Old 27-03-2007, 09:29 AM   #1
thorpy
Default AU Water Leak from fire wall
I have a water leak from fire wall after it rains.Water drips onto your feet at brake & clutch pedals.My car is a 99 Ute,my son has 02 Ute & has the same problem after it rains.Im geussing the water is collecting somewhere & coming through with the movement of driving.Has anyone else had this problem ??
thorpy is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2007, 09:41 AM   #2
JefXR8
JefXR8's Avatar
funny you should ask this,driving back from syd on the weekend i had a few drops leak onto my foot lol,i havnt had time to looks for the leak yet but if no one else knows what it is ill find it and tell ya
JefXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2007, 09:46 AM   #3
james22
With da Warlords
james22's Avatar
Both our cars are the same, my Xr leaks and the mrs Falcon S leaks too....
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
Old 27-03-2007, 11:15 AM   #4
AU dude
Flying high...
AU dude's Avatar
My guess would be if the car is a manual, then there is a crack where the clutch cable runs through the firewall, its a common problem for an AU. I believe the firewall flexes from the clutch being pushed in a out....
AU1 Forte - 17'' AU2 Tickford rims on all corners, Super low springs,
KYB shock absorbs + camber castor kit and a 3.45 LSD, Tickford snorkel,
3" mandrel intake, K&N pod in the box, Polished Rocker Cover.
AU dude is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2007, 12:08 PM   #5
JefXR8
JefXR8's Avatar
mine is manual and there is no crack ive checked that.
Old 27-03-2007, 12:15 PM   #6
Bucknaked
Bucknaked's Avatar
Its a common problem. Pedal box at the firewall apparently. The firewall is a little thin and the movement of the clutch weakens it and cracks it. Only manuals effected.
FG2 XR6T
KIA Cerato
2022 Kawasaki Z900
Old 27-03-2007, 12:28 PM   #7
GCPursuitPower
AUII XR8
GCPursuitPower's Avatar
It would most probaly be a rubber grommet in the fire wall that has broken down over time had the same prob with my car just a 5 cent piece of rubber that seals around cables and wires going through the wall.
Ford XR8 AUII Sedan, 5.6L Stroker Engine 250kw.
GCPursuitPower is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2007, 12:56 PM   #8
JC
JC's Avatar
It's nothing silicon can't fix, but you have to find the source of the leak first!
Ford Performance Club ACT
Old 27-03-2007, 04:57 PM   #9
sickxr
Ford POWER!
sickxr's Avatar
I had the same thing with my manual xr6. Simply remove the drivers wiper and remove the plastic that is under it. if you get a light and flash it down there you will see 6 (maybe 8) spot weilds that tend to pull apart. I simply used some silicon and no more leaks!
Liquid Silver Ford Falcon AUII XR6 HP Manual
sickxr is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2007, 05:32 PM   #10
Pistonbroke
Mines an auto and does the same thing.
Pistonbroke is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2007, 08:23 PM   #11
thorpy
Thanks sickxr found 3 spot welds that looked dodgy put silicon on them,so far so good.no leaks
