is it just me or is this a bit expensive for lights and bit of plastic.
http://cgi.ebay.com.au/ED-XR-Headlig...QQcmdZViewItem |
thats about the right price mate
damn. i thought it would be cheaper.
ah well thats never getting done to my car then ![]() |
#4 | |||
Formerly mad_ed_wagon
thats actually pretty cheap, not uncommon for the whole kit to go for over $1000+
2004 BA FALCON XT/GHIA WAGON Build thread coming soon! Quote:
ED_Ghia
i know this isn't the same, but it gets you a similar effect at a lesser cost
http://www.twinlight.com.au/twinlightproducts.htm does anyone in e-series have lights from these guys??? |
#6 | |||
If you really want the XR front you have to be willing to spend the big buck's. But you never know you can stumble across the odd cheap one every once and awhile but dont hold your breath. |
windsor user
the other thing is, you might find a front cheaper, but it will be stuffed...
looks like that one is in good condition.... |
EBII XR6
That price is pretty good actually. I know it sounds expensive...I had the exact same thought when I first found out, the reason for them being so expensive is that there pretty rare, thats how I see it anyway.
DEVLXR
Pimpin My VK
i rekon they're not worth it, they suck at night and they're very fragile. i had a highbeam taken out by a magpie and the globe in the other one blew
windsor user
do you want them to be indestructable and blind anything in your path?
hitting a bird at speed, you got off lightly and as for them sucking at night, they cant have been adjusted properly as they're far far better than regular falcon headlights |
#11 | |||
Now XR8TickfordBoy
EF XR8- Respray in Monza Red with Clear Coat, Custom Rear Bar, AU V8, EL GT MAF, Rebuilt and Strengthened Auto with Stage 2 Shift Kit, 2,500RPM Stallie and tranny cooler, Rebuilt Diff with 4.11 Gears, Custom Radiator, King Ultra Lows, Pedders Shocks, NL Concorde Rims. |
#12 | ||
Former E-Series Member
I think the reason they might perform better is because they have projectors - to my knowledge no Falcon outside of E series ever has. Should be similar output to an NA-NC Fairlane.
^^^who are you ?
#14 | ||
Low, Loud & Black
Didn't realise just how much these front ends are worth. Think I'll be investing in a car bra for sure.
Just wondering if anyone here knows if the headlight carriers (part the lamp itself mounts into) can be purchased anywhere? Got a busted adjustment screw on one of mine and can't get the highbeams right no matter what I try. |
#15 | ||
windsor user
no unfortunatley......they were never supplied as a part....
what exactly on yours is broken mate? the little white clip which goes on the end of the screw into the beam or? pm me, i may be able to help you out |
#16 | ||
Low, Loud & Black
PM Sent, Thanks MADNC_8
#17 | ||
Number 5 is alive!
That front went cheap.
Having had to replace a complete front 2.5 years agoi got one for $1100, Ford wanted $1600 for all new bits. Out of interest i got another quote last week from ford and the price was looking closer to $1800. So a good second hand setup is worth paying a little extra.
Kerry Tickford wings are for Tickford cars! "Experimental Racer" #6 1994 Gunmetal XG XR6 1997-1999 [B][COLOR=Red] 1994 Le Mans Red ED 2008 MA XR5 Mondeo 2015 VOLVO V60 T6 R-DESIGN-POLESTAR Enhanced ![]() |
#18 | ||
I stumbled across a set about a year ago ($400) and still haven't figured out how to get them working right. Gotta sort out the wiring so the high beams don't stay on.
They are genuine off an ED XR6 , only 1 cracked lens but the bulb still works. Any help on the wiring would be very appreciated. |
#19 | ||
windsor user
this may be helpful mate
http://www.fordforums.com.au/showthread.php?t=21091 |
#20 | ||
I build your wish list...
It looks like the Seller was NZ (Karl) from here on F.F.
#21 | ||
windsor user
yup.....sure was
#22 | ||
Cheers for the link. I'll give it a try tomorrow and see how i go.
#23 | ||
[EBGLT]
If you can find a set under $600 id grab em straight away!
[EBGLT] Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/ |
#24 | ||
No diode or even a plug for a diode on my 91EA. Only the headlamp circuit breaker then relays. I can see the diagram in Gregory's has an alternative circuit between the relays with the 5 post relay replacing so i'll see if just that fixes it.
#25 | ||
windsor user
the diode plug will be there, as its there on fairlanes....
you have to unbolt the coolant headder tank and go searching for it |
#26 | ||
Yay!!!!!! all done and working fine now thanks to Troyman on fordmods. It turns out the EA's don't have the diode or even the plug for it. I went to the wreckers and cut the diode and plug out of a fairlane. You have to replace the low beam relay (grey) with a 5 post dual swithing one (blue).
I fitted a female spade terminal to the red/black wire from my diode plug then put it in the empty middle hole for the low beam relay (pushed it on the terminal with a small screwdriver) The green/yellow wire from the diode plug has to be spliced into the green yellow wire on the highbeam relay. I did this with one of those white crimp style splicers like they use for trailer light etc. After doing this , the high beams stayed on without the ignition on. Apparently the EA's have different setup for headlight relays so you have to swap the wire that goes to pin 30 on the low beam relay with pin 87 . Did this and voilla! all 4 lights are on for high beam. Cheers for the help! |
