Old 28-03-2007, 09:48 PM   #1
Alan Shore
Alan Shore's Avatar
Default Ghia is a lil sick...
Hey peoples...I'm back with the blue oval (swapped my VL turbo for a 98 AU Fairmont Ghia 5L). So anyways...I've noticed that my abs light remains on at all times...I've tested the braking from slow speed and find that the wheels locked, so perhaps I don't have abs at all. Pedal feel is weak with it going almost all the way to the floor.
My traction control light stays on too...flicking the switch makes no noise or does anything. And last one...when cruising at different speeds, there is a rubbing noise of some sort coming from the front left somewhere...more prominent when turning right. Any help would be great peoples! Cheers...
Alan Shore is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2007, 09:51 PM   #2
TwistedEL
TwistedEL's Avatar
Sounds like you need to get under the front left wheel and inspect the pulse ring and sensor
If the ABS light is on it means there is a fault and ABS has been disabled. Traction control is linked in with ABS that's why it's off too.
Old 28-03-2007, 09:51 PM   #3
Mark One
A humorous statement
Mark One's Avatar
You need your brakes looked at quick smart.
Black manual AU1 S.
S
Originally Posted by HLC
not using the search button makes the baby jesus cry.
Mark One is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2007, 11:13 PM   #4
GlennBA
GlennBA's Avatar
ABS sensor, same thing happened to my dads BA.
GlennBA is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2007, 06:12 AM   #5
au2sw
Blown 5L coming
au2sw's Avatar
next port of call my man is the brake shop....and id be doing it pretty soon. if youve just bought it, was it private seller, or dealer? if dealer, there should be at least a 6 month warrenty and they will cover that sort of thing, especially if it has been that way since you bought it.
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2007, 07:11 AM   #6
walker
walker's Avatar
Well if you bought it with a RWC take it back and say wtf is going on here and it shouldn't be your problem........ But on the other hand and it didn't come with 1 I would be getting it checked out, as to that brakes are fairly usefull in a car
Its not peer presure..........Its just your turn!
XE project underway
walker is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2007, 07:43 AM   #7
GK
Walking with God
GK's Avatar
Walker, check the first post. He swapped cars with a mate.
Welcome back to the blue oval. Is the car on gas? That plays havoc with the traction control system and isn't compatible with gas. If it is, turn off the gas and see if the TC light goes out.
As for the ABS, could be the sensor, filled with crud. Gently clean it and then see. If no joy, go to the brake dude.
Even though these are rears, here is a pic of the abs sensor ring. It's the bit with the ridges on it. The sensor is a small bit about half way down.
http://www.fordforums.com.au/showpos...2&postcount=68
This will be more helpful. Look at picture #6, you can see the sensor through the hole.
http://www.fordforums.com.au/showpos...5&postcount=54
Keep us posted with your progress.
BTW, swapping a VL for an AU Ghia V8 is an awesome deal. You scored!
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 29-03-2007, 06:39 PM   #8
walker
walker's Avatar
GK
I cant see anywhere in that post where it says swapped with a mate, he very may well of but it dosen't say that.......... It dose say swapped but caryards do that kinda thing to....
XE project underway
Old 29-03-2007, 07:12 PM   #9
GK
Walking with God
GK's Avatar
Point well made, I assumed the swap occured between him and a mate!
Cheers,
GK
Now gone!
On LPG
