Old 13-05-2005, 10:03 PM   #1
tickford302
T1 TE50 Galaxy Blue #010.
tickford302's Avatar
Location: In between German Engineering and Tickford Perfection.
Default Stain in paint
Put the new rear wing on a while ago and i am left with two stains that run the width of the boot from the double sided tape that used to hold down the old bobtail wing anyone got any ideas what to use to get rid of it, i've tried the tar remover and gave the boot a cut and polish but it is still there..
tickford302 is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2005, 10:12 PM   #2
WizBang
it is a stain or the glue from the tape as this happen to once and I got this tin of stuff from the sticker place ($8.00) and it took it off with out any damage to the paint but dam if I remember want it was called but I'm sure they will
WizBang is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2005, 10:18 PM   #3
WizBang
It got the better of me and looked in the shed and found it try isopar h or sometime called hydro-carbon liquid this done well
Old 13-05-2005, 11:00 PM   #4
b2tf
not here much anymore
b2tf's Avatar
Try something like goo remover or bug and tar remover. Do you have a high pressure hose? If so, give it a pretty good going over with that at a close range but with a wide spurt of water (not just one single jet blast at it). That should loosen it up a bit, then wash it as normal, and some ScratchX or similar should take care of any marks it leaves behind.
2024 F150 XLT
Old 14-05-2005, 12:14 PM   #5
tickford302
Thanks for that i'll give it a go today and maybe finally get rid of the stains
Old 14-05-2005, 12:18 PM   #6
Peuty
Afterburner + skids =
Peuty's Avatar
Is it a stain in the actual paint?
Oo\===/oO
Peuty is online now   Reply With Quote Multi-Quote with this Post
Old 14-05-2005, 12:26 PM   #7
LuvinmyEB
Beware of mood swings!
LuvinmyEB's Avatar
Location: Western 'burbs, put your bullet proof vests on!
Eucalyptus oil might work. Test it somewhere that's not obvious first though.
1993 EBII GLi Auto, 4.0L MPI rebuilt by JMM, JMM Dev1 kit, JMM Hi Flow Cat, still to hit the quarter mile.
LuvinmyEB is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2005, 12:32 PM   #8
LG
LG's Avatar
On another note, where's your old wing?
Old 14-05-2005, 05:24 PM   #9
XRated
Shoot.
XRated's Avatar
Try "Paint Doctor". You should be able to get it from SuperCrap Auto for about 10 bucks. Comes in a big tooth paste sorta tube. It's bloody magic. Removes scuffs, stains etc..
20V Turbo
Old 14-05-2005, 05:33 PM   #10
tickford302
Peuty-- The stain is either side of where the tape used to be all traces of the double sided tape are gone and now just the stains which are dark in colour running the width of boot lid.
LG-- The old bobtail is sitting in the garage, are you interested in it?
Old 14-05-2005, 05:48 PM   #11
Racecraft
they call me Tibbo
Racecraft's Avatar
you could try and rub them out with 2000 grit w&D then buff it... It sounds like it is the clear coat thats tarnished.
Old 14-05-2005, 11:25 PM   #12
LG
LG's Avatar
Could be...
PM sent.
Old 14-05-2005, 11:35 PM   #13
Peuty
Peuty's Avatar
Ahh i see.
I had a similar problem when i tool the 4.0 badges off my ol' ED.
Fixed it by doing what Racecraft said.
Oo\===/oO
