Old 22-08-2006, 08:32 PM   #1
FORDEBV8
E-Series
FORDEBV8's Avatar
Default One side is sitting lower that the outher side :(
well as the title says 1 is siting lower on 1 side. all i did was change the caster arm because is was bent put the car of the jack and now the car is sitting lower dose any 1 no way?
EBTS50 NOW WITH A UNICHIP 140RWKW THANKS TO BOG :eclipsee_
http://tinypic.com/14v6afr.jpg
FORDEBV8 is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2006, 12:07 PM   #2
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
How did the radius rod get bent? If it's from impact damage there's a pretty good chance the LCA, spindle, K-frame, chassis, inner guards etc etc are bent. If you tightened the suspension bolts up with the wheel hanging in the air, this could cause it, as well as having a swaybar not connected properly.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2006, 12:11 PM   #3
FORDEBV8
E-Series
FORDEBV8's Avatar
ok thanks for that it not bothering me any more it dosnt scrape or any thingumm i got a wheel agilnment to day and there trying to say that the lower balljoints r gone, needs R/H rack end, for some reasion he said only 1 side had a camber kit when i had both side fitted, and a re alignment
Old 23-08-2006, 02:25 PM   #4
RavenLS1
How Much Lower????
405rwhp LS1, FG XR6T Ute manual, VE series 2 Omega LPG.
RavenLS1 is offline   Reply With Quote Multi-Quote with this Post
