Old 22-04-2007, 10:09 PM   #1
b2tf
not here much anymore
b2tf's Avatar
Default Fairmont MDC issues (again)
Dad's fairmont is having the standard MDC death atm, display is fading on one side.
Im 99% sure I know the answer to this, they dont just have bulbs behind the screens do they? Its been replaced under warranty back when the car was 6 months old, but Im just trying to work out if we have to go the full replacement route with it or if I can just rip it out and put a new bulb in.
So is there a bulb behind it or is it stuffed?
2024 F150 XLT
Old 22-04-2007, 10:21 PM   #2
mattp
mattp's Avatar
There are bulbs behind them. If it's only fading on one side that'll be it I'd say, since there's 2 big bulbs for the main display.
mattp is offline   Reply With Quote Multi-Quote with this Post
Old 22-04-2007, 10:32 PM   #3
b2tf
b2tf's Avatar
oh sweet as, now the hard one - how the hell do you get the unit out to replace them?
2024 F150 XLT
Old 22-04-2007, 10:39 PM   #4
HLC
Audi S3
Austin, to get the unit out...
pop the black plastic surround around the clock off using a small flat blade screw driver.
usea phillips head to undo the screw behind the cover you just popped off.
then just wiggle the unit til it comes out.
undo the 2 looms.
then use a pair of needle nose pliers to take out the bulbs. same as in the dash cluster.
fitting is reverse.
Old 22-04-2007, 10:41 PM   #5
b2tf
b2tf's Avatar
undo the 2 looms.
fitting is reverse.
not just a pretty face eh :
2024 F150 XLT
Old 22-04-2007, 11:08 PM   #6
HLC
Audi S3
:evilsasmo
Old 22-04-2007, 11:23 PM   #7
mattp
mattp's Avatar
To prevent damaging anything, I use a business card to slip in behind the clock surround and press the toggle in. The cardboard can't scratch my lovely raindrops finish, whereas a screwdriver could ;) Apart from that HLC hit the nail on the head. Left side comes out first, right side will follow. Cheers
Old 23-04-2007, 10:28 PM   #8
HLC
Audi S3
raindrops finish... *makes ****ing motion* :
alternatively, you could put a piece of cloth around the blade of the flat head screwdriver, thats what i usually do.
