Old 21-09-2006, 02:57 PM   #1
Robe
Default White and Black
It is time for a little cosmetic touching up around the edges - are all AUs the same version of white? What is it called?
And what is the shade of black on the pillars, and who makes it in affordable amounts?
Thanks
Rob Ewart
Bog standard silver BF Wagon, except for the Elvis doll , on gas.
Victorian Rock'n'Roll Dance Association
www.VRRDA.com.au
2015 Victorian Rock'n'Roll Dance State Championships
23 May 2015, Furlan Club, Thornbury
Robe is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2006, 03:02 PM   #2
mattp
mattp's Avatar
Try using the 'search' function, it works well...
This is from the Technical Resources section anyway, you'll have to check your paint code on the build plate under the bonnet, there's a few different ones.
Paint Codes for the AU Falcon (9/1998 to 10/2002)
Model Code Description Notes
AU A1 Winter White
AU B5 Sparkling Burgundy
AU B7 Barossa Red
AU BC Botannica
AU C2 Regency Red
AU DG Congo Green
AU3 E1 Light Satin Veil AU3
AU GY Galaxy Blue
AU H Dynamic White
AU HH Silver Birch
AU J8 Alaskan Frost
AU K6 Meteorite
AU L7 Cinnamon
AU LD Liquid Silver
AU M8 Mystic Blue
AU MN Monsoon Blue
AU NR Narooma Blue
AU O2 Organza
AU P4 Hot Chilli Red
AU S9 Sand Storm
AU ST Silhouette
AU T5 Oxford Green
AU3 UU Blueprint AU3
AU VF Venom Red
AU W6 Amoretto
mattp is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2006, 03:22 PM   #3
Abacus
Life's a Gas
Abacus's Avatar
As far as the whites go:
http://www.fordforums.com.au/showthr...ight=AU+Whites
In that thread:
Originally Posted by EvilChief
correct, colour code H (dynamic white) was carried over from the el series in the S1s. i think they stopped mid 99s and user winter white from then on (dont quote me)
So some early AUs come out in Dynamic White Code H, but most are Winter White code A1. I'm guessing you have a series 1, so it could be either.
Abacus is offline   Reply With Quote Multi-Quote with this Post
Old 22-09-2006, 08:39 AM   #4
Robe
Thanks for clearing that up. I was having a lot of trouble identifying the colour reference on the vehicle plates.
Now, any idea on the black bits? :voldar02:
Rob Ewart
www.VRRDA.com.au
Old 22-09-2006, 09:11 AM   #5
HLC
Audi S3
the black bits on the b-pillars are just black moulded plastic.
post pics of what you want to touch up.
Old 22-09-2006, 09:43 AM   #6
Abacus
Life's a Gas
Abacus's Avatar
He probably means the black paint on the upper part of the doors themselves.
I'd be interested to know about this - lots of little chips from rings etc.
Old 22-09-2006, 10:07 AM   #7
Robe
Sorry, I did mean the outside black paint.
It does look like rings, luggage, etc and maybe the seatbelt have chipped bits off the black paint on the edge of the pillar and there are white spots showing through.
I asked the guys at an Autobarn shop but they could find no references about the correct shade of black.
Getting off the thread, but still a pillar issue; inside there is a grey plastic cover trim over the seat belt upper mounting that also needs replacing. I have never seen this problem before but whoever had the car before me has managed to wear a groove in the plastic from pulling the belt out. It looks like another trip to the wreckers for me.
Rob Ewart
www.VRRDA.com.au
Old 22-09-2006, 12:32 PM   #8
Abacus
Life's a Gas
Abacus's Avatar
OK. I just visited my panel beater on an unrelated matter and he advises that the black bits can't really be touched up. They are, as HLC indicated, moulds. Moreover, they are powder coated aluminium moulds and if you try to paint the chipped bits it just breaks down the coating around the bit you've painted.
I've ordered a new one for the drivers door. Part number ERF20554A, cost $37.40 + GST.
Mine's a series 2 Ghia. you may want to check yours is the same part.
