Old 31-03-2007, 01:12 PM   #1
syktlr
stktlr
syktlr's Avatar
Default got thermos for $70
hi just thought id let everyone know i picked up a set of thermos out of a el from deer park wreckers for $70 fairly cheap just wanted to pass on.i got the wiring kit and have printed of a guide from here how long do u think it would take?
eb v8, dedicated gas,twin pipes,ghia interia,au console,el mirrors,drilled and slotted rotors,lowered with superlows and koni 3 ways ...:evil_laug
and maybe selling :
syktlr is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2007, 03:15 PM   #2
Walkinshaw
Two > One
Walkinshaw's Avatar
3hrs should see it complete. The hardest job is removing the stock fan if you don't have the Ford tool. A few big screwdrivers should see it come off.
Old 31-03-2007, 03:46 PM   #3
BRADMAN
BA Mk2 XR6 Turbo
BRADMAN's Avatar
its a pretty easy job.
walkinshaw is correct without the ford tool its a beatch. however take 1 bit of flat steel, cut a hook out of one corner so it locks onto the nut heads and shaft and turn spanner the opposite direction. itll be tight!! but itll come with a tad of effort.
once loose take the shroud off and fan off.
slide fans into grooves at base of radiator
put 2 bolts into each top corner. 1 should line up the other use a washer and new nut from memory and your done.
ohh and of course wire it up after installing. good luck and have fun
yeah 3hrs should do the job...maybe longer to neaten wiring
brad
2005 - BA mk 2 - XR6T - 4.0ltr Turbo - 6 Speed Manual
Blue Power Airbox, Sunroof, Typhoon Wheels, Brembos, Prem Sound, Momo Chunky Wheel, Genuine FPV Gauge Holder, Whiteline Swaybars, Lowered, Tinted Windows, 60lb Injectors, Plazmaman Cooler, Hot Side & Under Battery Pipes, 4" Dump & Cat, Process West Surge Tank & Bosch 044, Turbo Inline Oil Filter
BRADMAN is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2007, 04:25 PM   #4
DEVL-XR
EBII XR6
DEVL-XR's Avatar
Do we have a detailed how-to for the thermo fan conversion?
If not a sticky should be made with lots of info and pics of how to wire it all up. Reason for this is that theres a lot of people wanting to do this mod and it'd be handy to have all the info in 1 sticky thread.
DEVLXR
DEVL-XR is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2007, 04:34 PM   #5
frd_crzer
:D:D
frd_crzer's Avatar
that is a nice pik up and that is pretty cheap
Cheers Grant
frd_crzer is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2007, 09:53 PM   #6
private9
www.TUFFCARPARTS.com
private9's Avatar
Great price, good pickup! Mate of mine just picked up a set off ebay for $10 or so, couldn't believe it!
