Old 06-03-2007, 01:04 AM   #1
sionghua
Default Petrol vs LPG
I heard comments that LPG wears the engine out sooner than petrol, is it true?
sionghua is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2007, 07:31 AM   #2
LTDHO
The one and only
LTDHO's Avatar
Yes.
Petrol lubricates, LPG doesn't.
Some people run external oil drippers to help prevent this.
Tuned by CVE Performance
Old 06-03-2007, 08:02 AM   #3
trick_xd
I build your wish list...
trick_xd's Avatar
yes its true .. if you have a push rod V8
a 6cyl E-series will not hurt it at all
a V8 will get a sticky valve quickly (maybe within 50,000 km ) and a I6 will last longer then the motor in general or the car
If it weren’t for physics and the law enforcement, I’d be unstoppable.
trick_xd is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2007, 03:42 PM   #4
DirtyHarry
Do you feel lucky?
DirtyHarry's Avatar
Regarding the V8s, is that what Flash Lube is for?
DirtyHarry is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2007, 03:47 PM   #5
webby_191189
low wagooon
Flash lube is like the lead additive for older model vehicles that where built to run on leaded
Webby
S2 AU XR6 UTE
webby_191189 is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2007, 03:58 PM   #6
DirtyHarry
Do you feel lucky?
DirtyHarry's Avatar
OK, so I've got a 5.0 on LPG. So far I've done about 20,000km with no worries.
What exactly should I do?
Old 06-03-2007, 10:16 PM   #7
INJECTED_250
Custom user title
INJECTED_250's Avatar
CAbs do 500,000 km on a head easly..... Yup gas is realy bad:>
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2007, 10:27 PM   #8
Fairlane
V8 Powaah
Fairlane's Avatar
Gas lubricates the motor less and runs hotter and can eventually lead to valve problems in standard petrol motors (groosly exaggerated, like running ULP in a leaded car and can be solved by running a Upper head lubricant). LPG has a big upside as well in extending motor life leads a hell of a lot less carbonisation and does can help in extending the life of the bottom end of the motor.
Look at oil in a straight LPG motor after 10,000klms, the oil will be clean as all hell, the oil will eventually break down with the heat, but it still looks like honey.
Taxi's and Hire Cars are perfect examples, half a million kays on motors no probs, hire cars are similiar they have no problems getting 400,000 kays out of I6 and V8 NF/L/AU fairlanes. My e-gas falcon has over 110,000 klms on it now running nothing but LPG, and the motor is running as good as ever.
FG G6E Turbo- Seduce & Cashmere - Sold
XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
Fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2007, 11:02 PM   #9
ratter
ratter's Avatar
Lots of people here are going to tell you that LPG does not promote valve recession in the ford 6 motor, do yourself a favour and ring a few head reconditioning specialists and ask them and ask if they build heads different for LPG and why, you'll find they have a different opinion to the people here.
Pit Lane Performance
Old 06-03-2007, 11:56 PM   #10
trick_xd
trick_xd's Avatar
yep they will tell you to get Harden valves
and a good set of Inserts
Old 07-03-2007, 12:07 AM   #11
StaikXR6
i used to work on gas and the problem is not with the gas its the people . if u have a car on gas at least run it once a week on petrol best way to maintain
StaikXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2007, 12:31 PM   #12
XRated
Shoot.
XRated's Avatar
What sort of minimum specs would you demand if you are building a dedicated LPG I6? (With highest compression possible 10-11:1?)
20V Turbo
Old 07-03-2007, 04:33 PM   #13
ea90gl
ea90gl's Avatar
i've heard a few horror stories with LPG, even seen lots of damage/wear myself. Backfiring that blows up air boxes, accelerated wear on valve seats, I even seen a base from a Rochester carb that was melted from the heat/backfiring. I only run it on my cheap run-around cars cause its cheaper than petrol, i would stick to petrol for a performance machine. But at the same time it is a good fuel if you maintain the engine and take them extra precautions to make sure your engine doesnt crap it self eg drip lubrication systems, proper tune ups etc
ea90gl is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2007, 02:34 PM   #14
Freight Dog
350k on my lpg EL so far. It uses 1 litre of oil between my 10k oil changes, and the engine has never been touched. However the gas converter seems to require maintenance every 100k or so.
It has factory fitted duel fuel, and Ford indicate in their Car Manual that LONGER engine life can be expected running on gas
Freight Dog is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2007, 03:29 PM   #15
sionghua
Factory fitted they changed to hardened valve seat, hardened valve, hardened piston & ring....
Old 16-03-2007, 09:14 PM   #16
WillsEDfalcon
WillsEDfalcon's Avatar
hi
Im thinking of puttong my ED on gas i read throught the posts but still undesided on what i should do. Ive herd that italian made gas converters are best suited to E series. so far it has only done 156,000. at the moment im uming and aring if i should make the change
what is your opinion
WillsEDfalcon is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2007, 09:28 PM   #17
atec77
Wrong , some motors did get different rods , not many and how many ex govco cars as cabs do you think get rebuilds under 500k , alloy heads already have seats to require nothing to run on gas.
Old 16-03-2007, 11:00 PM   #18
trick_xd
trick_xd's Avatar
I would not Demand anything.. But I would like as much as I could
9 and over is a good .
Build a motor from the start
pm if you would like to know more
The Ford I6 motors would have to be one of the best motors to put gas onto .
As for backfireing .. that is a spark problem .. you should check/change your plugs every 40/50,000km anyway. and when you are nealy out of gas you do not put your foot to the floor as the Lack of gas will make it back fire as well ..
As for performance on L.P.G. .. you can get as much as you have on petrol.. if you set it up right.
Factory gas (tickford) setups would be the worst to have as they can not be adjusted. Deal with it anyway you want.. it will do the best the setup/tune will let it.
willieboy .. put your car on gas .. if your car is looked after it will be just as good on both and with less cost per km.
Old 17-03-2007, 08:47 AM   #19
sionghua
According to the info I got from a Ford mechanic, LPG does shorten the lifespan of engine. E-gas engines were modified to be able to run LPG, thus the longer lasting result.
Old 02-04-2007, 02:59 AM   #20
driva137
idrivemanylanes
92 NC FAIRLANE 5.Litre V8 377,895ks
Runs 91 unleaded Tyres 205/65/15 Dunlop
635.8 ks Shell Ultra 91 62.51L $1.559c/L $97.46c
Trip Meter would Equal 733ks per Tank
Auckland to Wellinton
Left at 1.10am got there 9.00am Sunday
driva137 is offline   Reply With Quote Multi-Quote with this Post
