Old 02-04-2007, 08:57 AM   #1
NZ
NZ's Avatar
Default rear camber adjustment on IRS?
Hi folks. Just wondering if there is any ford part to adjust the camber on the IRS models. At the moment my car has got a bolt with a large washer that locates it in the centre of the long hole in the upper arm. I went to spare parts and the guy said he couldn't say, when i asked if it was that he couldn't or wouldnt say he told me that it was he wouldnt say because they would want me to bring the car in to have them do the work so it leads me to belive that there is some part avalable to adjust the camber. The IRS was from a Fairmont ghia and i have ultra low spings so there is a lot of negative camber. I want to straighten it up to get rid of the ommodore look. cheers
EF Falcon Sedan 5.0 auto with IRS
"the man that crashs AFF"
Old 02-04-2007, 09:06 AM   #2
Casper
Contributing Member
Casper's Avatar
The Fairmont Ghia IRS had very limited camber adjustment (I believe the bolt you are looking at is it adjuster) however the XR6 VCT and XR8 IRS, while exactly the same, had a longer bolt and more adjustment available. May be something to replace so you can adjust more.
Older, wiser, poorer.
Old 02-04-2007, 10:17 AM   #3
RG
Back to Le Frenchy
RG's Avatar
That maybe so but you will still not have enough adjustment to get rid of the commodore look. Mine is pretty low and is adjusted as far as possible and I still have it. The good news is though that Pedders has an adjustment kit for the rear of these which according to them is only $35 (yes $35 not a typo) per side which will apparently give you all the adjustment you'll need.
Old 02-04-2007, 08:41 PM   #4
ronwest
All Bran = Regular Member
That bolt with the large washer should be replaced with a similar bolt which is welded off-centre to the washer. When the bolt is turned it adjusts the camber.
Bolt and washer look similar to this:-
Oddly enough, even though I fitted the eccentric adjusters, they seem to be in the "neutral" position after the wheel alignment. Tyre wear is even so maybe the adjustment (on mine) is minimal.
Old 03-04-2007, 07:25 AM   #5
NZ
NZ's Avatar
Ok cheers for the info i'll pop into pedders today. I'd tried repco who looked up their suspension parts but nothing was listed and i passed up going into pedders.
thanks for info fela's
