Old 04-11-2006, 03:51 PM   #1
napoleon
20 years of driving....
Default Stuggle to accelerate
Hi Guys, I have looked thru the forums but can't seem to find a similar problem.
I just bought a AUI Falcon and it has problems accelerating on the road. It does 0 to 60 in like a minute. It has no problem idling and revs very well in neutral, just very bad acceleration under load on the road. I have replaced the leads and plugs, cleaned the ISC, and reset the computer.
Anyone got any ideas as I am stuck for ideas now.
napoleon is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2006, 03:54 PM   #2
LG
LG's Avatar
How many kms have you done? Is this your TL50, or a Falcon 6 cyl?
Could be an oxy sensor problem?
Old 04-11-2006, 04:05 PM   #3
napoleon
The car has done 183000kms (service sticker reads 190000 for next service), and this is not my TL (sif I'd have problems with that...) but a Falcon I bought for the wife.
Old 04-11-2006, 05:51 PM   #4
Stav
Smile
Stav's Avatar
Frayed accelerator cable?
Old 04-11-2006, 05:57 PM   #5
TURBOTAXI
Turbo Falcon Fiend
TURBOTAXI's Avatar
Fuel pump, fuel filter, ECU (at a stretch)
Start with the simple stuff.
Spark
Air
Fuel
If you can eliminate those then its likely to be something electrical.
Does the car drive an different NOW to when you TEST drove it before buying?
If so, how many k's have passed since you bought it?
The service sticker probably only relates to oil and filter - so everything else is anyones guess.
Might be a silly question - but is it dual fuel?
Just a few.
TURBOTAXI is offline   Reply With Quote Multi-Quote with this Post
Old 05-11-2006, 08:55 AM   #6
Chippar
The Ancient Warrior
Chippar's Avatar
Stuffed cat converter.
Blocked or crushed exhaust.
Badly adjusted throttle cable.
Handbrake partially locked on.
Chippar is offline   Reply With Quote Multi-Quote with this Post
Old 05-11-2006, 08:25 PM   #7
CATFORD
SCALDED CAT
CATFORD's Avatar
If its an auto....may be it worth giving the box a service once you have done every think mentioned above....good luck mate!!!
"THE CAT IS BACK"
CATFORD is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2006, 08:48 PM   #8
napoleon
Thanks for your help.
Took it to the Mechanics, put his computer on it. Had to replace Coil Pack and it was split in 3 places, a sensor off the manifold as it was not working at all, fuel filter the old one had never been replaced since new, and the fuel pump.
All sweet now. Now for roadworthy and look at stereo's to put in it.
Old 08-11-2006, 10:03 PM   #9
mik
mik's Avatar
thats good usage out of the fuel filter it supposed to be changed at 100,000
