17-03-2007, 04:40 PM | #1 | ||
Cane Farmer
here is my new pod setup.
Got all the gear from supercheap. Some might say I did a crap job or it looks crap, but I like it! Tiny bit better throttle response from doing it, but if anything it looks cool! comments welcome! |
17-03-2007, 04:44 PM | #2 | ||
STR8 6
D you know if that legal or not, i wouldnt mind doing something similar.
17-03-2007, 04:47 PM | #3 | ||
Cane Farmer
Yeah I think it is.
What they don't know can't hurt them? Besides, I think that it's an EPA related thing and not police. And for less than $150, can't go wrong! |
17-03-2007, 04:50 PM | #4 | ||
STR8 6
$150 + fines = not happy
i wanna be sure that it is LEGAL |
17-03-2007, 04:51 PM | #5 | ||
Cane Farmer
if it has an airbox around the pod it's legal.
17-03-2007, 04:53 PM | #6 | ||
EBII XR6
Although its got a heat shield I'm not sure if thats legal or not. I know there legal if there boxed but heat shields I'm not sure of.
DEVLXR
17-03-2007, 04:54 PM | #7 | ||
STR8 6
So yours is illegal?
17-03-2007, 04:58 PM | #8 | ||
It is illegal unless it has an engineers certificate.
Chrispy |
17-03-2007, 05:03 PM | #9 | ||
its so dumb how can changing to no air box cause the epa to get shitty? whats it do? suck in endangered wildlife or something?
if anyone knows the exact reason feel free to post it in here for me cos i dont get why pods are illegal unless boxed |
17-03-2007, 05:11 PM | #10 | |||
EBII XR6
DEVLXR
17-03-2007, 05:26 PM | #11 | |||
Hmmmmm
your allowed to have 1 intake mod without an engineers cert, as soon as u have more than 1 u need to get them engineered. unboxed Pods ARE illegal FYI |
17-03-2007, 05:28 PM | #12 | ||
STR8 6
i think the fibre the pods are made from are highly flammable (read it somewhere on these forums) correct me if im wrong.
17-03-2007, 05:31 PM | #13 | ||
Hmmmmm
yeah, its incase of backfiring, so that it doesnt catch on fire and blow up your engine bay
17-03-2007, 05:35 PM | #14 | ||
not a bad setup. it would be more efficient if you could section off the area around the pod a little more.
similar to Rollins old setup.
Powered by Rollin Motorsport Turbo Barra ED 4L
17-03-2007, 06:07 PM | #15 | ||
i got a Pod on mine with heat shield From Niko i just took off the factory top of the Airbox left the bottom alone i was gonna put the pod in top of the airbox but wont fit due to it being 3 inch intake which is kinda weird.
i have notice'd better throttle response and third gear is better acceleration to fourth and better in Power Mode |
17-03-2007, 06:45 PM | #16 | ||
LOW AND SLOW
Unboxed pods are illegal as they suck hot air into motor which in my theory throws all factory emission output levels out of whack. Dont quote me on that though, thats just my theory. But im 100% that unboxed pods are ILLEGAL. Besides if you are using the pod for more power, its useless if its sucking in hot air. We all know motors perform better with cold dense air.
17-03-2007, 07:59 PM | #17 | ||
|AFordEd|
EDadam, i second that, and if its boxed its still illegal cause your modifiying the engine's components, best legal way to alter an airintake is to get a bigger snorkel for your standard box, nothing but cold air getting into it, + its legal, and upgrade your filter if you want to take it a step further
- Ash
1996 Ford Fairlane mock by tickford EF Xr6 Engine EF Xr6 ECU 3:4:5 LSD diff JMM Extractors 2.5" Stainless Steel highflow cat 2.5" Exhaust T5 transmission Front Slotted rotors Lowered on Pedders Sports Ryders ....and a cherry scented airfreshner Speed determines how fast you hit the Traffic Light....Power determines how far you take it with you. |
17-03-2007, 09:26 PM | #18 | ||
Aspiring mr efxr
looks good. unfortunatly for u, u are drawing hot air into the engine.check out rollins old setup above... this is alot better than your super-cheap heat shield but if u are happy with it that is all that matters.
EF Wagon Project: Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA |
17-03-2007, 10:24 PM | #19 | |||
LOW AND SLOW
17-03-2007, 10:35 PM | #20 | ||
the heat shield stops hot air coming from engine side of the engine bay and allows more air coming in under the bonnet which is cool to get into the pod so yes a heat shield will improve the effectiveness of a pod but a knN panel filter in stock air box with xh snorkel will probs work jsut as good and is that much more legal
17-03-2007, 10:49 PM | #21 | |||
LOW AND SLOW
17-03-2007, 10:53 PM | #22 | |||
Eat more peanuts....
Just keep the old stuff it you need to replace it for any reason.
'04 Falcon XR6T Ute, Envi, K&N filter, F6 Intake, Twin 2.5" exhaust... Formerly owned: '99 AU Falcon Ute '88 EA Falcon GL |
17-03-2007, 10:57 PM | #23 | |||
it doesnt stop ALL heat from coming in, it does allow alot more cool air in than if there is no heat shield however. |
17-03-2007, 11:03 PM | #24 | ||
LOW AND SLOW
Thats kool mate, thats what i was getting at.
17-03-2007, 11:40 PM | #25 | |||
www.TUFFCARPARTS.com
http://i1233.photobucket.com/albums/...psc203b7b1.jpg |
18-03-2007, 09:04 AM | #26 | ||
Cane Farmer
Well, at the moment I am modifying the old intake pipes and snorkel so that the sir from the snorkel is directed straight to the pod. I'm pretty sure that'd feed plenty of cold air into to.
I might even get a custom S/S box made up to house the pod. |
18-03-2007, 09:15 AM | #27 | |||
LOW AND SLOW
18-03-2007, 01:12 PM | #28 | ||
Cane Farmer
Ok here is an update.
I took the bottom half off the airbox and put it back in place, hooked up the snorkel and angled the pod down into the box. Hopefully that should feed it heaps more cold air! |
18-03-2007, 01:59 PM | #29 | ||
STR8 6
Yea that looks heaps better and hopefully more cold air
18-03-2007, 02:02 PM | #30 | ||
Hmmmmm
that setup is somewhat better, but it is still illegal mate.
with your airbox setup being the same design as the one on my XR you could try somehting along these lines if you wanted to make it perform alot better, and also have to added bonus of legallity. |
