Old 08-04-2005, 10:43 PM   #1
sphell
sphell's Avatar
Default help with microfueller
posting this on behalf of sunny cause he can't log in for some reason...
he has decided to buy a microfueller to control an extra injector for the turbo. He was wondering how this particular microfueller would be adjusted:
would there be a dial on the other side of the case that you could increase/decrease the fuel delivery?
Also how effective are these things for a low boost (less than 10psi) setup?
Old 08-04-2005, 10:55 PM   #2
needfordspeed
There's a screw on the side which you can adjust.
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH
needfordspeed is offline   Reply With Quote Multi-Quote with this Post
Old 08-04-2005, 10:57 PM   #3
sphell
sphell's Avatar
i saw that but thought it was just holding the case! cheers knackers.
Old 08-04-2005, 10:59 PM   #4
needfordspeed
Nah not that one! there's another one on the side.
Old 08-04-2005, 11:00 PM   #5
Damo
lol.
Sik. Will it be boosting on monday ?
Old 08-04-2005, 11:01 PM   #6
needfordspeed
The guy just sent an email back :P
Old 08-04-2005, 11:02 PM   #7
sphell
sphell's Avatar
it's boosting now..but melting wires in the process Gotta get some heat sheilding sorted. Hopefully this thing will make a big improvement. I just bought a wideband AF meter for tuning purposes so we can use that to get the mixture right....can't wait
Old 08-04-2005, 11:03 PM   #8
sphell
sphell's Avatar
how much is it gilly?
