Old 11-10-2006, 02:19 PM   #1
Noddy
Mercury Silver T3
Noddy's Avatar
Question laptop repairer Brisbane, recommendation
I have a dell laptop which i need to have looked at. Trying to find someone reputable.
thanks,
Matt
House of Tickford
T3 TS50 No.156
AUIII XR8 220
2017 Magnetic Mustang
What to hear a tuff T3?
Click here
http://s7.photobucket.com/albums/y30...ent=Movie2.mp4
Noddy is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2006, 02:59 PM   #2
EvilChief
Boost Addict
under warranty?
call dell and get nearest repair agent
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
Old 11-10-2006, 03:04 PM   #3
BlueRaven
Dual O2 sensors
BlueRaven's Avatar
Whats the problem with it?
Black 1990 300zx Twin Turbo 5 Speed Manual :
Blue 2004 Mini Cooper S 6 Speed Manual - Yes, thank you Amanda. I realise now that you updated my signature to include your car. :
BlueRaven is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2006, 06:27 PM   #4
Noddy
Mercury Silver T3
Noddy's Avatar
There is no warrenty left on it. It will not charge the battery and it also won't boot with just AC connected.
House of Tickford
T3 TS50 No.156
AUIII XR8 220
Click here
Old 11-10-2006, 06:32 PM   #5
pertuan
Focus on my Focus
1. Have you checked that the power pack/transformer is working? Sounds like a stupid question but I've had mates who had broken wires between the power pack and the plug into the lappy.
2. It could be the fuse in the lappy.
Now: 2006 Ford Focus LX Manual in Satin White
Wife: 2013 Kuga Titanium in Frozen White
Then: 1990 Ford Laser - Assasinated by a 76 year old man who failed to give way.
Now normally when we have these races, Jeremy goes in the car and says "Powerrr" alot.... - James speaking about Jeremy (Top Gear S7 E05)
American parts... Russian parts... ALL MADE IN TAIWAN! - Russian guy in Armegeddon
pertuan is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2006, 06:50 PM   #6
S3SR
S3SR's Avatar
there are fuses in computer these days? well user servicable ones?
if the battery wont charge and the comp wont turn on even when plugged in, check the power pack with a multimeter (any needle inside the pin and one on the outside, if theres no reading then thats stuffed) if there is a reading then its the 'power pin' inside the lappy itself, this happened to my sisters laptop and it will require a new motherboard ($600ish)
otherwise get a quote from someone else.
and test to see if the pin inside the lappy moves if so then the above is correct and its throw away unless under warranty.
goodluck
My Cars:
2002 Ford Falcon AU S3 SR
2006 BF MKI Falcon XR6
2008 Mazda BT50 SDX
2004 BA XR8 ute
2006 AUDI A4 B7
2013 FG II XR6 Ute
2006 Ford Territory TX
2003 Ford Falcon XR8
2009 Territory Turbo Ghia
Current: 2012 Audi A4 B8 2.0T Quattro
S3SR is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2006, 06:51 PM   #7
Noddy
Mercury Silver T3
Noddy's Avatar
Yes i have two power packs and both are showing the green light and the cables are not damaged in anyway.
I was thinking that where the power packs plug go's into the lappy in may be damaged there. More than likely its the power module on the motherboard thats stuffed, it is expensive and that would just be my luck atm. :(
House of Tickford
T3 TS50 No.156
AUIII XR8 220
Click here
Old 11-10-2006, 06:57 PM   #8
Noddy
Mercury Silver T3
Noddy's Avatar
goodluck
Yeah i think your on the money, i will check the power pack with a meter though.
The laptop is approx two and bit years old and owes me about $2300 so i will most likely get it repaired.
House of Tickford
T3 TS50 No.156
AUIII XR8 220
Click here
Old 11-10-2006, 07:00 PM   #9
atec77
thanks,
Matt
Run a meter over the pack and check for voltage on the input dc plug to the computer , if you cant work it out Pm me your number and I will walk you though som other stuff ,k ?
( Browns Plains here. )
Old 11-10-2006, 07:38 PM   #10
Noddy
Mercury Silver T3
Noddy's Avatar
I will try and get my hands on meter tomorrow to check this.
House of Tickford
T3 TS50 No.156
AUIII XR8 220
Click here
Old 11-10-2006, 07:50 PM   #11
05MkIIFutura
SV6000. Yum
05MkIIFutura's Avatar
Problem with computers these days (paticularly Dell's) is that they are cheaper to replace than bother fixing an old machine
05MkIIFutura is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2006, 07:52 PM   #12
BlueRaven
Dual O2 sensors
BlueRaven's Avatar
Is the jack in the laptop in good condition? I've had similar problems before with acers and found that wigglying the jack can sometimes work....then its a simple fact of soldering the jack again.
Old 11-10-2006, 07:57 PM   #13
S3SR
S3SR's Avatar
heres a tip dont buy Acer or DELL or optima or fujitsu, there specs might look 100x better than any toshiba, HP/compaq (they are better now) or Asus but they use cheap crap. if it dont work anymore and you still want your stuff someone should be able to make a backup of your stuff and burn it to a CD, or PM me ill give ya a hand
My Cars:
2008 Mazda BT50 SDX
2004 BA XR8 ute
2006 AUDI A4 B7
2013 FG II XR6 Ute
Old 11-10-2006, 08:06 PM   #14
the_scotsman
MY21.5 Mustang GT
the_scotsman's Avatar
I would say the opposite...but meh...we all have our own opinions...
Old 11-10-2006, 08:14 PM   #15
Noddy
Mercury Silver T3
Noddy's Avatar
True and thats the cherry when your looking at these types of laptops, price.
To be completely honest the unit has been dropped twice onto tiled floors and also had drinks spilt onto the keyboard on a couple of occasions too.
The specs it has can be bought now (from dell) for about $1400.
House of Tickford
T3 TS50 No.156
AUIII XR8 220
Click here
Old 11-10-2006, 08:16 PM   #16
Noddy
Mercury Silver T3
Noddy's Avatar
When the power plug is connected to the laptop there is quite a bit of movement from the jack, so it could be the problem.
Thanks for the input guys, much appreciated.
House of Tickford
T3 TS50 No.156
AUIII XR8 220
Click here
Old 11-10-2006, 09:37 PM   #17
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
Another problem with alot of older laptop motherboards / and some desktop motherboards , i have found a large majority of pc's not charging or even starting up these days (if its not the power pack ) / due to dodgy capacitors used on the motherboards , the laptops are real bad for this problem on the capacitors around the main cpu. Usually you can tell if they are suspect when they start buldging at the top and like a black crusty formation builds up on the top of them. If your carefull you can replace the capacitors yourself no worries ( just need a fine soldering iron and a magnifying glass ) , usually its the capacitors around 1000uf and above that start causingproblems as they get old. This problem can cause a dead pc and stop laptops from charging too ! . gl .
:eclipsee_
Old 11-10-2006, 10:17 PM   #18
BlueRaven
Dual O2 sensors
BlueRaven's Avatar
^^^^^^^^^^^^^^^ I agree with the above. We had over 50 desktops from Dell that used dodgy cheap capacitors and had to have their motherboards replaced.
