Old 02-04-2007, 08:53 PM   #1
tickfordguy
TICKFORDGUY
Default funny idle
car idles ok but when u stop hard it drops down a couple hundred rpm have all new leads and plugs seems to run ok but every now and then it drops down and then up what could it be
tickfordguy is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2007, 08:06 AM   #2
tickfordguy
TICKFORDGUY
Default idle
any one have any ideas on what it could be
Old 03-04-2007, 08:13 AM   #3
Mechan1k
Mechan1k's Avatar
Dirty air filter .... sounds weird ... but it does this on factory LPG models moreso when stopping quickly revs will drop to nearly stall point and regain.
Other than that ... I'd say your Idle Control Solenoid (I think it's called that) may be showing initial signs of dying. Not sure if it's a cleanable item ... or if it's just better to replace it or not.
Others will give you a better idea.
Might be an idea to spray some carby cleaner into your throttle body too ... it's probably oiled/gummed up ... the butterfly can some times stick a bit when gunked up too.
Old 03-04-2007, 12:21 PM   #4
GK
Walking with God
GK's Avatar
Check the filter as Mechan1k has suggested as it's so easy to do. If it's dirty, replace it. If that doesn't help, then give these a go.
1. Cleaning ISC Valve
http://www.fordforums.com.au/showpos...9&postcount=43
2. Cleaning Throttle Body
http://www.fordforums.com.au/showpos...2&postcount=48
If the idle hasn't improved, you may consider giving this a go.
3. Setting Base Idle
http://www.fordforums.com.au/showpos...1&postcount=47
Cheers and all the best with it,
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 03-04-2007, 12:24 PM   #5
Mechan1k
Mechan1k's Avatar
Well done with the links GK.
I swear you wrote Chief though :hihi:
Well that's what I saw in the email notification ... :P
Old 03-04-2007, 12:36 PM   #6
StealthAu
I had the same issue, when stopping hard revs dropped. Had the auto serviced last week and havn't had this issue since.
Old 03-04-2007, 01:03 PM   #7
tickfordguy
TICKFORDGUY
thanks gk and other ford dudes
Old 03-04-2007, 01:04 PM   #8
GK
Walking with God
GK's Avatar
You got me! LOL!
I actually did write chief first, as I'm often mucking you 2 guys up! I changed it straight after, as I checked your post to make sure I was giving credit where it was due!
GK
Now gone!
On LPG
Old 03-04-2007, 01:05 PM   #9
GK
Walking with God
GK's Avatar
You are welcome!
Hope it works out cheap and easy for you.
GK
Now gone!
On LPG
Old 03-04-2007, 02:13 PM   #10
S3SR
S3SR's Avatar
GK
only wish that were true (cheap part anyway)
TIP: fix problems when they happen not when you have time, it will cost more than you have time for...trust me
My Cars:
2002 Ford Falcon AU S3 SR
2006 BF MKI Falcon XR6
2008 Mazda BT50 SDX
2004 BA XR8 ute
2006 AUDI A4 B7
2013 FG II XR6 Ute
2006 Ford Territory TX
2003 Ford Falcon XR8
2009 Territory Turbo Ghia
Current: 2012 Audi A4 B8 2.0T Quattro
S3SR is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2007, 02:24 PM   #11
Stav
Smile
Stav's Avatar
The car is running too rich at idle and the plugs arent burning the extra fuel to create enough engine vacuum.Also could be the tps going haywire and not referencing the correct idle voltages to the ecu which controls the isc module for idle speed
