15-10-2006, 06:02 PM | #1 | ||
If your good at wiring sound systems i need your help
i have bought another amp just wandering how to wire it up and i have an amp already for my 2 subbys |
15-10-2006, 06:14 PM | #2 | ||
V8 Ute V8 Boat
its not difficult
red- battery brown/black-ground blue-remote RCA-RCA not too difficult just need to get the battery wire to the boot i drilleed through my fire wall
VE SS Ute manual 09 AU XR8 UTE 200KW manual 02 Challanger Ski boat V8 01 125 Thumpster 2010 Swag All set for the weekend |
15-10-2006, 06:21 PM | #3 | ||
the rca is the problem my other amp already takes up the 2 rca termanials on the back of the headunit
15-10-2006, 07:10 PM | #4 | ||
I've got the same problem mate, i'll be taking mine to Jb and getting them to install it.
15-10-2006, 07:17 PM | #5 | ||
rofl copter
u need double adapters, and u just use them at the amp side
GQ patrol.
.... thats all |
15-10-2006, 07:28 PM | #6 | ||
so just use split them at the headunit?
15-10-2006, 07:35 PM | #7 | ||
15-10-2006, 08:33 PM | #8 | ||
Hmmmmm
split them at the amp
15-10-2006, 10:05 PM | #9 | ||
V8 Ute V8 Boat
i have 2 amps and a 2 year old pioneer head unit with 1 rca and i just used a spliter
15-10-2006, 10:16 PM | #10 | ||
EBII XR6
does it make any difference if theres 1 rca output compared to 2 or 3?
DEVLXR
15-10-2006, 10:36 PM | #11 | ||
V8 Ute V8 Boat
from what im told that the rca is somthing from 3 to 5 volt and when u split it, they half the voltage but i didnt notice a rats dicks difference
15-10-2006, 10:48 PM | #12 | ||
If ur amp has RCA out..use them..i think they call it daisy chaining! lol
BA XR6 TURBO - SILVER & 1970 Mustang Coupe
15-10-2006, 10:53 PM | #13 | |||
Tuned @ Pitlane Frankston
Although, not recommended for a high end system. If you want a high end system, you need a headunit with 2 x RCA out, and Subwoofer out. 3 amps, one for the front split speakers, one for the rear speakers, and a mono block for the sub. Or you can run one 4 channel for fronts and back. Splitting RCA's is ok to an extent. On a small system, it'll work fine.
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
15-10-2006, 11:34 PM | #14 | ||
Smash the Boost
Only thing about splitting is u lose fader control from the H/U. You will have to do it utilising your gains on your amps.
2023 Hyundai Palisade 1971 Fairmont Sedan 1974 SWB F100 Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
