Old 10-09-2006, 06:56 PM   #1
S3SR
S3SR's Avatar
Default Bosch wiper blades
just installed these today and all i can say is im converted... absolutely love them, the washer pump makes more noise, the aircon makes more noise and i even tested them on a dry windscreen where the other aunger ones would squeek and youd be deaf
anyways i got the metal insert ones (pain in the ar5e to install) as it doesnt use a clip it use piece of metal to expand inside the rubber and make a tight fit. only $13.95 for them and $9.95 for the aunger well worth my money
also flushed coolant and replaced with green this time to compare the dif...only improvement so far is the car feels smoother
checked some prices on bosch leads and spark plugs and well thats gonna be next pay..dont which ones to go with, super 4?, platinum (with ytterium), iridium (wasnt on their website)
anyways BUY bosch you'll be glad you did
My Cars:
2002 Ford Falcon AU S3 SR
2006 BF MKI Falcon XR6
2008 Mazda BT50 SDX
2004 BA XR8 ute
2006 AUDI A4 B7
2013 FG II XR6 Ute
2006 Ford Territory TX
2003 Ford Falcon XR8
2009 Territory Turbo Ghia
Current: 2012 Audi A4 B8 2.0T Quattro
S3SR is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2006, 06:58 PM   #2
HLC
Audi S3
they arnt the red wiper blades are they? im due for a set. mine are rooted.
Old 10-09-2006, 07:09 PM   #3
S3SR
S3SR's Avatar
not sure mine are black
heres some links to picies
http://www.bosch.com.au/content/lang..._Brochure2.pdf
http://www.bosch.com.au/content/lang...l_Brochure.pdf
My Cars:
2008 Mazda BT50 SDX
2004 BA XR8 ute
2006 AUDI A4 B7
2013 FG II XR6 Ute
Old 10-09-2006, 07:17 PM   #4
The Dok
The Dok's Avatar
This raises an interesting point. Some time ago, I was told to only buy the rubber inserts (with the metal strips), @$15 from Ford. The plastic backed type are too rigid & skip (hence the squeal). Try running your hand down the AU windscreen, @the centre you should feel a "valley" in the glass, in my experience, anything but the rubber type seem to miss this "valley" & never appeared to do a neat job. Personally, I would never go back to the aftermarket type.
Can't recall if they made my air-con & washers louder though :
Removed by laminge
The Dok is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2006, 07:24 PM   #5
HLC
Audi S3
i dunno, my stock standard ford ones are pretty crap. have always squealed/squeaked/made that horrible horrible noise.
Old 10-09-2006, 07:36 PM   #6
S3SR
S3SR's Avatar
had the aunger ones for a while and that plastic just snapped off during heavy rain on the way to work so thought id try a different brand......well let yous know when i replace them next year.
also anyone have/had bosch plugs and leads installed? where they an improvement?
My Cars:
2008 Mazda BT50 SDX
2004 BA XR8 ute
2006 AUDI A4 B7
2013 FG II XR6 Ute
Old 10-09-2006, 07:59 PM   #7
Paxton
Cobblers!
Paxton's Avatar
I put Tyco ones in the Territory, and they have been fine for the last few days (we have had more rain in the last four days, than in the preceding month). I always do the cartridge, not just the rubber, as I stuffed the windscreen in my EF because of them.
I would have bought Bosch, however Repco didn't have them.
Ego BFII Ghia
Titanium Silver E53 X5 4.4i
Gunmetal EF XR6. Now retired from active duty.
Roses are red. Violets are blue. OS X rocks. Homage to you.
Paxton is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2006, 08:03 PM   #8
HLC
Audi S3
greenrob off here put bosch leads in his car- not sure if he did plugs as well. said it got rid of the miss he had.
Old 10-09-2006, 08:11 PM   #9
blackers10
blackers10's Avatar
i have NGK plugs and Bosch leads and it got rid of the breaking down lead problems that i was having (replaced the motocraft items that were on the car)
work fine for me
have used all the bosch gear previously and its definatly a good buy!
Old 10-09-2006, 08:21 PM   #10
Dezza
Parts bin special
Dezza's Avatar
I'm well overdue for new wiperblades as well. Mine just smear way too much, and it does a pathetic job of getting water off the windscreen.
Old 10-09-2006, 08:24 PM   #11
jimmy_c
jimmy_c's Avatar
I had those bosch leads and super 4 sparkies in the EB. No problems. The wiper blades are good too.
jimmy_c is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2006, 08:33 PM   #12
Ozfords
Girls! Drink! ****! ****!
Ozfords's Avatar
I got the silicone ones from Aunger once and was suprised at the racket they make on semi-wet windscreens, horrendous racket! For some reason I'm of the opinion that they have added more webbing to the windscreen.
So I went to Autone and got the regular rubber ones, I think Trico, the fella behind the counter said its the one used by the vehicle manufacturers.
What can I say? It leaves a puddle type thing on the lower portion of the screen and leaves a very thin film of water on the screen, which is just annoying. The silicone ones worked a treat the in the rain, but caused an embarresing racket in the semi wet and I think they webbed up the screen.
Automatic Driver and I'd be proud of that fact, only if I weren't so lazy.
1993 ED Fairmont Sedan - I6 - Colbalt Blue
- XH Snorkel
- Superlow Kings Springs and KYB Shocks
- Cross Drilled and Slotted DBA front Discs
- 18" pre-AU GT-P Alloy Wheels
- Ford Original Bootlid Spoiler
Ozfords is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2006, 08:35 PM   #13
sarrge2001
SZII in Silhouette
sarrge2001's Avatar
The Bosch wiper blades are excellent - AND they last longer than 2 weeks until they smear...........
sarrge2001 is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2006, 08:57 PM   #14
LowEL2XR8
Mr Impulsive
LowEL2XR8's Avatar
I dont have any problem with wiper blades. I use Rain X to compliment the wipers.
I only use wipers for light rain when the drops are to small to run up the windscreen.
Heavy rain and the Rain X does all the work.
Owned Fords
85 Telstar (man), 96 EF GLi (auto), 95 EF XR6 (man), 97 EL Fairmont Ghia (auto), 98 EL XR8 (man), 06 BF wagon (auto), 06 BF XR6 (ZF auto), 08 FG G6E (ZF auto), '10 SY MKII TS Territory (4spd)
LowEL2XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2006, 09:03 PM   #15
Paxton
Cobblers!
Paxton's Avatar
I have Rain X, and have discovered that you have to be Travelling at ?70 KM/H for it to start to sheet off the Windscreen, even when the application is fresh. YMMV (Your Mileage May Vary) however. I will just add that I have relied on Rain X only once, on the F3. I had lost the Wiper Inserts (that I mentioned in my above post), and it was pelting down. I made it back no sweat, however I had never been so scared in my whole life.
Ego BFII Ghia
Old 10-09-2006, 09:22 PM   #16
Silver Ghia
Silver Ghia's Avatar
I put on the Aunger rubber ones (inserts only) on a few weeks ago and they work really well. Much better than the originals that made a lot of noise jumping across the windscreen right from the start.
Bit worried about the plastic breaking though on the Aungers, that FalconSR mentioned.
Silver Ghia is offline   Reply With Quote Multi-Quote with this Post
