12-04-2007, 04:42 PM | #1 | ||
I had problems with my 98 AU sucking the fuel DTE dropping everytime i looked at it. Was told by 3 people it was my Fuel Injectors so i've done those and the spark parks and while driving today the same thing continues to happen. I spoke to a mechanic that was a complete dick and told me my car was f'ed and wouldn't give me a price to put the diagnostic tool on it etc etc and he mentioned it could be a dud ECU.
Does anyone have ANY ideas what i can try next? |
12-04-2007, 04:52 PM | #2 | ||
Just slidin'
How many K's per tank are you getting. The DTE fluctuates wildly at the best of times, depending on your driving style.
As for remedies, changing your air filter, or washing it if its K&N, helps immensly if its over 10000k's old (dont listen to the 50000k's they say on the box), Oxygen sensor, plugs and leads, all these help in keeping your car sucking only the amount of petrol it needs. Hope that helps.
MD Mondeo - For the family
12-04-2007, 06:33 PM | #3 | ||
The DTE is supposed to go down as you drive. But if you're getting less than 300kms per tank, it usually means it's running rich - 2 major causes of that are a stuffed MAP sensor, or a stuffed O2 sensor. If you don't know when they were last replace them, then for $200 odd for both, it's a cheap fix, though of course can't guarantee that it will fix it.
You probably really need to get the scan tool plugged in and get the error codes off. A new ECU is up around the $1000 mark, and needs to be programmed/matched to the BEM by Ford.
12-04-2007, 07:47 PM | #4 | |||
12-04-2007, 08:03 PM | #5 | ||
sounds like a it needs good mechanic more than anything "car was f'ed" tells you nothing.
12-04-2007, 08:09 PM | #6 | |||
Back to Le Frenchy
take it to a decent mechanic, G&D are local to you and won't stuff you around.
12-04-2007, 08:32 PM | #7 | ||
sounds like a MAP sensor failure like JC said.
12-04-2007, 09:15 PM | #8 | ||
maybe high fuel pressure...? too much pressure causing too much fuel to go in when the injector opens...
12-04-2007, 09:47 PM | #9 | ||
i reckon map sensor! MAKE SURE all your vacuum hoses are connected in the right positions as well. Is the car blowing any smoke/carbon?? idling rough??
12-04-2007, 10:23 PM | #10 | |||
12-04-2007, 10:51 PM | #11 | ||
it sounds like my car when my o2 sensor wsas stuffed.
13-04-2007, 04:20 PM | #12 | ||
What temp is the engine running at? If it runs to cold it could be in wam up mode which will make it run richer.
13-04-2007, 04:26 PM | #13 | |||
13-04-2007, 04:54 PM | #14 | ||
thanks guys. I'm going to try a new map sensor! I'd say it would have never been replaced anyhow.
13-04-2007, 05:41 PM | #15 | ||
CRE.87V
hey guys mine is doing the same....wat is a new map sensor worth
13-04-2007, 05:45 PM | #16 | |||
