Old 13-01-2007, 04:38 PM   #1
Christopher.j
Christopher.j's Avatar
Exclamation Air Intake Drilled?
A friend of mine said that its possible to drill a hole in the Air intake Right below the Filter box (i think he said a filter box)
Is this possible or is it a **** idea?
Any tips on this would be good.
Thanks!!
Christopher.j is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2007, 04:39 PM   #2
Casper
Contributing Member
Casper's Avatar
Thanks!!
Its possible.. but your ABS gear is under there so you have to be VERY careful with the placement of the hole.
Older, wiser, poorer.
Old 13-01-2007, 04:58 PM   #3
The Dok
The Dok's Avatar
If you're trying to get more air into the system, begin with a Tickford snorkle (if you haven't already got 1) then try the extra intake at the front of the airbox to pick up air flow from beneath the headlight. Unless this hole you refer to is for some other purpose?? Conduct a search on these here forums, there's a few articles regarding air intake mods. Note: if you're running duel fuel, too much air is not always a good thing. :
Removed by laminge
The Dok is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2007, 08:31 PM   #4
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
What Dok said I agree 100% re mod and dual fuel comment
Uncle Ken
Old 13-01-2007, 11:45 PM   #5
Christopher.j
He basically said its better For AirFlow And it Gives the Engine more of a grunt type sound.
He's done it with an EA Falcon. AU Falcon And a ST Mondeo.
ill have a good look around the forums for it.
Old 13-01-2007, 11:52 PM   #6
The Dok
The Dok's Avatar
From all reports, the grunt sound can be achieved with a "pod filter" although in both my vehicles, I can't hear it (must be the insulation & exhaust).
Personally I think you will achieve satisfactory results with a pod & a Tickford snorkle, however, hanging one's head out the window whilst driving to hear said noise is not recommended!
Removed by laminge
Old 14-01-2007, 12:05 AM   #7
TwistedEL
TwistedEL's Avatar
I thought the abs stuff was relocated to under the hood near the battery in the AU's? Is there stuff in the passenger wheel well too?
Old 14-01-2007, 12:45 AM   #8
The Dok
The Dok's Avatar
I'll have to consult my photo's but from memory there is a charcol cannister in the LH front wheel area as well as a bunch of vacuum lines, & brake lines. But yes the main ABS unit is located behind the battery.
Removed by laminge
Old 14-01-2007, 10:03 AM   #9
Christopher.j
So basically he Dosnt really know what he's talking About then :-P
ill just go for my new Exhaust and Snorkle lol that might be better i think than F-Ing up my car
Old 14-01-2007, 12:12 PM   #10
TwistedEL
TwistedEL's Avatar
If you are going to drill holes in your chassis why don't you pull off the wheel arch trim and see for yourself what is in there...
Old 14-01-2007, 12:32 PM   #11
Andy XR8
AU3 Winged Windsor
Andy XR8's Avatar
Thanks!!
does he mean drill a hole in the actual filter box or through the chassis as TWISTEDEL said
Andy XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2007, 03:08 PM   #12
NeishaXR8_347
SS Grunt
NeishaXR8_347's Avatar
I would cut the whole front of the airbox off, it made a differance to my car and also a EF I6.
The Beast has gone to a new home
Morpheous VE SS 6LTR 6speed Manual in its place, Leather, Lowered, 20's, Ramjet OTR and Dual 3inch, 280RWKW
I will also enter any part of the Forum I wish to enter. :
NeishaXR8_347 is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2007, 07:08 PM   #13
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Yeah , thats a good way of doing it Neisha , Ive got that done , but soon to be replaced witha BF Box
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2007, 07:34 PM   #14
Futura01
horsepower
i am thinking of adapting a ls1 pod style setup with heatshield ???
reckon it would be of benefit
Futura01 is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2007, 08:11 PM   #15
RG
Back to Le Frenchy
RG's Avatar
I've cut the front of the airbox out on my AU. Here's a tip, DON'T USE AN ANGLE GRINDER. Trust me on that one, bad bad idea...lots of burning hand bits.
Old 14-01-2007, 09:00 PM   #16
Christopher.j
How hard is that to do red?
Apart from the Burning Angle grinder bits :eclipsee_
Would it be much of a benefit to me?
Old 14-01-2007, 09:03 PM   #17
RG
Back to Le Frenchy
RG's Avatar
Easy as, took me 5 minutes max and I always say the more air the better. I was using a hacksaw for the first 30 seconds but then got impatient. The angle grinder did end up doing a good clean job of it though...
You could always go the big buck way (as I will be soon) and go for the G&D airbox.
EDIT: Look it's my 2000th post, yay for me!!!!
Old 14-01-2007, 09:12 PM   #18
Christopher.j
omg 2000 posts :P
Congrads
Old 15-01-2007, 10:00 AM   #19
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Post Whore
AU2PWR
Old 15-01-2007, 09:22 PM   #20
redef
redef's Avatar
Cool
Thanks!!
i used a hole saw and cut a hole through box then the guard.Then ran a 2 3/4 hose to front of bumper. seems to have made it go better but couldnt be assed putting on dyno cause dont have k&n filter yet.. didnt have any problem with rail or canister.
redef is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2007, 08:17 AM   #21
xr8 007
xr8 007's Avatar
Why isnt to much air good for duel fuel as mentioned previously??
xr8 007 is offline   Reply With Quote Multi-Quote with this Post
