Gday guys, just wondering is there any way of by passing SMATLOCK?
PM me if you want
ring jim mock motorsport and pay $300 for a bypass module, or ford may still be selling them at around the same price, else simple answer NO
|AFordEd|
why would you want to bypass it? For a remote start?:P cause thast exaclty what I have in mind
1996 Ford Fairlane mock by tickford EF Xr6 Engine EF Xr6 ECU 3:4:5 LSD diff JMM Extractors 2.5" Stainless Steel highflow cat 2.5" Exhaust T5 transmission Front Slotted rotors Lowered on Pedders Sports Ryders ....and a cherry scented airfreshner Speed determines how fast you hit the Traffic Light....Power determines how far you take it with you. |
DFDFDF
Yer.. I have to ask aswell.. wat is the reason behind wanting to bypass smartlock??
I have got around it when i installed my alarm system.. no remote start though cos they are no no.. Cheers, Nik
The Daily : 2012 Ford Territory The Restorer : 1994 Polynesian Green ED XR6 T5 - Completely stock, put away for a few years The Project : 1994 Velocity Blue ED Ford Futura - AU3 220kw XR8 5L V8 5-Speed in progress The Toys : 2003 GasGas EC250 & 2001 Yamaha DT230 |
|AFordEd|
Bypass smartlock only to put a remote start in i think, (is what people have been tellng me) and what i want to do, why are they a no no roosta?
www.TUFFCARPARTS.com
I have no idea what's been done, but the smartlock in my EL has been disabled (or possibly bypassed) to allow for remote start. I had a brief look under the dash, but can't find anything obvious other than a heap of scary looking stray wires!
I want to remove the whole lot though and just put a normal alarm in and fix smartlock.
http://i1233.photobucket.com/albums/...psc203b7b1.jpg |
DFDFDF
I am fairly sure that it is illegal to have a remote engine start fitted to a road registered vehicle..
And i am pretty sure that is Australia wide.. On the other hand maybe you wish to fit a turbo timer or something like that.. if so u dont neccessarily have to bypass smartlock.. Cheers, Nik
|AFordEd|
what would be the point inthe turbo timer if the car isn't turbo?
and are you sure its illegal? i thought it was only illegal for manual cars (as you might leave it in gear) Nik u've replyed to most of my posts within the llast 10min (must be bumming onthe comptuer like i am :P)
DFDFDF
Lol.. yer i am bored as.. LOL..
I am 99% sure it is illegal in any vehicle.. Keep in mind most manual vehicles have nuetral switches so fitting a remote start would be same level of danger as an automatic.. As for the turbo timer i was just guessing at wat MONTYMUZZA might need to bypass smartlock for.. Cheers, Nik
grey bumperz
whats a smatlock
EB with sik exhaust and subs and XC falconsik is a banned word?(needs new motor) |
|AFordEd|
its a lock...thats smart
#12 | ||
grey bumperz
lol, i knew what it was, just the op spelt it wrong, sounds a little sus. to me wanting to bypass it maybe the car is stolen cause if he smart enough to do remote starts etc he should know this already :evil3:
BA Mk2 XR6 Turbo
roosta is kind of right.
ive had cops check out the fact that it remote starts and they havent told me off. i guess as long as you have wired up all the safety measures theres no reason for it to be unsafe. b.t.w it makes no diff betweeen man n auto both have safety switches to check if in gear...and if park brake is on. disable the turbo timer part of the alarm if u dont have turbo. its a cool down timer...no turbo no need. smart lock reads for keys doesnt it? so u will need a bypass unit. brad
2005 - BA mk 2 - XR6T - 4.0ltr Turbo - 6 Speed Manual Blue Power Airbox, Sunroof, Typhoon Wheels, Brembos, Prem Sound, Momo Chunky Wheel, Genuine FPV Gauge Holder, Whiteline Swaybars, Lowered, Tinted Windows, 60lb Injectors, Plazmaman Cooler, Hot Side & Under Battery Pipes, 4" Dump & Cat, Process West Surge Tank & Bosch 044, Turbo Inline Oil Filter |
#14 | ||
PM me if you want
Smartlock does not read the key, it simply has an extra part of the igntion barrel that tells the smartlock unit to send a signal to the ECU to enable it.
Smart Sheild (AU onwards) does read they key then basically does the rest the same. Smartlock module via a key fob will allow you to unlock/lock the doors, open the boot and also controls fading the interior light.
#15 | ||
grey bumperz
my old n14 didnt have a safety switch (manual) i would start it in gear and off it would go! ahhh :evil3:
