Old 25-02-2007, 08:44 PM   #1
Hybrid34
|AFordEd|
Default Manual Shift in an Auto, Good or bad?
Ay, Just want to know, went giving it a bit of gas at the lights or overtaking someone, is it healthy to use the 1,2,3 in an auto? or will it wreck the bands or transmission?
another thing, which is the best way to start off to get a head start?
ie; Having a little revs with the brake on? or just plant it????
Just intreeged :P thats all....
1996 Ford Fairlane mock by tickford
EF Xr6 Engine
EF Xr6 ECU
3:4:5 LSD diff
JMM Extractors
2.5" Stainless Steel highflow cat
2.5" Exhaust
T5 transmission
Front Slotted rotors
Lowered on Pedders Sports Ryders
....and a cherry scented airfreshner
Speed determines how fast you hit the Traffic Light....Power determines how far you take it with you.
Hybrid34 is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2007, 08:47 PM   #2
mcflux
mcflux's Avatar
BTR + std gears + std stall = slow no matter what you do.
Old 25-02-2007, 08:50 PM   #3
bentles
bentles's Avatar
i use my auto shifter all the time, when having a fang, otherwise D with econ is fine, never used power since i started using the auto shifter, it shits on power mode. i use shifter while slowing down cos it makes my car sounds about 200 times better lol
bentles is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2007, 08:58 PM   #4
castek
since my diff is rooted (serves me right paying $80 for it), i leave it in econ, because the shift is a bit softer than in normal mode, and the clunking doesnt give me the shits. if i am going to ballarat and i am on cruise, i usually chuck it in 3rd and leave it, it gets annoying hearing it go through unlocking the converter, kicking back to third, then fourth, the lock up etc. it doesnt really put much more strain on the transmission, but if you hold it back in first for a while, without a cooler, it will overheat
castek is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2007, 09:29 PM   #5
holmsy
holmsy's Avatar
iv been using the 123 part sometimes over the past few days. makes the car sound 10 times better but it has a whine when ya at low speeds. but it doesnt have the same wine in D so i dunno.
mine also doesnt allways go into 1 so easy it doesnt lock in without a bit of help.
is it my tans being dodgy or does other peoples cars do this. if i am in 3rd or 4th (gear stick on D)
and i put the foot down it doesnt change down at all so it doesnt have much power? is it just that old cars wernt so good changing down when ya want it to or is there something wrong with it?
holmsy is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2007, 09:35 PM   #6
EA Ghia
EA Ghia's Avatar
Could be your accelerator cable. I found when I changed mine, it was a lot more responsive, and the kickback came a lot easier.
EA Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2007, 10:06 PM   #7
bentles
bentles's Avatar
if ur doing about 70+ and plant it ull be lucky to drop down into 3rd.
the whine sound is normal as i bet u only get it in 1st at speeds below 40? its cos the gear is spinning real fast but the engine isnt making enough noise to overpower the wine sound i think.... might be wrong but
Old 25-02-2007, 10:42 PM   #8
PHoeNiX
The ORIGINAL!
PHoeNiX's Avatar
my EF hits 2nd at 70. i have found that my car can do 85 in first, so 70 in 2nd is eeeeasy as. 135 should be the limit for 2nd, not game to try max out 3rd. i rekon itll hit the limiter in 3rd.
there is a reason that the transmissions were modified to have the tiptronic? auto shift (semi auto)...the normal auto isnt designed for constant changing. its not good to do it all the time as far as i know, just when towing or belting the sh!t out of it at lights etc. ive found that gettin the revs to about 2k with foot on the brake gives it a decent aunch, but u really want a bigger stally for a good launch.
brenton
:thebirds: My Site
PHoeNiX is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2007, 11:00 PM   #9
DNKPWR
DNKPWR's Avatar
Changing down into 1,2,3 will evendually damage your trans! I did this and now have a manual because the auto died in the @rse!
As for the head start at the lights stall it up to 2k rpm with the brake on of course, too much revs will cause wheel spin! lol
BA XR6 TURBO - SILVER & 1970 Mustang Coupe
DNKPWR is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2007, 11:09 PM   #10
atec77
manually shifting will casue problems over time , if you wanna go quick then mod the box .
Old 25-02-2007, 11:12 PM   #11
tuffnc
aka SHY4D aka Patty
tuffnc's Avatar
when my box was done i got a stage 2 kit and moded stengthened internals, guy told me up shifting (1,2,3) is fine, just dont down shift, thats when u gonna do damage...
tuffnc is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2007, 11:13 PM   #12
crannersEL
crannersEL's Avatar
I started a similar thread a little while ago, have a read through this :-)
http://www.fordforums.com.au/showthread.php?t=66810
crannersEL is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2007, 06:23 AM   #13
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
manual FTW cant beat a clutch so much fun and the best mod i did to my weekender
VE SS Ute manual 09
AU XR8 UTE 200KW manual 02
Challanger Ski boat V8 01
125 Thumpster 2010
Swag
All set for the weekend
eb91xr6 is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2007, 08:13 AM   #14
EA2BA
PM me if you want
EA2BA's Avatar
I have been manual shifting my auto for about 2 years now and nearly everyday all the time, its still going good, I am using the BA shifter and a SSS electronics module that tells the solenoids what gear to be in, maybe it's a little kinder to the gearbox.
Old 26-02-2007, 02:13 PM   #15
BLSTIC
Inside the gearbox, there is no mechanical or hydraulic difference between the forward gear selector positions of a BTR (or most electronically controlled gearboxes). Its all electronic (try it, those with early models, disconnect your auto ecu, 3rd gear only, and yes I have had the valve body apart and looked closely).
That said, the computer never does downshifts at speed unless you are accellerating. Doing that is where the extra wear comes from.
cya
Ben
BLSTIC is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2007, 03:14 PM   #16
Bipolar
I'm back. Same car.
Bipolar's Avatar
I downchange my auto every time I drive it (only when useful though), but make sure I blip the throttle before the change to match the revs. Can't feel any shock when I do that.
Bipolar is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2007, 06:05 PM   #17
DEVL-XR
EBII XR6
DEVL-XR's Avatar
I MANUALLY change gears all the time....with a clutch! :
DEVLXR
DEVL-XR is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2007, 06:21 PM   #18
mcflux
mcflux's Avatar
I used to hit 2nd at 110 :P
Old 26-02-2007, 06:42 PM   #19
Dezza
Parts bin special
Dezza's Avatar
No wonder your auto died :P
Old 26-02-2007, 06:52 PM   #20
mcflux
mcflux's Avatar
Ahh the whole car luffed it. 1500rpm beyond peak power, valvetrain sounded like I was in an aviary full of excited budgies, puff of smoke from the exhaust (or probably from out of the tranny dipstick :P) upon gearchange...
Yep, I'm a pro driver, that's for sure. Anyhoo that was with the 3.27s. I'd be lucky to see 85 with the 4.11s.
Old 26-02-2007, 07:27 PM   #21
Maximus
ED XR6
Maximus's Avatar
Good work, me too!
Yeah, seriously MANUAL CONVERSION TIME.
Maximus is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2007, 10:04 PM   #22
babbo
babbo's Avatar
yeah 2 right, i dont really like driving autos much.
babbo is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2007, 11:09 PM   #23
PHoeNiX
The ORIGINAL!
PHoeNiX's Avatar
no, no, no...was saying that 70 would be easy for 2nd....if u read the rest of my post ull see that my 2nd reaches 135 and im not game to max out 3rd...so : straight back at ya....lol
:thebirds: My Site
Old 26-02-2007, 11:15 PM   #24
mcflux
mcflux's Avatar
I dunno where my 2nd maxed out, but it would've been somewhere around 180ish ;)
But what I'm saying is my 1st maxed out at 110. Hence, my e-phallus is greater than yours. Hooray for doughy launches with stock diff gears. *memories*
Old 27-02-2007, 12:45 PM   #25
Hybrid34
|AFordEd|
Hmm thanks for all your posts, Just wanted to use the 1,2,3 for when im at the lights, not as an everyday thing.....as for what people said before its hard to get into first or won't go in, theres acutally a second lock on the button, it will let you go down into 3rd and 2nd fine, but when you want to hit 1st you have to hold down that little black button and clunk it in
EF Xr6 Engine
EF Xr6 ECU
3:4:5 LSD diff
JMM Extractors
2.5" Exhaust
T5 transmission
Old 27-02-2007, 05:33 PM   #26
SVT8
SVT8's Avatar
i hate to steal this thread but.....
My trans has just had a service and its perfectly fine, i shift gears all the time but only when the car has fully stop then i slip it into 1,2,3 then drive and leave in drive it until i stop again. I never downshift though, as i have heard thats what does all the damage.
Anyway, when i stick my gear stick into 1 and shift onto 2, it shifts fine when im driving casually. But when i plant the pedal to the floor starting from 1 and shifting into 2..........it doesnt seem to change into second gear???. It only shifts into second gear as soon as i back off the pedal???. Is this normal?? should the gears change as soon as i move the stick to the next gear despite the pedal put down to the floor?. all it does is rev in that gear until i actually back off. Just wondering if everyone has this problem when shifting gears manually in an auto?.
SVT8 is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2007, 08:29 PM   #27
falcon351
HANK
falcon351's Avatar
i frequently shift down to 2 or 3 when drivin as it makes my car pop when decelarating and sounds sweetas, but wait till stationary to change to 1st. ill let u know how it goes once i buy an auto shift kit from shiftkits australia!!!
1992 EBII Fairmont
Lowered 30mm on kings springs and monroe struts/shocks
Performance catback exhaust with stainless 3 in tip!
Shift kit!
Tinted windows n tail lights.
Pioneer 200w flip face head unit
600w pioneer sub backed by my nu 640W kenwood 4 way amp
Eclipse 6x9s and 6's
Clear front and side indicators
115 rwkw on regular, not bad for pod, catbak!
Back on the rd! nothing can stop us, not a defect or even a stoby pole!! BAHAHA NEVER SAY DIE!!!
falcon351 is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2007, 10:56 AM   #28
brlucas
yeh ash! hahaha
brlucas is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2007, 12:50 PM   #29
EBTom
EBTom's Avatar
Any harm in using 3rd around town (under 60kmh)? I dont know if its accurate or not, but I seem to get better fuel economy doing this, maybe because you dont have to use as much throttle to constantly kick down from 4th? Does this sound right or is my trip computer playing mind games?
I find it helps to avoid speeding due to the degree of engine braking compared to 4th.
Current Ride:
EL XR6 - 4.0, M5, FULL EXHAUST, 18” ANZ TYCOON'S, SUPERLOWS
Former Rides:
EB1 FAIRMONT – 4.0, A4, FULL EXHAUST, WADE 1004, TIP J3, 18” BA XR8’S, SUPERLOWS, SPRINT KIT,
AU1 FAIRMONT GHIA – 5.0, A4, 3" CATBACK, 20" VERSUS WRAITH, ULTRALOWS, TICKFORD & MOMO GOODIES
EBTom is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2007, 03:38 PM   #30
Bipolar
I'm back. Same car.
Bipolar's Avatar
Absolutley not. 3000 cabbies can't be wrong.
I think the only problem is constantly smashing the spragg clutch by putting too much of a sudden load on it from constant downshifting (as Rollin has said before). As for matching the revs like in a manual though, I don't see why the box would react any differently to that than by burying the throttle and letting it drop back on it's own. Anyone correct me if I'm wrong...
