Old 12-12-2014, 12:12 PM   #31
BOTTLEDUP
T1 TE50 P01
BOTTLEDUP's Avatar
Default Re: Cam grind, rockers and extractors for 302?
Originally Posted by bluestripes View Post
Is that another way of saying you need new heads to run that cam ?
If that's the case .., your best off looking at the TFS top end kits and piece match the parts to your chosen specs. You will also need to add lifters onto that list.
But I still think building a 347 is the smarter way.
Brad unless TFS have improved their camshafts I wouldn't really be using any of their grinds. Also much your own engine the better option is to buy your components individually and get the right parts the first time.
BOTTLEDUP is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2014, 12:13 PM   #32
mcfly94
mcfly94's Avatar
Yeah i figured, thanks for the advice and info!
There definitely coming soon, and ive found a diff out of an xr8, but i dont know whether to put the 3.45 in or wait and put 3.73 gears in, 3.45 goes well in mums xr8 but mine having that extra 150kg over hers i think i might need to go 3.73 to get the same feel.
What are your thoughts on gears?
Current Car: 2002 AUII LTD
408ci Windsor, T6 S488, TH400, 2 Piece Shaft, Helicial LSD 3.23 IRS
Daily: 1998 Mitsubishi Super VR-4 Legnum
mcfly94 is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2014, 01:15 PM   #33
bluestripes
Q - CAR
bluestripes's Avatar
Smile Re: Cam grind, rockers and extractors for 302?
Yes - I'm not saying buy the tfs topend kit, but look at all the componantes in the kit and peice match to your desired camshaft grind - heads etcetera.
Anyways - alls good and I'm signing off this post now as Dave seems to have things covered
AU FORD STROKER
347 Windsor Stroked; (10:2.1) / TFS 190 heads / TFS R Series 90 manifold / Accufab 85mm Race TB / 90mm Lightening MAF / K&N 90mm pod CAI / FTI custom cam (230-236 @ 50) / Bosch 36lb inject / MSD coil + leads / ASR 8lt sump / Mcleod RST Twin Plate Clutch / Pacemakers PH4006 + 3" single exhaust / BA Premium brake pac / Pedders Xtreme coil over shocks / 30mm Whiteline sway / 3.45 LSD / Custom FG bonnet / Ghia interior upgrade / Enkie Rims - staggered / Quarter Horse tuned.
bluestripes is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2014, 01:25 PM   #34
BOTTLEDUP
T1 TE50 P01
BOTTLEDUP's Avatar
I've got 3.91s in my T1 with the T5 manual and it sits at around 2600rpm at 100km/h. I would say of the mods I've done so far it was definitely the one which made the biggest improvement. Fuel economy hasn't suffered at all, if anything it improved.
Old 12-12-2014, 10:44 PM   #35
Bossxr8
Peter Car
Bossxr8's Avatar
I'll back that up, my economy has improved too, although most of my driving is around town where its most beneficial. Although with a BTR it sits on 2250 rpm at 100 kph, not as high as your's Bottledup.
Old 12-12-2014, 10:52 PM   #36
bluestripes
Q - CAR
Whats a BTR ??
AU FORD STROKER
Old 12-12-2014, 11:24 PM   #37
BOTTLEDUP
T1 TE50 P01
BOTTLEDUP's Avatar
Whats a BTR ??
BTR is the manfacturer of the 4 speed auto Brad, full name of the transmission is a BTR95LE or BTR97LE.
Old 12-12-2014, 11:24 PM   #38
bluestripes
Q - CAR
OK - called on my trusty friend Google.
BTR - 4 speed Auto transmission ..lol
HAHAHA - thanks Dave ... we posted at the same time
Old 13-12-2014, 12:51 PM   #39
bluestripes
Q - CAR
Just on the topic of diff gear swap ... When you say your going to swap over the gears in an xr8 diff ... Which I am assuming is the 3:45 ratio to 3:91 ratio ... What does that actually entail regarding parts to swap and estimated cost of labour ??
For when I enquired into it I was quoted around $1600.
AU FORD STROKER
Old 13-12-2014, 04:03 PM   #40
mcfly94
mcfly94's Avatar
I can get labour done for around $500 and gears for around the same
Old 13-12-2014, 04:16 PM   #41
mcfly94
mcfly94's Avatar
Are you on 3.91 too?
Old 14-12-2014, 08:58 PM   #42
MrEL
Sick Puppy
MrEL's Avatar
3.9s were the best thing I ever did to my 5.0 T5 AU ute.
Improved fuel economy and just made it so much nicer to drive.
Might even do it to the missus 5.0 AU3 Ghia one day.
MrEL is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2014, 09:02 PM   #43
Bossxr8
Peter Car
Bossxr8's Avatar
I bought my gears off Ebay for about $250, and gave them to the diff workshop to fit, cost about $600 all up to have them fitted.
Yep.
Old 14-12-2014, 09:07 PM   #44
bluestripes
Q - CAR
My guy was saying .. If you replace the gears you need to replace something else ?? Can't remember ... Plus he wanted to use gears purchased through Herrod ... Plus his labour charge ... Hence the $1600 price tag. He did say he would install ebay gears but would not warranty work (
AU FORD STROKER
Old 14-12-2014, 10:00 PM   #45
Bossxr8
Peter Car
Bossxr8's Avatar
Diff bearings probably. Mine were replaced at the same time the gears were fitted.
Old 05-08-2015, 03:31 PM   #46
snypereb
[EBGLT]
snypereb's Avatar
Hey guys,
Great read in here I got a lot of info.
Im in the middle of doing some mild mods to my 302 aswell I have a list of the parts I have so far.
Trickflow Manifold
Pacemaker PH4000
YT 2028 Roller Rockers
Crane 444225 Cam
24lb Injectors
GT40p Heads
AU xr8 motor Series 1
Just a bit unsure on what sort of valve springs I should be looking for.
[EBGLT]
Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/
snypereb is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2015, 04:10 PM   #47
bluestripes
Q - CAR
Originally Posted by snypereb View Post
Hey guys,
Trickflow Manifold
Pacemaker PH4000
Crane 444225 Cam
24lb Injectors
GT40p Heads
Send a pm to bottledup ... His a genius with the ford building specs
AU FORD STROKER
Old 05-08-2015, 05:39 PM   #48
snypereb
[EBGLT]
snypereb's Avatar
Yeah I have just waiting for him to get back to me.
[EBGLT]
Old 05-08-2015, 06:27 PM   #49
bluestripes
Q - CAR
Simplest way is to go on Fordstroker website and look at their beehive Pac springs ... That's what I brought. And you will also need new lifters and Fordstroker seeks the good gear at affordable prices. ... And yes pushrods !
More so ... Just email fordstrokers owner " Jim Woods" and he will take care of you
AU FORD STROKER
