Old 25-04-2007, 07:05 PM   #1
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
Default XL vs XLS
Just a quick question guys, I've read about the differences between high series AU's and low series AU's but i'm unsure where the XLS ute fits..I assume XL would be Low series, does that make XLS High series or is it still low?
Thanks in advance
Chad
DoreSlamR is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2007, 07:11 PM   #2
AU dude
Flying high...
AU dude's Avatar
Good question, I'd also like to know what the options/differences are.
AU1 Forte - 17'' AU2 Tickford rims on all corners, Super low springs,
KYB shock absorbs + camber castor kit and a 3.45 LSD, Tickford snorkel,
3" mandrel intake, K&N pod in the box, Polished Rocker Cover.
AU dude is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2007, 07:26 PM   #3
Aulpgute
XLS is the mid range model between XL and XR. Had 16' wheels and better trim than an XL
Aulpgute is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2007, 07:26 PM   #4
NC1183
NC1183's Avatar
As for where it sits as in low or high series i don't really know but if ford used the same fitout standards as they have in the BA then the XL will have vinyl floor and XLS has carpet, also i think the XLS has lower suspension then the XL
Nathan
2005 FPV BF Super Pursuit
The new toy (now sold)
The SP
The old ute (sold)
www.aufalcon.com/nc1183
Build Thread
Originally Posted by F6T
If you look closely you can see the remains of a Hyundai excel that’s been sucked into the intake.
about the pic of 'CHOP YA' F6
NC1183 is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2007, 07:48 PM   #5
Mechan1k
Mechan1k's Avatar
OK ... this is what I found ... especiallt when it comes to what BEM is uses.
It uses a high-series BEM with some functions disabled ... making it a Mid-series vehicle.
Strange I know .... I did see a listing on what things were disabled in the BEM but don't have them on hand at the moment.
XLS has a few things the XR has ... but a few things missing as well.
From factory ... here are a few things it didn't have that the XR did have.
A/C
Cluster (AU series anyway)
Adaptive shift auto
16" wheels instead of 17" wheels
ABS
LSD and diff ratio difference
different interior trim
XLS came standard with XR Sports suspension ... although raised 50mm if option Dedicated LPG (in the rear only though from memory)
XLS has a different tub liner (allows a full CHEP Pallet to fit between the wheel tubs ... XR didn't fit a pallet)
AU XLS had no body kit fitted (although I think earlier series XR's didn't either)
I am sure there is much more but that's what I can think of off the top of my head.
Old 25-04-2007, 08:28 PM   #6
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
cool, thanks for the info... so an XLS is a hybrid of sorts... so the BEM controls things like turning the interior lights on when you unlock the doors?
Old 25-04-2007, 08:58 PM   #7
Mechan1k
Mechan1k's Avatar
Yeh .. also power antenna height .... headlights dwell timer after turning vehicle off (Ghia and T-series had a seperate switch next to the headlight switch on the dash) ... intermittant wiper dwell timer and adjustability.
Will see what i can dig up on the listing.
Old 25-04-2007, 09:11 PM   #8
5tumpy
My mate had an XLS that had the VCT engine in it....
5tumpy is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2007, 09:13 PM   #9
b2tf
not here much anymore
b2tf's Avatar
Series III XLS came standard with the XR6 VCT motor I think?
2024 F150 XLT
