www.TUFFCARPARTS.com
Hi All,
Thought I'd be nice this morning and give the AU an early oil and filter change. Unfortunately though the sump plug must have been over tightened when it had it's last service, and now I've rounded the bloody thing trying to get it off! Obviously a new sump plug is a given, but how on earth do I get the old one off? Thanks, Justin. |
try vise grips, or even a hammer an chisel, ive had to get AU transmission filler plugs undone using a hammer and chisel from people over tightening them and rounding them off
FTF Car Club NSW
id try either cutting a slot in to the middle of it and use a large screwdriver, or alternatively grind two flat edges on the outsides of it and use a spanner on it
#4 | |||
Walking with God
GK
#5 | |||
On a related matter, I've seen plenty of threads about the magnetic sump plugs, but has anyone heard about the sump plugs that have a valve/tap on them so you never have to undo it again - just release the valve to drain the oil. I've read about them somewhere, but can't seem to find them, even on ebay! |
![]() Join Date: Dec 2004
Get yourself a single hex ,6 sided socket.Be surprised if that doesn't get it off..And saves the hammer and chisel :(
#7 | |||
Formally Kia Chaser
Kia Grand Carnival (2006) Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw HSV Clubsport R8 VY (2003) Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
#8 | |||
Sounds like you used one of these yourself? |
I did the same thing on a Magna not long ago, a pair of good vice grips and a lot of persistance got it off eventually
Make sure you buy the new one before removing the old one ![]() |
Tickford Equiped
i always use a 6 sided socket to remove mine, no chance of rounding it off then. there is one other way but not sure about doing it near Oil, that is to very very very carefully tac weld a bolt onto the end of it, then you use the bolt head to undo, good way to get rounded bolts off, or if you happen to loose your locking nut for your wheels. But as said, not to sure about doing it on the sump plug, to much flamable liquids around for my liking.
Genuine Tickford Equiped 1998 AU Fairmont Mods: ....... Dash mat & Air Freshener, does that count as a mod?????? Sports Exahust, Tickford Intake Snorkle, K&N Filter, NGK Plugs, Top Gun Leads TS50 Front Bar with Fog lights, TS50 Rear Bar. Injected LPG System, |
Go buy a cheap socket of similar size, find someone with an arc welder, weld the socket onto the bolt, remove bolt with a socket wrench.
1965 XP Falcon Deluxe Sedan 1978 XC Falcon Wagon Rallypack 2003 BA Fairlane G220 Windsor Powah!!! http://www.youtube.com/watch?v=m7hT9dxD2hM |
#12 | ||
Boost Addict
weld a piece of flat steel on it and u vice grips
thats what i used to take off lock nuts of my mates car, as he didnt have the key for them
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO ![]() Can't live with it, can't live without it! |
BonK182
Gday mate,
Had the same thing happen to my car. and it was really really really rounded. It is a 16mm hex head - and people should use ONLY a 16mm socket to undo it. Try some inox lubricant see if it penetrates at all, then try one of these sockets ![]() - designed to take of rounded nuts. i cant remember what you call them (maybe someone else could help there....) but mechanic mate has a fully set of them. they are the invention of the century! you might be able to purchase the single socket. hope this helps. -James |
#14 | ||
Blown 5L coming
Single hex socket is the best way everytime to remove any nut and/or bolt that requires a tight fit. As for welding around sump, ie welding another nut onto rounded bolt head, there is no problem unless you puncture a hole in the sump and have a nice little puddle under where your welding. The only place I never try welding on is steel petrol tanks or gas tanks. But if you (or anyone else out there) are worried about welding or dont have a welder, single hex socket with a breaker bar (a strong bar with adaptor for the socket with a length of about 30cm up wards for those who are not mechanicaly minded) will remove a rounded bolt as you will still have flat edges. Good luck.
Also, you mentioned you were giving her an early service? how early? I have heard that if you change your oil and filter to often you can actually end up causing damage to the motor, that and it becomes more expensive for you buying oil and filters. 10,000km or 6 months is ideal. |
#15 | ||
Forget welding anything on the sump/engine, send an arc through to a bearing and you'll screw it. The product in the crude drawing is called an Xtraktor (brand name) and it basically features helical cuts which grip the bolt/stud/nut and removes it. I don't know if they're avaliable individually but I believe the biggest size is 17mm
http://www.excaliburtools.com/xtrakt...d_stud_re.html A small pair of stillsons is another possibility, if it was tight enough to strip the head of the bolt (provided you were using the correct size spanner) then it is probably going to take some effort. You could also drill a small hole up the centre of bolt and use an easy out. I purchased a set of Metrich sockets which I generally only use on rounded nuts. They drive off the walls of the bolt head rather than the corners, thus allowing them to handle metric/imperial and rounded fasteners. But as has already been said a six point "impact" socket is generally the best. |
#16 | |||
Thanks for all the advice everyone, really appreciate it!
I can't imagine that you'd cause any damage by servicing early though - most old school mechanics still recommend that you change at 5000 not 10 or 15 as recommended by most manufacturers. But then yes, you would have balance the extra service costs against the increased life you're giving your car! Last edited by private9; 12-12-2006 at 09:45 PM. Reason: spelling, oops! |
#17 | ||
PM me if you want
you can always file down 2 sides till the are flat and then get the correct size open ended spanner on it and undo it, works for me on larger nuts and bolts.
#18 | ||
who the fudge told you it does damsdge? what a crock of shit. What pooable damadge is clean oil going to cause?
#19 | ||
STOCKLY MODIFIED
use vice grips or get a old bolt n cut the head of and weld it on top thats my fav one but ur choice
210 duration cam at 528 lift. vernier cam gear. and chip.pacemaker competition extractors.T5 with heavy exedy clutch 14.71@95 miles oh yeah ![]() ![]() check out my car and all my custom mods.. http://www.fordforums.com.au/showthread.php?t=73782 |
#20 | ||
![]() Join Date: Oct 2006
I think the crude pic was meant to be a metrinch socket; which should also work.
regards Blue |
#21 | |||
#22 | |||
#23 | ||
I can't believe you nutcases hooking into your donks with a welder, your diesel fitters aren't you, admit it!
#24 | ||
No way in hell I'd weld something onto it ... that's for sure.
#25 | ||
BonK182
thanks aussieblue.. now let me repost
*ahem* "what you need is a metrinch socket" -James ![]() |
#26 | ||
It's amazing how many times the same suggestions can be repeated. come on has anyone else got any ideas? I know how about trying a socket or welding something on it
#27 | |||
hee hee ![]()
#28 | ||
Do it like a man and use your teeth..
#29 | |||
#30 | ||
well i have a thing that looks something like this
![]() the part over the top moves, it is sorta spring loaded, and it has teeth on the inside, s basically you put it over something round, and as you push the teeth dig in and it should undo it, very useful for removing household taps as well that are too far into the wall to get a spanner onto... in short it is basically like a shifter, but with teeth inside it...i have no idea what it's called |
