Old 13-04-2007, 04:47 PM   #1
elusiverunner
elusiverunner's Avatar
Red face Chrome Dressing
Hello Members - I hope some of you can give me some ideas on the following matter. As Ghia and higher end drivers will know the boot has chrome trim above the rear number plate. On my vehicle this has become covered with light scratches, none of which I have been able to eliminate.
I personally would like to have this trim frosted in its finish, if there was somewhere to get this done. However, I would like to see what other members would have as ideas to either get rid of these scratches or cover them up.
BF Fairmont Ghia MKII
2007 Fairmont Ghia MkII. Ego in colour
4 litre 6 Cylinder, ZF 6 speed transmission.
Bolle Window Tint - fitted by Tint a Car
PWR Heat Exchanger, PWR Auto Transmission Oil Cooler - No milkshakes in this car.
After market DRL.
Custom fitted gauge holder with three gauges - Stav of Stingray Car Security.
elusiverunner is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2007, 04:52 PM   #2
Smoke Pursuit
it would be easy to do if it was real chrome metal, but as it is plastic the only way to fix would be get it re chromed dipped, and even then the finish would not last as long as the proper factory one.
If your really desperate you could just replace the garnish, but at $150 i dont think this is the best option.
2022 RAM Laramie 5.7 2023.50 Ranger Wildtrak 3.0 V6 Premium Pack 2024 Everest Sport 3.0 V6 Touring Pack2025 Mustang Darkhorse 6M Blue Ember + Appearance pack ETA Jan 25.
Smoke Pursuit is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2007, 10:04 PM   #3
Silver Ghia
Silver Ghia's Avatar
Frosted would look real crappy I think. I would try to get a good second hand one from the wreckers. I think there are places which does plastic chroming, where you could get it chromed as per original. Look up the yellow pages.
Also dont use this as a handle for when opening or closing the bootlid, to prevent future scratches. But then you cant control kids and wives.
Silver Ghia is offline   Reply With Quote Multi-Quote with this Post
