Old 03-04-2007, 12:58 AM   #1
StevenAu2
Irregular Member
Default Window Stuck Down
Help lol,i was driving home from work tonight at midnight and put my windows down abit.Then i noticed my drivers side electric window button wouldnt raise up the pass window.I reached over and the pass side button wont raise the window either so now im stuck with the pass window 3/4 of way down.
So tmrow(well today actually) il take the door trim off and is there a way to manually raise it back up? I suspect the power window regulator is buggered and i flicked through the manual and it doesnt look like a fun job to replace.
Anyone else had the same problem?
StevenAu2 is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2007, 05:59 AM   #2
au2sw
Blown 5L coming
au2sw's Avatar
deos it sound like the motor is still working? maybe just some graphite powder or silicon spray on the guides will fix the problem? also possibly clean the contacts in the switches? dont know if you have already tried those options, im just trying to save you from having to pull the door card off and replace the regulator. otherwise good luck.
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2007, 08:01 AM   #3
StevenAu2
Irregular Member
Yep motor still works fine going down just nothing to go up on the pass side.Ive done the lube on the guides ages ago and thats never played up since.
Should be fun driving around with 1 window 3/4's down.Cars know how to really P!$$ me off sometimes.
Old 03-04-2007, 09:04 AM   #4
mcflux
mcflux's Avatar
Motor still working most likely = switch problem. So it's fully dead when you flick "up"? If the motor is still trying when you switch up then that means the switch is fine and that you'll have to have a crack at the doorskin & look at the guides/regs as au2sw has mentioned.
Old 03-04-2007, 09:06 AM   #5
StevenAu2
Irregular Member
Thats right,motor works down but not a sound when you try to go back up.
Old 03-04-2007, 09:13 AM   #6
mattp
mattp's Avatar
Flick the switch up and down for a while and it will go back up. It's meant to be 31 times to reset it but it seems to differ sometimes. Just when it starts to go up, let it keep going obviously, but it should fix it for a while anyway. Then I'd suggest cleaning your switches out and cleaning all the contacts, especially if you haven't done it before.
mattp is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2007, 09:29 AM   #7
Racecraft
they call me Tibbo
Racecraft's Avatar
http://www.fordforums.com.au/showthr...indow+tutorial
switches for sure
Old 03-04-2007, 09:49 AM   #8
StevenAu2
Irregular Member
Hey guys thanks,when i took the pass side switch out the contacts were abit off color,and i have nevber cleaned them before,rubbed them up(ok that sounds bad) with some sand paper and IT WORKS AGAIN!!!!
I didnt think that could possibly stop them from working but it did.
So thanks again!!!
Old 03-04-2007, 02:54 PM   #9
XR8AU2121
XR8AU2121's Avatar
Thanks from me also. The passenger window switch has only worked on "down" for the last 2 years. Had to put up from the drivers side. Just uncliped the switch, a bit of sandpaper and bingo all fine. I hate to think what a dealer would have charged. Probably would have just fitted a new switch.
XR8AU2121 is offline   Reply With Quote Multi-Quote with this Post
