Old 22-08-2006, 10:04 PM   #1
AU3 HERROD XR8
XR8 M8
AU3 HERROD XR8's Avatar
Default just some and specs of your pride&joy, so we get to know what everyone is driving :)
Hey guys, i thought that it woud be great to get to know what everybody is driving and what there packing..!
so just basically write in some details and mods of your ride and what it/she whatever you might call them, is packing..
AU3 HERROD XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2006, 10:13 PM   #2
Smoked
Burnin Rubber
Smoked's Avatar
Check out the Show Us Ya AU thread in Show N Shine, has got just about everyones ride and details of it.
2001 AUII Forte (LPG)
K&N Air Filter
Tickford Air Intake
***Coming Soon: Clear Side Repeaters***
Originally Posted by The-ShowStoPPa
...dont get me wrong this 3.8v6 is pretty special, it does come with the popular shake rattle and roll option and the auto compliments this with the ever popular snap crackle and pop feature
Smoked is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2006, 10:17 PM   #3
Dark Horse
_Oo===oO_
Dark Horse's Avatar
Yeah either that or aufalcon.com
Dark Horse is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2006, 10:18 PM   #4
AU3 HERROD XR8
XR8 M8
oh thanks mate, hehe missed it so i made one for myself
cheers.
Old 22-08-2006, 10:18 PM   #5
b2tf
not here much anymore
b2tf's Avatar
see sig......
2024 F150 XLT
Old 22-08-2006, 10:18 PM   #6
onfire
onfire's Avatar
Model : AU Forte
Year : 1999
Engine : 4.0l i6
Trans : Auto
Colour : Oxford Green
KMs : 79,8XX kms
Wheels : 17x8.5" Speedy Spyders
Tyres : Hancook
Suspension : King Spring Superlows, GT Shocks.
Exhaust : Standard
Induction : Tickford Snorkel ( For Sale only $90.. come on! )
Extras : Clear Tail Lights
Stereo :
- Sony Xplod MP3 HeadUnit
- Xpold 12" Sub
- Xplod 250watt Amp
- Sony enclosure
FOR SALE: 2 0 0 3 F A L C O N X R 8
http://www.fordforums.com.au/showthr...31#post5041431
onfire is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2006, 10:19 PM   #7
Casper
Contributing Member
Casper's Avatar
http://www.fordforums.com.au/forumdisplay.php?f=135
AU workshop builds area.. for everything you may want to know.
Older, wiser, poorer.
Old 22-08-2006, 10:21 PM   #8
HLC
Audi S3
see my thread in the workshop builds section :P
Old 22-08-2006, 10:23 PM   #9
MRJUCY
Fordless
MRJUCY's Avatar
<------------ I drive that car.
MRJUCY is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2006, 12:38 AM   #10
jimt3te50
My kids think I'm cool
jimt3te50's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Jim has consistently for some time now shared his life, and his passions in his XY GT and more so his FG GT in a way so everyone here feels part of the journey, which helps make AFF such a worthwhile place to be.  An outstanding contributor in my book.
I've missed a fair bit of documenting enough of the process to do a project car thread but have a fairly extensive thread specifically on the engine here http://www.fordforums.com.au/showthread.php?t=32600
Basically, in short this is what is done to the engine
AFR 185cc Alloy heads- 60cc chambers, modified pedestals for stud mount rocker gear
Comp Cams XFI 5.0 Stroker hydraulic roller camshaft- 236/248 @ .050", 286/300 total, .579"/.579" lift
Yella Terra 1.6 ratio adjustable Aluminium Roller Rockers
Full ARP Head, rocker and main studs
Full Felpro gasket set
Isky adjustable guideplates
Trend hardened chrom-moly pushrods
Crane double valve springs
Crane hydraulic lifters
ACL Race series rings and bearings
Rollmaster double row timing chain with nitrided gears
Stock T3 302W roller block- factory bored .020" oversize, torque plate honed
Stock T3 ACL Hypeurtectic pistons, dished and notched (9.7cc)
Stock T3 Argo shotpeened billet rods
Stock T3 Tickford nodular iron stroker crankshaft
Stock T3 Intake manifold
Stock T3 82mm throttle body and 80mm F150 Lightning MAF
Stock T3 laser cut main girdle
Stock T3 oil pump and sump
Stock T3 fuel pump and fuel lines
Bosch 43Lb injectors
MSD DIS4-High Output ignition system, Eagle Eliminator 8.0mm leads with Kevlar boots, MSD Coil Packs
Modified Cold Air Intake and K&N Pod Filter
Difilippo 4 into 1 ceramic coated s/steel extractors, twin hi-flow 3" s/s cats, twin 3" stainless steel all the way with X pipe, lukey Race mufflers and twin rear resonators
AU Edit- extensively tuned
345cu in (.020" over standard bore with stroker crank)
10.27:1 Compression Ratio
398.6whp (297.3rwkw) @ 6,000rpm and a ton of torque
Video of the Dyno Comp run on sunday here (3rd outright!)
Other mods are
  • Herrod SureShift short throw shifter
  • Lovells lowered progressive rate coil springs all round
  • Enkei RPO3 18x8.5" front wheels with 255/35R18 tyres and 18x9.5" rear with 275/35R18
  • Eclipse 8454 Head Unit, Alpine DDDrive front splits, Kicker Comp 5x7" rear splits, Kicker L7 Solo Baric sub in wheel well enclosure, Alpine V12 4 channel amp and Kicker DX350 monoblock amp
Ride height and wheels
And of course the stripes.......
In car pic
Idling video here
Outside car video here
And that's pretty much a summary of my entire contribution to the forum!
Phew, maybe there was enough for a project car thread after all LOL
2011 FPV GT 335 >My Build Thread<
(Posts 3511-3515 has a compilation of most of the pics, page 118 @ 30 posts per page)
BLUESTREAK built 5.2L flat-plane-crank VOODOO with 3.2L Intercooled Kenne Bell blower, 1000rwhp/746rwkw @ 8000rpm @ 20psi on E85. Built ZF with BLUESTREAK 2C Circle D converter. Unbloodybelievable...
2018 Ford Ranger RAPTOR
2013 Audi SQ5
jimt3te50 is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2006, 04:48 PM   #11
AU3 HERROD XR8
XR8 M8
jimt3te50, mate that car is absolutely GORGEOUS
Old 23-08-2006, 04:59 PM   #12
jimt3te50
jimt3te50's Avatar
awwww, shucks, really? thanks buddy!
The wife told me she's contemplating taking a restraining order out on me against my car- can't go within 50m of it she reckons :
I love that it's appreciated by other people and that's why (like others) I've tried to include as much as I can and not be secretive with anything- just want to share what I've found and have others enjoy my car as well- I love it and thanks for the thumbs up!
I'm loving the venom XR too BTW- wish I'd had the finances to keep my 220 XR8, I loved that car. The wheels look great, suit it down to the ground.
2013 Audi SQ5
Old 23-08-2006, 08:49 PM   #13
FTE217
T3/Sprint8
FTE217's Avatar
Show off Jim LOL......
Tickfords T3/TS50 '02
Sprint8 manual Sept 24 '16
Daily Macan GTS
"Don't believe everything you read on the internet. Abraham Lincoln"
FTE217 is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2006, 08:53 PM   #14
jimt3te50
jimt3te50's Avatar
any chance I get Maurie no harm in being proud of your car mate :P
2013 Audi SQ5
Old 23-08-2006, 09:01 PM   #15
FTE217
T3/Sprint8
FTE217's Avatar
I hear ya mate ! I feel the same with my mear stocky T3 YEEEHA....
Daily Macan GTS
Old 23-08-2006, 09:59 PM   #16
mik
mik's Avatar
awesome machine jimt3te50, sounds bloody grouse to boot......get a woody just listening to it.
Old 23-08-2006, 10:36 PM   #17
GlennBA
GlennBA's Avatar
Heres mine, not as good as Jims... :(
I love it anyways!
AUII Forte
Auto 6cyl (manual soon hopefully..)
Momo Steering wheel + gear shift
Sony HU
2.5"catback
Monroe GT's and kings superlows
AWC Tickford series 2/3 kit
19" wide pack Impuls
Body colour side moulds and mirrors
DBA slotteds
C2R grill
Going to do a car alarm next, black headlight bezels and some subs.
GlennBA is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2006, 10:41 PM   #18
xr8ute
Back on the road
xr8ute's Avatar
Im a big fan of those rims GlennAUII...I wonder what they would look like on a black ute?
Old 23-08-2006, 10:42 PM   #19
jimt3te50
jimt3te50's Avatar
Alot better than the car I had when I was 18 that's for damn sure! LOL
Looks the business now Glenn, love seeing the transformation of some of these cars, it's a real credit to you fellas.
Looks great Glenn- the colored bezels will look trick, even the colour coded ones would look great on that colour. Was always a HUGE fan of the T1 with the sparkling burgundy with colored bezels- even thought of getting another set of headlights and going blueprint on mine for a while.......
Love the wheels- they were worth the wait hey?
2013 Audi SQ5
Old 24-08-2006, 04:03 PM   #20
GlennBA
GlennBA's Avatar
Nah they'd look crap, don't bother buying them.. :Up_to_som
Old 24-08-2006, 04:04 PM   #21
GlennBA
GlennBA's Avatar
Thanks man,
I am probly gonna go black to break the colour up a bit, and i could do it myself this way. The rims were worth the wait but they look heaps better now its dropped a couple of inches.
Old 24-08-2006, 04:48 PM   #22
xr8ute
Back on the road
xr8ute's Avatar
LOL...dont worry...I dont think they would suit my 4WD ride height.
And anyway, I'm too much of a tight-**** to spend money on bling. I still regret the $10 I wasted changing the orange indicator lenses for clear ones. They didn't make me go any faster at all :P
Old 24-08-2006, 04:57 PM   #23
I6corp
Was V6corp
I6corp's Avatar
LOL iv'e still got to do that :
Car: 99 AU I Forte Sedan
Colour: Blue
Engine Mods: K&N Pod in a XR8 Pod Box; Performace fuel pump; 2 1/2" Exhaust
Planned Engine Mods: ; Extractors; Tickford CAI; Twin Mufflers; Shift Kit; Hi-Stall; Cam; ECU Flash
Bling Mods: Tinted Windows; JVC CD/DVD HU
Planned Bling Mods: TS50 Front; High Series bonnet; Rebel Skirts and Rear Bar; SL Springs; Clear Side Indicators; Rear Spolier; Mags
I6corp is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2006, 05:00 PM   #24
AU3 HERROD XR8
XR8 M8
I love glennauii's rims if they were a couple of inches bigger, wat inch size is your rims. Also i'm not a big fan on that custom grill, i've seen them a couple of times, i reckon jimt3te50's grill would suite glennauii's ride better
cheers.
The King of the jungle doesn't whistle.. he roars!
Old 24-08-2006, 05:10 PM   #25
b2tf
b2tf's Avatar
AU3 HERROD XR8, Im wondering your sig is wrong. Says you have a 5.4 engine in an AU?
2024 F150 XLT
Old 24-08-2006, 05:14 PM   #26
AU3 HERROD XR8
XR8 M8
Nah, it's a 5.4L no mistake
Old 24-08-2006, 05:15 PM   #27
AU3 HERROD XR8
XR8 M8
BTW, can somebody tell me who you do that quote thing, i'm sick of copy and pasting and doing that line underneather
Old 24-08-2006, 05:18 PM   #28
LG
LG's Avatar
Just hit quote underneath their post (on the right) ;)
Old 24-08-2006, 05:19 PM   #29
AU3 HERROD XR8
XR8 M8
like this, thanks mate
Old 24-08-2006, 05:23 PM   #30
bodes-sh
cheers.
if i'm not mistaken that 'custom' grille is the c2r grill isn't it? or at least the one that came with the c2r kit?
