Old 19-09-2006, 02:07 PM   #1
poolkeeper
Its Resonating!
poolkeeper's Avatar
Default Blank keys off ebay??
Do they work? In the description, it says key can be cut by any locksmith/key cutter. But I doubt it. Anybody know the story bout getting another key made?
poolkeeper is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2006, 02:11 PM   #2
fiery
fiery's Avatar
I asked Ford about getting another key for my car and basically he said they are really hard to copy unless new..
Don't know how true that actually is (he was trying to get me to buy a complete new lock set for the car instead) though....
I personally wouldn't be buying any keys off of ebay..
Originally Posted by MNM96
Quit wingeing, drink more and grow a Butt! Its un Australian not to be the correct size to fit the seat of a Falcon!
fiery is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2006, 02:16 PM   #3
Sam_Boss260
Have Boost, will use it..
Sam_Boss260's Avatar
Well, when I bought my car, it only came with one set of keys.... So I had another key cut and programmed for my Ford dealer for around $170...
So I guess you can buy blank keys.
As far as complete lock sets, I'd be telling the dealer to go jump....
Sam_Boss260 is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2006, 02:18 PM   #4
Smoke Pursuit
If you have the key code they are easy to copy. its just a matter of re doing it, which Ford dealers have access to.
So if you go to the dealer with proof of ownership they should be able to make you a new key without having to replace barrells etc.
2022 RAM Laramie 5.7
2023.50 Ranger Wildtrak 3.0 V6 Premium Pack
2024 Everest Sport 3.0 V6 Touring Pack
2025 Mustang Darkhorse 6M Blue Ember + Appearance pack ETA April 25.
Smoke Pursuit is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2006, 02:34 PM   #5
Perana
Perana's Avatar
Most decent locksmiths can cut Tibbe keys... It's just a matter of either knowing the code or having a key to copy from.
Perana is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2006, 03:20 PM   #6
fiery
fiery's Avatar
The problem with mine was that I only had the one key and it was extremely well worn.... So was told by a Ford dealer (was on the southside of Brisbane) that they could not guarantee that the copy would work properly and that once it was cut then I had to pay (even if it did not work)..
Hence the pushing of buying the complete lock things for the car...
Needless to say, I did not buy any new locks for it and I am still using the old worn out key..
Old 19-09-2006, 03:51 PM   #7
Perana
Perana's Avatar
Some places actually "read" the cuts (there are 6 different depth cuts IIRC) on the key and cut the new one using a guide on the machine
Old 19-09-2006, 04:23 PM   #8
Zed7fiddy
Temporary Australian
Zed7fiddy's Avatar
Where was this mate??
Pacific ford wanted $250!!!!!!
i only have one key and would snap at the chance to get one a that price!
Zed7fiddy is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2006, 11:19 PM   #9
DTFRMONT
I had a quote for a new key, cut & coded, from my local Mr Minit (knox city) - they wanted $150.
DTFRMONT is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2006, 11:32 PM   #10
normxb
normxb's Avatar
Location: Sitting on the Dunny , Contemplating "What to do Next".
Can one of the guy's in Wagga check Riverina Safes & Locks in Berry St (6921-3517) . We got 2 spare keys for the wife's ED Fairmont cut there a couple of years ago (or are you talking a different model ? ), I'm probably VERY wrong , but I thought it was $30 or so each because we wouldn't have had much more cash than that on us (will check with the Mrs)..... The guy "Looked at the key" , wrote down the code ( 1 letter 6 numbers , I have their card in front of me) said come back in an hour , all keys work great.
I'm sure we asked at the local dealer & the guy in spares (who I know) told me if I was in Wagga anytime to go there because his were too dear.
XB Futura 302 , Wife ED Fairmont ,1994 Polynesian Green.
Daughter No 1 KJ Laser , Daughter No 2 KH Laser
Keeping FORDS in the family
(Embarressment :yeees: , Son now has a "Camira" : )
"Look Right , Look Left , Look Right , BEFORE crossing Roads"
normxb is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2006, 08:59 AM   #11
brendo83
Sorry forgive my ignorance, how do they code the keys, do the just stamp or engrave a number on the key?
Because $150 is damn expensive
for my EB I had two new keys cut from the old well worn one for under 30 bucks each.
Because it was so worn he cut the key, tried it in the lock, then took it back inside cut a little bit more, tried it again and it was perfect.
I went to the for dealer first and he sent me to this place cause he knew their prices sucked.
brendo83 is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2006, 09:26 AM   #12
pauljh74
pauljh74's Avatar
If you're talking about the EF XR6 in your avatar, all you would need is the key to be cut. I suppose if your key is worn, that could be a problem. I know I got a key copied for my EL at a locksmith and it works fine. I've heard the AU and later needs to be coded in a chip in a key along with the correct physical key.
It cost me $20 for a copy of my key for the EL. You'd think that Ford would be able to find the combination of the key and have one made up via information such as the VIN
Originally Posted by Mark Webber
Not bad for a #2 driver
Mark Webber after winning the 2010 British Grand Prix.
pauljh74 is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2006, 09:35 AM   #13
Perana
Perana's Avatar
EA2-->AU1 only need a key to be cut.. its about $25-30
AU1 Update onwards need a key to be cut and coded.. that is $150 odd
