would know
2002 silhouette pursuit 250 manual,brembos, 3.73,s
2002 blue print pursuit 250 in restoration
1995 WMW250(CR250) dirtbike fully road registered
1947 ford thames tipper V8 21 stud flat head
1939 ford beer barrel truck V8 24 stud flat head
HZJ diesel ute
HJ47 diesel ute
56L is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2006, 11:03 PM   #3
jimt3te50
My kids think I'm cool
jimt3te50's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Jim has consistently for some time now shared his life, and his passions in his XY GT and more so his FG GT in a way so everyone here feels part of the journey, which helps make AFF such a worthwhile place to be.  An outstanding contributor in my book.
yeah you're spot on mate
2011 FPV GT 335 >My Build Thread<
(Posts 3511-3515 has a compilation of most of the pics, page 118 @ 30 posts per page)
BLUESTREAK built 5.2L flat-plane-crank VOODOO with 3.2L Intercooled Kenne Bell blower, 1000rwhp/746rwkw @ 8000rpm @ 20psi on E85. Built ZF with BLUESTREAK 2C Circle D converter. Unbloodybelievable...
2018 Ford Ranger RAPTOR
2013 Audi SQ5
jimt3te50 is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2006, 11:37 PM   #4
howesy
howesy's Avatar
Bare in mind mal Wood only charges around $7000 drive in drive out with new clutch for a Six speed for the AU.
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2006, 11:40 PM   #5
svo347
AFF's 1st DM.......
svo347's Avatar
Hmmm pocket change
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 17-08-2006, 11:48 PM   #6
jimt3te50
jimt3te50's Avatar
Originally Posted by svo347
Hmmm pocket change
Yeah- that's what I thought.......
$7k plus fitting, plus clutch- I'd hardly call it "only $7k" considering that's more than half what most AU's are worth now.........
Believe me- if I thought "only" $7k was a bargain I'd have one, but I don't- if I could get a BA one to fit, at $800 I'd have two in the shed......
2013 Audi SQ5
Old 18-08-2006, 06:56 PM   #7
kennys
Thanks for the info guys...
I thought the input shaft would have been different, looks like i'l be sticking with the auto
Old 19-08-2006, 12:42 PM   #8
kennys
So i take it the BA 97LE auto will be the same, as in the gearbox length will be longer than the AU 97LE?
Old 19-08-2006, 07:26 PM   #9
sbutler
335 kw of goodness
sbutler's Avatar
I think you'll find out, its more like drive in, tow out, because there wont be a box or clutch & other bit & bobs fitted ...
CAUTION!
STILL Contain's opinion's & fact's that may offend !!!
2012 GTP 213 black what was I thinking? NOW FOR SALE>>
http://www.fordforums.com.au/showthread.php?t=11439680
sbutler is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2006, 07:57 PM   #10
howesy
howesy's Avatar
Thats what they said when I was up there can only go on that. Thought it was too expensive so tried to get a price on a brand new imported one in sydney and it was $5500 and would still need alteration.
Old 20-08-2006, 07:41 AM   #11
sbutler
335 kw of goodness
sbutler's Avatar
It might be worth getting onto some sites in the states, the 3650 was used behind a Mustang with a windsor engine, but I cant remember which model. I think it may have been a Saleen. Do a search & you might get onto one there.
The biggest problem was the Tickford addapter plate. Tickford chopped the front off the gearbox & the front bearing is now located in the plate not the box, thats why there a bugger to fit to anything else. Hope that helps.
Site sponser has the odd T3 come in now & again he may be able to find you a T3 box.
CAUTION!
