Old 23-09-2006, 04:56 PM   #1
BFD83
BFD83's Avatar
Default tyre size question?
i am gonna be buying 18"s off my mate, he brought one of the wheels over and leant it against my existing tyre and said the size looks bigger then normal and not sure if it will fit and put my speedo out, the tyres i got atm are: BF GOODRICH 225/50 XR16 and the tyres im gonna be putting on are FALKEN 245/402 ZR18. does anyone know if it would put the speedo out or would it make no difference?
BFD83 is offline   Reply With Quote Multi-Quote with this Post
Old 23-09-2006, 05:21 PM   #2
ENVI XR6
ENVI XR6's Avatar
Nah they will be fine mate i had a set of 245/40/r18's on my au, doesnt set the spedo out at all
Ford Forever!
Lowndes Is No.1
ENVI XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 23-09-2006, 05:30 PM   #3
plext
Forum Director
plext's Avatar
Circumference of 225/50 16 is 1983.6, while 245/40 18 is 2052.1
This roughly represents a 3.5% change, which will show with the speedometer reading slightly under true speed. Not enough to get in a twist over though.
EDIT: Unless you happen to visit Victoria of course.
Last edited by plext; 23-09-2006 at 05:35 PM. Reason: Disclaimer for totalitarian speed detection devices
plext is offline   Reply With Quote Multi-Quote with this Post
Old 23-09-2006, 05:35 PM   #4
RG
Back to Le Frenchy
RG's Avatar
I've got 18's on mine (originals are 17's) and my speedo is out by 10k at 100.
Old 23-09-2006, 07:26 PM   #5
ORESUMSR
Legless Old Fart
ORESUMSR's Avatar
All the correct information that you require, can be found in the following link. Just scroll down (2/3?) till you get to a section called "Why would I want to change my rims and tyres anyway?" There you will find "A Tyre Size Calculator". You just have to insert the tyre sizes that you want to compare and it will automatically work out the difference in circumferences and speedo error, if any.
Luck and happy reading..
ORESUMSR is offline   Reply With Quote Multi-Quote with this Post
Old 24-09-2006, 04:30 PM   #6
BFD83
BFD83's Avatar
does anyone else know?
Old 24-09-2006, 04:49 PM   #7
lukey
www.lukehimself.net
lukey's Avatar
http://www.fordmods.com/forums/documents.php?doc=30
Subaru Liberty MY04 4GEN Luxury
www.lukehimself.net
lukey is offline   Reply With Quote Multi-Quote with this Post
Old 24-09-2006, 05:40 PM   #8
JC
JC's Avatar
Note sure why the correct info above is not enough, so here's some more:
Tire Size Comparison
Specification Sidewall Radius Diameter Circumference Revs/km Difference
225/50-16 112mm 316mm 631mm 1984mm 504 0.0%
245/40-18 98mm 327mm 653mm 2052mm 487 3.5%
When your speedo says 60, you will be travelling at 62.1 (but given that from factory it has between 5 and 10% error anyway, it more likely you will be travelling at 59 indstead of 57).
Even the factory option wheels end up being out by a little bit:
235/40-18 94mm 323mm 645mm 2027mm 493 2.2%
Speedo showing 60 is really travelling at 61.3.
5% is the acceptable difference, so either of these tyre choices are well within limits without needing to change your speedo gear.
When either the 235 or 245/40/18s are compared to 235/45/17, the difference is at most 1.5% (max 0.9km/h at 60 difference).
Ford Performance Club ACT
