29-03-2007, 07:02 PM | #1 | ||
Hey everyone, just wanna know if putting a vct engine in an au3 falcon without vct is a straight swap over other than the ecu.
Any help would be greatly appreciated thanks Benny Mac
New Project: 1980 MK2 Escort Panel Van, 2lt, auto Soon to be painted running a 4.0ltr v6 See the build here http://www.fordforums.com.au/showthread.php?t=11388068 You Have Freedom of Speech Just Choose to Remain Silent |
29-03-2007, 07:04 PM | #2 | ||
Requires some extra wiring as well.
29-03-2007, 07:46 PM | #3 | ||
I reckon you'd be better off putting an HP XR6 engine in mate. VCT is harder to mod, there's not a lot of aftermarket upgrades, in the aftermarket boys "too hard basket".... But AFAIK it's just electrical, ECU and engine... Good luck mate!
29-03-2007, 07:58 PM | #4 | |||
Barra Turbo > V8
-2011 XR6 Turbo Ute - Lux Pack - M6 -2022 Hyundai Tucson Highlander Diesel N Line |
29-03-2007, 09:12 PM | #5 | ||
I have always wondered this myself. I had the idea of just swapping the heads thought, putting vct onto my block. Would it be possible to edit the stock ecu to run the cam timing? I think it would be a pretty cool mod if it wasn't too hard to do.
Evan |
30-03-2007, 06:19 AM | #6 | |||
Blown 5L coming
probably cheaper to do then the whole engine...so head, ecu and wiring? would that work or is the bottom end different to the standard 6?
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;) NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com Quote:
30-03-2007, 07:09 AM | #7 | ||
bottom end is identical
30-03-2007, 06:24 PM | #8 | ||
What extra wiring has to go in? I would guess what ever it is that runs the vct component to go from the front of the motor to the ecu? If i can get a head at a cheap enough price then it would probably work out better than doing an after market cam. I am just dreaming of course, but i still maintain it would be cool!
Evan |
31-03-2007, 09:33 AM | #9 | ||
TL40 Wagon?
IF you can get a VCT engine cheap enough and they are about its easy. They will drop in.
Everything will work except for the VCT which will mean it will be like an XR^ with the cam retarded all the time. All the VCT does is advance the cam from 1000-3800rpm. you could build an rpm switch to do this or muck about forever with copying the vct wiring and finding a VCT ECU which is easy enough every fairlane faormnit ghia had one |
31-03-2007, 12:04 PM | #10 | ||
has anyone tried running a vct cam in a non vct head?
is the xr6 hp cam is a different profile to vct cam ?
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17. |
31-03-2007, 03:04 PM | #11 | ||
TL40 Wagon?
Yes the vct cam and XR6 cam are different.
31-03-2007, 03:04 PM | #12 | ||
What sort of gains would be expected out of this conversion? Would it be the same as just putting a vernier gear on the standard cam? I believe that is used to change the cam timing?
31-03-2007, 05:53 PM | #13 | ||
Seems like simplest option is to trade in and buy a car with VCT!
31-03-2007, 08:18 PM | #14 | |||
