07-10-2006, 09:08 AM | #1 | ||
I am experiencing low cooling A/C ( 10 degrees ) due to no vacume at the heater control valve on the heater hose. This allows a mixture of hot/cold air when A/C is on.
I have closed the above valve using wire and the A/C temp goes down to 5//6 degrees. Where is the vacume on/off controlled from ? Should it be normally closed when everything is off ? Many thanks in anticipation. |
