Old 24-08-2006, 10:39 PM   #1
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
Default tapping
i have a tapping sound comming from my engin, im thinking its the tapets, some one told me that i should just get a rocker arm off a ef, will that fit and will it solve the sound, any gains rather then getting one off a ED
cheers
VE SS Ute manual 09
AU XR8 UTE 200KW manual 02
Challanger Ski boat V8 01
125 Thumpster 2010
Swag
All set for the weekend
eb91xr6 is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2006, 10:40 PM   #2
RG
Back to Le Frenchy
RG's Avatar
They all bloody tap, noisy bastards. Just replace the lifters.
Old 24-08-2006, 10:47 PM   #3
ROOSTA
DFDFDF
ROOSTA's Avatar
EF rocker arm will on ly make a difference to your wallet mate.. have you changed the cam in the car?.. if so then you my need shims.. if not then replace all the lifters.. a new set will cost ya round $150 - $200.. don't just try to find the one or two faulty ones as experience shows you will chase it all round the rocker assembly..
That being said i have replaced my lifters 3 times and they still tick.. Good luck with it..
Cheers,
Nik
ROOSTA is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2006, 10:56 PM   #4
EB Pete
EB Pete's Avatar
Location: Under the bonnet, trying to keep as clean as above!
the old tappets hey? love that name. if it is the hydraulic lifters go to repco not ford. get a some but make sure they are the same as the original ones. repco have 2 types i'll see if i can dig up a pic of em. i'm pretty sure the darker ones are the ones you want.
EB Pete is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2006, 10:56 PM   #5
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
yer i put a crow cam in and yer i think it upset them
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 24-08-2006, 11:00 PM   #6
ROOSTA
DFDFDF
ROOSTA's Avatar
Shim away mate.. start with small ones if you need some i get mine custom made.. depending on thickness.. i am running 3.2mm now and it still ticks away like a mo fo..
1.2mm would prob be a good start.. before you go replacing the expensive lifters..
Cheers,
Nik
Old 24-08-2006, 11:04 PM   #7
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
isnt it the idea of a billet cam to not need shims
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 24-08-2006, 11:09 PM   #8
ROOSTA
DFDFDF
ROOSTA's Avatar
Maybe..
I just making suggestions from my experience..
Cheers,
Nik
Old 24-08-2006, 11:17 PM   #9
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
would changing it to a el rocker arm do anything at all like my mate said to do
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 24-08-2006, 11:25 PM   #10
ROOSTA
DFDFDF
ROOSTA's Avatar
Maybe changing the whole rocker assembly but not jus one arm.. there are 12 arms in there after all.. May help.. i doubt it though as i think the Eb-ED was same as EF-EL..
Cheers,
Nik
Old 24-08-2006, 11:29 PM   #11
EDXR6T
EA-EBII were diffrent to late ED-EL
EDXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2006, 11:30 PM   #12
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
sorry thats what i ment as in the whole assembly would it help worth a shot
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 24-08-2006, 11:31 PM   #13
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
EDXR6T the question will it fit and is it different in power or anything like that
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 25-08-2006, 12:25 AM   #14
EDXR6T
wouldent no if they would give you any power upgrade they do look better
but yes they will fit you'r head bar late EL setup
i was wondering how do you bleed(probably not right terminology) the new liffter's before you throw them back in the roller rocker's? just drop them in a tin of oil.?
Old 25-08-2006, 01:21 PM   #15
V8 Ghia
Formally ED I6
V8 Ghia's Avatar
The ED-EL rocker assembly is stronger than an EA-EB it has metal washers on both sides of the rocker arms where the earlier models wore out. I recently changed the rocker assembly (off an EL) in my EA and the harsh ticking that was there for about 5minutes after startup is completly gone.
Push a screwdriver inside the lifter and hold it upwards to drain out about 2 or 3 drops of oil.
Daily driver
98' AU 349ci Fairmont Ghia on LPG
Other
93' ED 5spd 4.0L NA Fairmont
13.75 @ 101mph
V8 Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2006, 06:00 PM   #16
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
thank you ED_I6
VE SS Ute manual 09
125 Thumpster 2010
Swag
