Old 03-10-2006, 06:08 PM   #1
ClassicAU
Default Standard cat converter
Hi everyone, i am going to see if i can book my car in for a set of extractors and an exhaust tomorrow. now i have been told that the standard ford cat's do flow very well and there is no need for a 'high flow' replacement. I was just wondering if this is true? what have most people done when they change exhausts? cheers
ClassicAU is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2006, 06:39 PM   #2
poolkeeper
Its Resonating!
poolkeeper's Avatar
I went all out, everything......
poolkeeper is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2006, 06:43 PM   #3
JeffAU1
JeffAU1's Avatar
If you plan on doing more mods to your car then i would replace it
Seems to be most people say on a NA AU6 the current CAT would be fine.
:eclipsee_ MY CAR :eclipsee_
JeffAU1 is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2006, 06:46 PM   #4
ClassicAU
thanks guys. other than maybe an edit, thats all i am planing to do mechanically to the car for a while, if at all. so it will stay NA and just have the exhaust. the main reason i ask is that from what i know the cat is fairly expencive to replace.
Old 03-10-2006, 07:51 PM   #5
mattsAU1
mattsAU1's Avatar
Just got the standard cat in mine too and seems to do the trick and your right, i was quoted $300 for a high flow cat and couldn't justify the cash.
mattsAU1 is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2006, 08:23 PM   #6
jonbays
TL40 Wagon?
Its true you don't need to change the cat unless its stuffed.
Old 03-10-2006, 08:28 PM   #7
Baboon_AU
Baboon_AU's Avatar
normal cats are very pricey too.. all cats are
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2006, 10:56 PM   #8
Sleeperau
Highway Taxi
Default Rear of Cat
The outlet on the rear of the cat is is only 2.25 inches get them to change that to 2.5 inches. This is what Jim Mock Motorsport do to them. I had it done to mine when the sports exhaust went on.
Close only counts in Horse Shoes & Hand Grenades. :evil_laug
Sleeperau is offline   Reply With Quote Multi-Quote with this Post
