Old 13-02-2007, 05:17 PM   #1
apoc
AUII I6
Default What oil in 190,000k AUII I6
Can someone please tell me what sort of oil i should be putting in my AUII I6 now that it has about 190,000 on the clock? I think that 10/30W is too thin for an older car...
I have tried to search the forum for this however as usual the most important word in my search "oil" was ommitted from the search as it is too short of a word...
Cheers,
Simon.
apoc is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2007, 06:03 PM   #2
GK
Walking with God
GK's Avatar
Cheers,
Simon.
10W/50! Even though your engine is getting on, it may still be fine with 10W/40.
Perhaps try the thinner oil first, then see at the end of the first oil change interval, then if it's using a bit, you could try the thicker oil.
Hope that helps.
BTW, I use Penrite HPR GAS 10, which is 10W/50. Used Magnatec 10W/40 but for my usage, it was a little too thin. Others here find it to be ok though, maybe my engine's a bit looser than most. Penrite recommend this oil for AUs on gas and their standard HPR 10 for petrol.
GK
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 13-02-2007, 07:02 PM   #3
Peuty
Afterburner + skids =
Peuty's Avatar
I have used Valvoline XLD Premium 10/30 in my AU ever since I have owned it, with no problems at all.
Oo\===/oO
Old 14-02-2007, 05:31 PM   #4
Mechan1k
Mechan1k's Avatar
I use whatever specification it says in the manual ... and I am over 200,000km.
I don't have issues with it yet and sounds fine with factory spec oil.
Old 14-02-2007, 09:19 PM   #5
apoc
AUII I6
Out of curiousity, what would be the negative side effects of using thicker oil in my engine, if any?
Cheers,
Simon.
Old 15-02-2007, 08:33 AM   #6
bodes-sh
you would probably get noisy lifters on cold starts, possibly also use more fuel as the engine has to work harder to push thicker oil around....it depends on how worn the motor is really
Old 15-02-2007, 09:04 AM   #7
JoesAu
JoesAu's Avatar
Can u run 15w50, thats what i wanna use next, i think my caR IS starting to use up the 10w40 a little quicker than normal.. ive done 160k
JoesAu is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2007, 09:37 AM   #8
Mechan1k
Mechan1k's Avatar
EGAS models use 15W40 from factory ... so I guess the fuel injected models should be fine using this as well.
