Old 28-02-2007, 01:02 AM   #1
sphell
sphell's Avatar
Default What gets double sided tape off?
I'm having drama's with the bloody side moulds on my car. Since they were left off for so long while the car was painted, they have warped and whenever I stick them on the car they gradually peel off again.
Anyway, I used the good 3M double sided tape on them the first time and now it's stuck to all the doors. I want to get it off without damaging the paint so does anyone have any magic product that will do this?
Old 28-02-2007, 01:23 AM   #2
The Dok
The Dok's Avatar
Prepsol/Prepwash is about the only product that will remove the glue, make sure all the excess tape is off first. It is also great for prepping paint in case you want to re-stick the body moulds back on.
Removed by laminge
The Dok is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2007, 01:57 AM   #3
FORD EB 4.0
FORD EB 4.0's Avatar
I recently removed my side moulds and did it on a hot day, most of the tape stayed stuck to the car but I was able to peel it off in long strips. Its a slow and tedious process but I don't think there is a faster or easier way. Maybe you could call a panel shop and see what method they use for removal.
Good luck.
FORD EB 4.0 is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2007, 05:34 PM   #4
Dezza
Parts bin special
Dezza's Avatar
I did the same with the chrome strips in the front bumper. When I replaced them, I used my fingernail to peel all the old double sided tape off. It was slow, but I got it all in the end
Old 28-02-2007, 06:15 PM   #5
sphell
sphell's Avatar
Hmm might have to stick with the Prepsol then, I've used that before but it's not that great. I was hoping there was some purpose made stuff cause this tape is strong as :(
Old 28-02-2007, 06:22 PM   #6
TUFED6
TUFED6's Avatar
Acetone should get it off. I've used it on painted surfaces before and it didn't harm it. Eucalyptus oil is pretty good at removing glue as well.
TUFED6 is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2007, 06:24 PM   #7
Sundeep
Sundeep's Avatar
CITRO should weaken it up a bit, goes to goo though so makes a bit of a mess.
Sundeep
Sundeep is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2007, 06:27 PM   #8
dansedgli
dansedgli's Avatar
Big Kev's goo remover if it is still being made.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2007, 06:27 PM   #9
LUXO_8
windsor user
the only thing though, its a fresh paint job so i wouldnt be too keen on the acetone on that.....otherwise, yes it works
Old 28-02-2007, 06:38 PM   #10
webby_191189
low wagooon
Eucalyptus oil should do the job for ya
Webby
S2 AU XR6 UTE
webby_191189 is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2007, 07:46 PM   #11
JUZXR8
Hmmmmm
JUZXR8's Avatar
another vote for eucalyptus oil....i just used that on mine when i changed over the moulds....does a good job
JUZXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2007, 08:35 PM   #12
pauly85
commodore bogan
pauly85's Avatar
go to a place like all cars in croydon and get your self a rubber wheel attatchment for your drill, we use them at work for double sided tape and pin striped, not sure how expensive they are but they work and look cool when they warm up and start smokin!! lol
just take it easy on the fresh paint tho
BA RTV
pauly85 is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2007, 08:41 PM   #13
nos_james
nos_james's Avatar
if ya molds are bent warped straghten em out with a heat gun befor you try putting them back on
nos_james is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2007, 08:42 PM   #14
Kryton
Kryton's Avatar
Shellite will definately remove it.
might pay to test a patch of paint in the boot first.
Kryton is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2007, 08:42 PM   #15
EBIIXR6
EBIIXR6's Avatar
1. wax and grease remover
2. An eraser - a white one
3. Eaucalyptus oil
4. A perspex square with a sharp edge on it
93' EB II XR6 factory manual
Everglade Green 3" Mandrel Exhaust, High Flow everything, GT61 garrett @ 6PSI :voldar02:
EBIIXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2007, 08:48 PM   #16
FORDNUTS90
STOCKLY MODIFIED
FORDNUTS90's Avatar
3. Eaucalyptus oil
1 vote for wax and grease remover that stuff is awsome i love it
210 duration cam at 528 lift. vernier cam gear. and chip.pacemaker competition extractors.T5 with heavy exedy clutch 14.71@95 miles oh yeah : : :1syellow1 :1syellow1
check out my car and all my custom mods..
http://www.fordforums.com.au/showthread.php?t=73782
FORDNUTS90 is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2007, 09:50 PM   #17
Nikked
Oo\===/oO
Nikked's Avatar
Get a "caramel wheel" from a good auto parts store or auto paint store, stick it in a drill and work at it. Whipe it clean with a wax and grease remover....
as for warped moulds, leave them in the sun for half a day then stick them on your car.
(hint:brake cleaner can be used on both the car and the moulds and doesn't leave resendue like wax and grease remover, that can cause the tape to not adhere properly.)
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2007, 10:53 PM   #18
sphell
sphell's Avatar
The rubber wheel and 'caramel wheel' sounds like a plan! I knew there had to be something around that was made for this. Lots of good ideas guys, thanks heaps!
Old 28-02-2007, 11:23 PM   #19
nawid
use a bug and tar remover found at any good auto supplier.
easy.use maybe a plastic spatula 2 scrap it off?
nawid is offline   Reply With Quote Multi-Quote with this Post
