Old 19-04-2005, 02:57 PM   #1
JUZXR8
Hmmmmm
JUZXR8's Avatar
Default EF Head into EA
as im replacing the head gasket in my ea i was considering using an AU steel gasket and figured while i was at it y not put on an EF head.....does this just mount straight on where the old head did....or would i have to do some modifications? also what sort of price am i looking at for picking one up....and where?
JUZXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2005, 02:58 PM   #2
dansedgli
dansedgli's Avatar
I have a EF tickford head you can have for $400 if you want, they straight on as far as I know, I was going to fit it to my EB. You will need to fit your own valve springs though.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2005, 03:09 PM   #3
EA2BA
PM me if you want
EA2BA's Avatar
Yes straight bolt on, everything fits\lines up no worries.
Old 19-04-2005, 03:52 PM   #4
stockstandard
what happens to the compression ratio?
Originally Posted by casper
Old 19-04-2005, 06:25 PM   #5
Psycho Chicken
Psycho Chicken's Avatar
Probably go up a little bit. I believe.
Old 19-04-2005, 10:03 PM   #6
stockstandard
I have heard it lowers compression unless you have EB-> pistons.
Old 19-04-2005, 10:06 PM   #7
GTFalcon 351
Mmmm... Bikini Carwash...
GTFalcon 351's Avatar
It would lower the comp ratio as the ef heads dont have the bump in the chambers as the ea chambers do, just get the head shaved and chambers cc'd to EA specs, taking into consideration the thinner head gasket if u decide to use the AU one, that is if it really worries u
'87 XF UTE 351C
'91 Peugeot 405 Mi16
'89 EA Falcon GL
GTFalcon 351 is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2005, 10:18 PM   #8
InitialD
Low and Loud
InitialD's Avatar
Yep you sure can Gremlin, as ive got one on my car now!
Old 20-04-2005, 05:44 PM   #9
Psycho Chicken
So 3.9 pistons are dished and EB/ED 4.0 are flat top?
Old 20-04-2005, 09:46 PM   #10
stockstandard
I think EB onwards are just less dished. I was told the pistons were changed because the bump was removed. Considering the size of the bump I would have thought it would drop the CR a fair bit. I remember a while back hearing that an EF head on an EA block would give a good CR for turbo's.
Old 20-04-2005, 11:58 PM   #11
Walkinshaw
Two > One
Walkinshaw's Avatar
That is exactly correct.
EA pistons = 13cc dish
4.0L pistons = 11cc dish (could be 9cc)
EF head on EA pistons would result in arround 8.6:1 comp i would say. Have the EF head milled down to achieve arround 9.0:1 comp and you will be in business.
Old 21-04-2005, 10:35 AM   #12
Gunns
Gunns's Avatar
With the AU gasket, it would bring the comp back to normal as they are 20thou less than th E-series ones.
Gunns is offline   Reply With Quote Multi-Quote with this Post
Old 21-04-2005, 10:42 AM   #13
InitialD
Low and Loud
InitialD's Avatar
CRAP! i knew there was a reason why I was suppose to use a AU Headgasket instead of a Graphite one :(
Would a lower comp make it slower at all? or use more fuel?
Old 21-04-2005, 11:19 AM   #14
EFFalcon
Last warning
EFFalcon's Avatar
with stock timing it woulnd't be the best.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 21-04-2005, 12:27 PM   #15
JUZXR8
Hmmmmm
JUZXR8's Avatar
when i put it all on....would i have to get the ecu retuned? or will it all be sweet?
Old 21-04-2005, 12:39 PM   #16
EA2BA
PM me if you want
EA2BA's Avatar
Will all be fine, the computer will be handle the slight change in cam specs without a problem.
