Old 17-02-2007, 01:45 PM   #1
ebfalcon13.5
grey bumperz
ebfalcon13.5's Avatar
Default EB central locking button
hey i was wondering what would i have to do to wire a button to the central locking system on my EB to unlock the doors similar to the EF falcon? thanks
EB with sik exhaust and subs and XC falconsik is a banned word?(needs new motor)
ebfalcon13.5 is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2007, 01:50 PM   #2
holmsy
holmsy's Avatar
shouldent be to hard my ed has a button.
try find out how the ed is wired up and either change over some ed parts or work out how to adapt it.
holmsy is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2007, 02:18 PM   #3
ebfalcon13.5
grey bumperz
ok sweet an ed button will look neater then my a/m switch i was gonna chuck in does anyone know where the wires end up? do they have to be ran inside the door trims to the actuators?
Old 20-02-2007, 12:10 PM   #4
Zedjay
Zedjay's Avatar
my EB has one too (standard)
what year model is youre EB??
Zedjay is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2007, 12:43 PM   #5
holmsy
holmsy's Avatar
i dont know what the switch connects to. but if it connects into the ecu or a computer you can probably just wire it up the same and it will work. try go to a wrecker and see where the wires go.
Old 20-02-2007, 01:46 PM   #6
ebfalcon13.5
grey bumperz
its a '91 model
Old 20-02-2007, 01:52 PM   #7
ebfalcon13.5
grey bumperz
ok i will do that heading over there for a bit on sunday probably im trying to look for a pinout diagram for my ecu but i can only find eb series II diagrams.. is the ecu in my series I the same as this
Old 20-02-2007, 01:55 PM   #8
EA2BA
PM me if you want
EA2BA's Avatar
They ECU pin out basically fall into the below catagories, and then smartlock and non smartlock for most of the below.
EA 3 speed auto/manual
EA-EB with seperate trans controller
EB-ED 4 speed intergrated auto/manual
EF - auto/manual
EL - auto/manual (very very close to the EB-ED 4 speed intergrated auto/manual)
Old 20-02-2007, 02:07 PM   #9
EA2BA
PM me if you want
EA2BA's Avatar
Smartlock controls the doors on cars with a button, to use the button in any other car you will need to wire up some relays etc to send the correct signal down the actual door lock wires to lock/unlock the car (much the same as adding an aftermarket alarm)
Old 20-02-2007, 02:10 PM   #10
ebfalcon13.5
grey bumperz
EF - auto/manual
ok thanks that helps a bit its non-smartlock and either one of these:
how can i tell?
Old 20-02-2007, 02:11 PM   #11
EA2BA
PM me if you want
EA2BA's Avatar
is it auto or manaul ?
Old 20-02-2007, 02:13 PM   #12
ebfalcon13.5
grey bumperz
ive found this link http://fordmods.com/forums/documents.php?doc=41 i think it falls into the "EB-ED 4 speed intergrated auto/manual" but my cars a series one not two
Old 20-02-2007, 02:13 PM   #13
ebfalcon13.5
grey bumperz
4 speed auto
Old 20-02-2007, 02:15 PM   #14
EA2BA
PM me if you want
EA2BA's Avatar
ok under the dash (steering wheel) on the left side (nearest the middle of the car) you should see a metal box with big yellow plugs going into it, if you do then its non intergrated and thats the trans controller.
I am willing to bet this what you have, so that means you basically need an EA 3 speed auto ecu wiring diagram.
Do you have 2 TPS's on the throttle body?
Old 20-02-2007, 02:16 PM   #15
ebfalcon13.5
grey bumperz
that clears things up
Old 20-02-2007, 02:20 PM   #16
EA2BA
PM me if you want
EA2BA's Avatar
Use this if I am correct:
EA Series 1 - ECU
PIN wire colour Description
1 yellow Keep Alive Memory Power
2
3 white Vehicle Speed Sensor
4
5 red/green Key Power - B+ when igntion is switched on
6 yellow Power Steering Pressure Switch
7 greeen/yellow Engine Coolant Temperature sensor
8
9
10 blue Air Con Clutch Relay
11
12
13
14
15
16 black Ingition Ground
17 white/black Self test output
18
19
20
21 grey/white Idle Speed Control Device
22 brown/green Fuel Pump Relay or circuit
23
24
25 yellow/red Air Charge Temp
26 orange/black Sensor Volatge Ref +5v
27
28
29 green/blue Heated Exhaust Gas Oxygen sensor
30 orange/black Neutral Drive switch
31 yellow/blue Canister Purge enable output
32
33
34 green/yellow Serial Data Output Port (Link) TRIP Comp
35
36 yellow/green Spark Output from the EEC IV
37 red Vehicle power B+
38
39
40 black/green Vehicle ground battery negative (-)
41
42
43
44
45 blue/yellow Manifold Absolute Pressure
46 black/white Zero ref for most sensors
47 green/black Throttle Position Sensor Voltage
48 white/red Self Test Input
49 grey/blue Heated Exhaust Gas Oxygen sensor GND
50
51
52
53
54
55
56 brown Profile Ignition Pulse
57 red Vehicle power B+
58 dark brown bank 1
59 green bank 2
60 black/green Vehicle ground battery negative (-)
Old 20-02-2007, 02:20 PM   #17
ebfalcon13.5
grey bumperz
yes i do have the metal box there with a yellow plug
not quite sure what your talking about sorry
Old 20-02-2007, 02:21 PM   #18
EA2BA
PM me if you want
EA2BA's Avatar
Then use what I posted above, the wire colours may not be 100% correct on your car (they are taken from my car EA), but will be correct for pin assignment
Old 20-02-2007, 02:24 PM   #19
ebfalcon13.5
grey bumperz
thanks a lot for that, which site did you get these from or is this your work?
Old 20-02-2007, 02:26 PM   #20
EA2BA
PM me if you want
EA2BA's Avatar
It's my own work, so I know its correct cause I sat down and went through each wire and checked and cross referenced back to the gregories as to the function of the wire as well. I did that for adding the 4 speed auto to my car.
Old 20-02-2007, 02:32 PM   #21
EA2BA
PM me if you want
EA2BA's Avatar
This is the 4 speed Trans controller as well:
4 Speed Auto Trans Computer (TCU)
1 Blue/Yellow Temp Sensor (input)
2 Orange Diagnostics (input)
3 NOT USED
4 Blue Air Con status (input)
5 Blue/Orange Temp Sensor ground
6 Pink Ignition system, engine speed signal (input)
7 Green Solinoid 5 return (input)
8 White/Red Diagnostics (ground)
9 Blue/White Throttle Position (ground)
10 Violet/White Shift Lever Position (ground)
11 Green/Yellow Solinoid 4 (input)
12 Green/Black Solinoid 1 (output)
13 Yellow/Red Solinoid 6 (output)
14 Green Mode indicator dash light (output) Negative (-)
15 Yellow/Black Battery Positive (power)
16 Blue/Red Throttle Position (input)
17 Violet Shift lever (input)
18 Red Econ/Preformance Mode switch (input) Negative (-)
19 White Shaft SApeed Sensor (input)
20 Green/Blue Diagnostics (output)
21 Black Ground
22 NOT USED
23 NOT USED
24 NOT USED
25 Blue/Green Throttle position sensor reference 5v (power)
26 Green/Red Solinoid 3 (input)
27 Green/White Solinoid 2 (input)
28 Yellow/Green Solinoid 7 (output)
29 Yellow Solinid 5 (output)
30 Red/Green Ignition switch (power)
Old 20-02-2007, 02:40 PM   #22
ebfalcon13.5
grey bumperz
thanks again for that EA2BA, you dont know how long ive been looking for that info!
Old 20-02-2007, 03:01 PM   #23
EA2BA
PM me if you want
EA2BA's Avatar
Not a problem when it comes to ea wiring at least, i have pulled apart and mapped nearly every wire in my car, and added a lot more too
Old 20-02-2007, 03:27 PM   #24
ebfalcon13.5
grey bumperz
i now know who to ask if i have any trouble wiring in my eb! ;)
Old 20-02-2007, 03:33 PM   #25
EA2BA
PM me if you want
EA2BA's Avatar
anytime, good luck with project
