Old 10-01-2007, 08:11 PM   #1
josh_hartman
Default Pod Filter set up??
ok i have a pod filter and i have it just sitting on the air box with no lid and left the snorkle connected so it gets some cold air. Would i be better off taking the whole box out and the snorkle off? please leave your opinions. any help would be great
josh_hartman is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2007, 08:32 PM   #2
HLC
Audi S3
having the pod filter exposed ie. without a box around it is illegal and you can get defected for it.
but its up to you.
Old 10-01-2007, 08:35 PM   #3
damon90
(advertise here)
damon90's Avatar
also if it is out of the box you will probly only get lots of hot air from the motor
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
damon90 is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2007, 08:46 PM   #4
martymonsta
AUII FUTURA
save up your cash and get an ss induction setup with a high flow filter and icrease your pipe diameter from air box to throttle body
martymonsta is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2007, 09:12 PM   #5
Sleeperau
Highway Taxi
Default Pod
Put the lid back on. I have tried the experiment with & without & unless you have a fully enclosed heatshield (only Simota make them as far as I know) you will have reduced performance. Too much heat! HLC is correct as well, why give the police a chance to defect you. There are stacks of threads on this already. Search the site you will find buckets loads of examples. Good luck with it.
Close only counts in Horse Shoes & Hand Grenades. :evil_laug
Sleeperau is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2007, 10:21 AM   #6
LOWAU
___________
LOWAU's Avatar
but its up to you.
You can have the filter exposed but it can't be oiled, most good filters are oiled so most will be illegal.
I would leave it in the box and just add some more air entry points to the box, via FS5 mod or just drill a hole in the bottom of the box and run some tubing to the front bumper.
LOWAU is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2007, 02:17 PM   #7
Baboon_AU
Baboon_AU's Avatar
if its out of the box it isn't illegal in WA. my mates dad is a cop and thats what he told us.. and the pod will only suck in hot air when the car is stationary like any other set up.. when the car starts going it only sucks in the cold air coming from the on coming wind. out of the box is what i have now and i think its great. i got a big marine K&N pod from work
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2007, 05:42 PM   #8
StAndArdAU
Back in a Blue Oval
StAndArdAU's Avatar
I disagree, my good mates 200sx had a exposed pod and it was marked as being illegal when his car was analysed and yellow stickered for something else, i thin it was a gauge sticking too far out from the a-pillar??? and so he was told to remove it before his car was roadworthy. he jujst put it back in later anyways. der.
'13 Territory TX Diesel RWD. The Family Bus
'08 Mitsubishi Pajero. The Off-road Machine
StAndArdAU is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2007, 05:43 PM   #9
StAndArdAU
Back in a Blue Oval
StAndArdAU's Avatar
unless they qwere just on a power trip that day.?
Old 11-01-2007, 11:20 PM   #10
LOWAU
___________
LOWAU's Avatar
Yes thats right, on turbo and intercooled cars you can only have an intercooler or an exposed pod, so for us NA guys its ok.
Vicroads has a modification guideline book that stated all of this but I can't find it.
Old 12-01-2007, 01:21 AM   #11
josh_hartman
Well i took the whole airbox out today and just left the pod and the car was much better to drive. a pod is alot better than a standard CIA
