Old 24-10-2006, 08:27 PM   #1
slayer351
slayer351's Avatar
Default Old351 clevo into EB sedan?
Hi guys, was wondering if it is legal to fit a old 351 clevo into a eb sedan in queensland?
Any help with this would be great.
Thanks.
slayer351 is offline   Reply With Quote Multi-Quote with this Post
Old 24-10-2006, 08:49 PM   #2
RegSpec
RegSpec's Avatar
I was filling up at a servo in Beenleigh one night and the guy at the pump beside me pulls in and we start talking about his EB with a 351C in it.
Can be done,seen it with my own eyes,he reckons it was all legal too but only if you run LPG.
Best to check with QLD Transport.
06' BF XR6T manual sedan in Bionic Blue.....written off 08/15......greatly missed...
New ride....07' RSpec manual Typhoon in Winter White....factory sunroof, Premium sound, Process West intercooler, upsized tubing, valve springs, 1000cc injectors, Delphi intank pump,*modified turbo, 4" dump, 5" cat, dual 2 1/2" Xforce exhaust, Mal Wood Opt 5 clutch, Herrod shifter, Ozrace coilovers with adj. Whiteline bars, 6 spot Brembos,
Edit by Crescent Motorsport.....382rwkws @ 1150nms on E85....
RegSpec is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2006, 12:42 AM   #3
SPK-250
SPK-250's Avatar
I think it can be done if you retain all original emmision equipment from engine and run cat convertors.
What would forum's be without post whoring know it all's.........
SPK-250 is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2006, 01:08 AM   #4
LUXO_8
windsor user
send a pm to eav8 on the forums...... he's just fitted a 351 clevo on gas into an EA
thread here
http://www.fordforums.com.au/showthread.php?t=22872
Old 25-10-2006, 08:00 AM   #5
slayer351
slayer351's Avatar
Thanks guys, I will look into it a little more now that i know it can be done.
Old 25-10-2006, 08:06 PM   #6
16wantsI6
iRegular crossmember
16wantsI6's Avatar
mmmhmm sounds like a plan, would be better tha those clogged up fuel injected windsors
1996 EF XR6
5 spd manual
2 1/2" manta S/S exhaust
After market alpine/soundstream stereo
18" tyhpoons
superlows waiting to go in....
spoilerless
16wantsI6 is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2006, 08:20 PM   #7
LUXO_8
windsor user
hahahaha......i'll line you up with my "clogged up" fuel injected windsor
Old 05-11-2006, 07:37 PM   #8
tamara1779
It is not legal to put a 351 in an EB in Qld. I spoke to local mechanic who is also approval guy for mods. I put a 351 in an Ea to race speedway. He thought I wanted to street it. If you do find someone to legalise. You will need to use the newer smaller starter motor as well as modifying extractor. Nuckle in steering gets in the way. Hope you have some luck..
tamara1779 is offline   Reply With Quote Multi-Quote with this Post
Old 05-11-2006, 08:53 PM   #9
Steffo
LPG > You
Steffo's Avatar
Definitley... better at slowing you down. :
Old 06-11-2006, 01:25 AM   #10
[Tonko]
What's green is gold
[Tonko]'s Avatar
they are called clevosaurus's for a reason matey, i went from 351 to 5.0 windsor and apart from the sound, they should stay extinct
EF XR8 - Koni's - Cam and Headwork -3.9s - Ex VIC TMU -
1982 Nissan Patrol - 460 ci Big Block soon - Semi Gloss Black - Dark Tint - 4x 6" Infinity Kappa Perfect Splits - 5" Kappa 2 ways - Kappa 6x9's - 2x12" Kappa perfect subs - 2x4 Channel and 2x Mono Kappa amps-
[Tonko] is offline   Reply With Quote Multi-Quote with this Post
