Old 06-05-2007, 01:18 PM   #1
csv8
csv8's Avatar
Default The new Sterling Bullet™
The new Sterling Bullet™ — competing in Class 4 & 5 — is lean and mean, ideally suited for Construction, Utility, Municipality & Government and P & D. The Bullet is vocationally specific, engineered by truck specialists who know your business. It does everything you need it to do ... safely, efficiently, economically. All day. Every day.
At Sterling Trucks, our family keeps expanding. From the Class 8 Set-Back vocational line with GVWRs up to 105,600 lbs. to the new Class 7 & 8 Set-Forward truck and the Class 3 – 5 Sterling 360 low cab-over-engine ... to the new Bullet. Sterling keeps building more of the work trucks that help keep America working.
http://www.sterlingtrucks.com/Sterli.../Features.html
csv8 is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2007, 05:39 PM   #2
apolloxbgt
cross breeder
apolloxbgt's Avatar
Looks kind of like a dodge. Isn't sterling the old ford truck division that was bought out by mercedes?
apolloxbgt is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2007, 05:43 PM   #3
Smoke Pursuit
Yes Sterling is owned by Daimler Crysler and was originally FORD Trucks.
They still carry the same lineup pretty much as when Ford owned the company, even some of the parts ive noticed are the same as EL Falcons (Aircon Vents) lol.
2022 RAM Laramie 5.7
2023.50 Ranger Wildtrak 3.0 V6 Premium Pack
2024 Everest Sport 3.0 V6 Touring Pack
2025 Mustang Darkhorse 6M Blue Ember + Appearance pack ETA April 25.
Smoke Pursuit is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2007, 06:13 PM   #4
TUF_302
The Vengeful One
TUF_302's Avatar
Looks a bloody lot like a dodge pickup!
TUF_302 is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2007, 09:25 PM   #5
CAMS290
trying to get a leg over
CAMS290's Avatar
It would want to be better than the other crap they sell, imo Sterlings are the worst Nth American truck you can waste your money on.
Cameron
CAMS290 is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2007, 10:12 PM   #6
GXL078
GXL078's Avatar
Are they made in Mexico like the F series?
GXL078 is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2007, 09:07 AM   #7
csv8
csv8's Avatar
No Canada
Old 07-05-2007, 01:04 PM   #8
mcnamg
mcnamg's Avatar
They are a dodge ram with a new nose do a search on autoblog there is a few articles on how bad the badge engineering is
mcnamg is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2007, 01:11 PM   #9
Mongoose
Can't go around corners
Mongoose's Avatar
I thought the F series was made in brazil?
Mongoose is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2007, 01:14 PM   #10
apolloxbgt
cross breeder
apolloxbgt's Avatar
As said above,sterling is part of the daimler - chrysler group,so not that much different to the bt-50/ranger arangement.
Old 07-05-2007, 04:13 PM   #11
mcnamg
mcnamg's Avatar
brazil and mexico are where they build the F Series.
The current model in mexico at the plant that the share with Navistar and the older model in Brazil and also RHD in Brazil
Old 07-05-2007, 04:26 PM   #12
TCK-098
TCK-098's Avatar
I wouldnt say no if i got offered a lightning or a harley davidson version of the f-series.
Look like a dodge though get to see a few versions up here in Brissy.
18 T6 Multivan
03 Ba Xr turbo 300rwkw
TCK-098 is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2007, 04:55 PM   #13
Full Noise
Life begins at 40
Full Noise's Avatar
Location: Melbourne. Socialist capital of Victoriastan.
Does it come standard with all of the usual Sterling features?
Like:
An air conditioning unit that leaks water all over the passenger side floor.
A sensor that detects summer and jams the heater on full.
A plastic dashboard that creaks and rattles every time you go over a bump.
Gauges that fail because they were made by a four year old girl in Indonesia.
Plastic drain tap on the radiator that breaks in the middle of nowhere resulting in a total loss of coolant.
High beam switches that flick the beam on for no apparent reason.
Intermittent electrical faults in the windscreen wipers resulting in a total loss of function, that can’t be detected by mechanics.
Super special halogen headlight globes that can’t be purchased anywhere other than a Sterling dealer.
Sterling’s own speed sensors in a Roadranger gearbox instead of the speed sensors from the engine manufacturer, so when you break down and a mechanic drives two hours with what he thinks is the correct part, only to find a sensor that he’s never seen before.
I could go on, however, this is bringing back so many painful memories.
Yay, go Sterling, built to a price.
When can I place my order?
Marriage is like a deck of cards. In the beginning you’ll have hearts and diamonds. Towards the end, you’ll be looking for a club and a spade.
Justice is what you get when you run out of money.
Full Noise is offline   Reply With Quote Multi-Quote with this Post
