Old 18-02-2007, 02:09 PM   #1
Hybrid34
|AFordEd|
Default Loud fan Noise as accelerate
I've noticed with most Ed or around that era, that when the cars acelerate (i think it is) the fan makes a loud noise, not a streech or anything, asthough the fan is spining realyl really fast, is ther anyway to get rid of that? as Ive only noticed it on the Ford Ea n ED's
1996 Ford Fairlane mock by tickford
EF Xr6 Engine
EF Xr6 ECU
3:4:5 LSD diff
JMM Extractors
2.5" Stainless Steel highflow cat
2.5" Exhaust
T5 transmission
Front Slotted rotors
Lowered on Pedders Sports Ryders
....and a cherry scented airfreshner
Speed determines how fast you hit the Traffic Light....Power determines how far you take it with you.
Hybrid34 is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2007, 02:14 PM   #2
DEVL-XR
EBII XR6
DEVL-XR's Avatar
Yeah its called thermo fans from an EF or EL. What your hearing is the fan spinning when the thermo stat is at a certain temp. When the temp is lower the fan isnt as loud.
The thermo fans are a common mod along early e-series owners. Have a search and you'll find plenty of info about thermo fans.
DEVLXR
DEVL-XR is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2007, 02:14 PM   #3
EDXR6T
No its called a clutch fan EA-D have them they are noisey as.
Way to fix it is to get thermo fan's.
EDXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2007, 02:32 PM   #4
Hybrid34
|AFordEd|
oh yeah a thermo fan, whats the cost of one of them? and is it common to have in? or to expensive?
EF Xr6 Engine
EF Xr6 ECU
3:4:5 LSD diff
JMM Extractors
2.5" Exhaust
T5 transmission
Old 18-02-2007, 02:38 PM   #5
holmsy
holmsy's Avatar
yeh i noticed the exact same thing. i dont like it beacause it dorwns out the noise of the exhuast
im not very mechanically smart. is it the fans sitting just behind the radiator? infront of the engine.
edit: i worked out yes it is.
how much is it for a cheap new or second hand thermo fan.
installed.
holmsy is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2007, 03:17 PM   #6
mark_TD
XR6 Turbo FTW
mark_TD's Avatar
The clutch kicks in at a rapid speed as the temperature climbs and the thermastat opens. If the noise is loud all the time that means the clutch fan is sticking and will need to be replaced. Fuel consumption increases too when the fan is spinning at these speeds. Themos are the way to go as there is no noise as such and fuel consumption decreases.
02 BA XR6 T U R B O - 232rwkw @ 6psi
Blueprint, 19" FG2 XR6 Luxo Rims, Momo Steering Wheel, XR8 Bonnet Buldge, Full Leather, 3.7 Typhoon Diff Gears, Force Lip Spoiler, De-badged, Ghia Boot Garnish, Pedders Adjustable Coil- Overs And Camber Kit
96 EL XR6 - (Daily)
Gunmetal Grey, 19" Typhoon Copies, Tickford Body Kit, Pedders Sports Ryders With Shortened Shocks And Camber Kit, Full S/S Difilipo Exhaust With Matching Extractors
mark_TD is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2007, 03:28 PM   #7
DEVL-XR
EBII XR6
DEVL-XR's Avatar
Thermo fans for starters!
Cost, around $100 - $150, depends where you get them from...wreakers, ebay, private sale. You'll also need wires and relays.
I'm sure someone on here can install them for you for a slab of beer!
DEVLXR
