Old 03-04-2007, 11:08 PM   #1
Jorgo85
Jorgo85's Avatar
Default Tickety friggin tick
I have just had my head reconditioned. The water jacket between the 3rd and 4th cylinder had corroded out and needed welding and re-facing. I paid $550 for the weld job, and an extra $80 for the bloke to put a lifter kit through the lifters. I removed the head myself and spent 12 hrs today re-assembling everything and triple checking all the bolts and torque specs. I finally started the car at about 7pm (WA time) and I was expecting a bit of lifter noise for the first minute or 2, but after five minutes, it still sounds like a diesel. It seems as though the cam is running dry. The (factory) oil pressure gauge is reading about half way up. Or alternativly the engine reconditioner has stuffed all my lifters. When I took the head off, I applied pressure to the rocker arms to try and find the dodgy one. None of them budged. I checked them again before putting the head on, and they're all soft. Can anyone shed some light on the subject before I tear the mechanic a new **** hole?
Any help will be most appreciated.
Sam
Jorgo85 is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2007, 11:57 PM   #2
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
Why do you think they're called 'TickFords' :P
Did you get the cam chain tensioner in properly? Enough oil in the sump? Did you change the oil when you did the head? The lifters take a few minutes to build up pressure and get oil in them, although 5 minutes seems a bit excessive. Someone on here who has done a heap of these should be able to answer that better.
I'd ring the mechanic and see what he says without being rude before you go mental at him.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
